uploading problems
You must be on a "token ring" LAN. Sometime if your network cable gets unplugged, the token falls out and gets lost. Look around your computer for it. If you cannot find it, it might have got caught in the ether net...
Oh - Make sure your files are 1.5Mb or under, too.
You must be on a "token ring" LAN. Sometime if your network cable gets unplugged, the token falls out and gets lost. Look around your computer for it. If you cannot find it, it might have got caught in the ethernet...
