Problem adding images, possible database or plugin issue
Experiencing problems with adding an image to a post. Tried both Chrome and IE (Edge.) During the normal "add image" process, it brings up a pop up noting that all images will be deleted, cancel or continue. I would post a screenshot, but unfortunately you have to use your imagination.
If you are pulling these pictures off of your PC they are probably to large of file (too much resulation) and you will get rejected. If this is the case you will need to reduce the file size or post them to a site like Phto-Bucket then pull them off of that site and they will be automatically reduced and they will go through with no problem.... Tedd
Thanks. Just to provide more detail, I didn't try to add a photo via attachment, I always use the "Insert Image" button instead which normally brings up the javascript plugin to choose where to add the image from, web, your gallery or upload. Except in this case it brought up a surprise. That warning needs to have a skull and crossbones on it or something...HAHA!
Ditto here. I had the problem yesterday, but things are working ok now.
The screen that popped up when you clicked on the add-image button was annoying because there was no obvious way to make it go away. No cancel button, nothing. The only thing I could do was hit the Back button.
This problem had nothing to do with the size of the image as you never got far enough in the process to select an image to upload.
