Unable to send private message !!!!!
I thought I would respond to a private message and go to sleep. Logged in and was welcomed. Composed the message five times, each time differently. Difficult to write the same message five times identically. Tried to submit message,but after sending I was told I WAS NOT SIGNED IN. Again five times. I stopped. One of the definitions of insanity is doing the same thing repeadedly and expecting the same results. Lost 2.5 hours of sleep.
DIEGO I AM TRYING TO RESPOND BUT CAN'T!!
On another note, it seems like it was a pretty detailed and thorough reply. What I've gotten in the habit of doing it selecting the entire message right before I send it, and copying it (Control + C), that was there's a copy of it just in case it doesn't send. Control + A will automatically select the entire active window. Or you can type the message elsewhere, like in Microsoft Word, etc and copy and paste it into the forum message and send it. That was the forum won't time out.
It's probably a little overkill, but I've been burned a couple of times.
When it tell you you're not signed in, doesn't it bring you to the login screen to type in your username and password. If you type them in and log in again, it'll send you message. The forum probably times out in the time you spent typing the message, it's pretty common.
My other suggestion: https://www.google.com/chrome/browse...top/index.html
Tedd Thompson
Sep 30, 2012 11:14 AM
