Site Help Ask your questions here about how to use the site.
Smilies
Old Mar 17, 2014 | 10:44 AM
380 Racer's Avatar
Smilies
So why can't post smilies in my posts? this site or my puter?
Old Mar 17, 2014 | 11:33 AM
It must be you.
Old Mar 17, 2014 | 11:38 AM
Macadoo's Avatar
Explain. You can't see the emoticons? You click but nothing happens? Are you using the correct batch? For in-post smilies use the batch to the right of your text box, not the ones underneath.
Hope this helps
Old Mar 17, 2014 | 11:44 AM
Thumbs up They work for me
Are you using the 'Go Advanced' tab to go where the smilies live on this site?
Old Mar 17, 2014 | 11:47 AM
Macadoo's Avatar
Good catch Allan. If you quote a previous post it automatically takes you to the advanced area which contains the emoticons.
Old Mar 17, 2014 | 10:29 PM
380 Racer's Avatar
Doesn't seem to make any difference whether I'm replying or an original post . Yes I am trying to use the emoticons to the right, I click on them but no worky. Also clicking on the button to the left will bring up the latest non-read post but the cursor will not move the page up or down. If I go in clicking on the last page things work OK?? I'm using Bing for a search engine if that makes a difference.
Old Mar 18, 2014 | 03:10 AM
I'm a bit confused by all of this, but it sounds like something isn't right with your browser.
Which browser are you using?
Have you tried others, such as Firefox, Chrome, or Opera?
Bottom line: it's faster and easier to just type the code characters than clicking on an emoticon, so,
Code:
Code:
:D
Code:
:eek:
Code:
:rolleyes:
= , etc.
When in "Go Advanced" mode, you don't have the "Disable Smilies in Text" box checked, do you?
Old Mar 18, 2014 | 04:09 AM
allyolds68's Avatar
I have the same problem. I've gotten around it by right clicking on the Smilie, copying the property, and enclosing it in image tags. It's a PIA, but it works:
Old Mar 18, 2014 | 07:33 AM
I have to right click, copy and paste.
Old Mar 18, 2014 | 09:28 AM
380 Racer's Avatar
OK the copy/paste woks good for that . Thanks! Where do I look for a setting for the other problem? Do I just live with that?
Old Mar 18, 2014 | 09:46 AM
I don't have your second problem. I would go in and clear the cookies, history, etc and try again.
Old Mar 18, 2014 | 02:29 PM
txrob779's Avatar
The Noob Messiah
I learned to call them TRIGGERS :XXXXX: if you know the trigger just add colonWORDcolon
like : ): or :
or just this LOL
:rolleyes : or without spaces
Old Mar 18, 2014 | 03:31 PM
Macadoo's Avatar
It sounds like a plug-in isn't working. I use chrome and have to occasionally update the flash plugin, etc. Try a different browser or a newer version.
Old Mar 18, 2014 | 05:45 PM
380 Racer's Avatar
OK thanks....if this doesn't work , I'll just deal with it. Thanks guys.
Old Mar 28, 2014 | 03:32 PM
380 Racer's Avatar
AHA........the copy/paste works good. Now I found by clicking on the read first unread post (spelled out).. Then everything works as planned. Thanks guys.
Old Mar 28, 2014 | 03:42 PM
IE, I have to copy and paste, Firefox works fine, go figure. Glad your working with it.
Old Mar 28, 2014 | 07:36 PM
Lady72nRob71's Avatar
Let's see if firefox works by just clicking them...
Thats all!
Old Mar 28, 2014 | 07:42 PM
Smile Smilie title test....
Thats all!
Almost Dark Lord. Have to check all those smiles in the title frame too. Here, I'll start one for you
Yup, it works
Old Mar 29, 2014 | 08:03 PM
oldsguybry's Avatar
NOVICE car nut
I had to change the way I post them because they stopped working for me also . I use to just double click the one I wanted , and then for a short time I had to literally type the word in to get it to work . Now I can just drag it over lol
