Site Help Ask your questions here about how to use the site.
changing profile picture
Old May 11, 2020 | 05:25 PM
98 man's Avatar
I changed the pictures on my profile and avatar no matter what i do the images are upside down. Can you fix this for me?
Thanks Greg
Old May 11, 2020 | 05:43 PM
Thanks Greg
Hi John. I'm not a moderator and I'm not certain a moderator can change the orientation of the image you chose to use for your Avatar. I doubt it. Where is your image stored? If iPhone you can use the image software on your iPhone to ROTATE the orientation of the picture and then upload the image again. Or, whatever program you are using to view your image (PC, laptop, tablet, etc) you can change the orientation of the image by rotating the image a couple of times until it is right-side-up. Look carefully at your image in the program you're using, there should be some symbols showing a little counterclockwise/clockwise rotation button you click on. Rotate (change the orientation of the image) and upload it again.
Old May 11, 2020 | 05:48 PM
98 man's Avatar
I tried loading it on there normal and upside down and shows up up side down both ways. Picture looks normal when i select it.
John - I captured/saved your image to my PC then I rotated it to the correct orientation if that helps you any. You can download the image I just changed for you and then try to upload it again if that helps you.
Old May 11, 2020 | 05:50 PM
Charlie Jones's Avatar
Phantom Phixer
Copy this pic to your omputer , and use it for a profile ;
Old May 11, 2020 | 05:51 PM
You actually need to perform that rotation operation prior to uploading the image. Sometimes the manner in which you perform the rotation depending on the device you're using, will show it correctly orientated and then bam...it's upside down. Depending on the device and program you're using sometimes it seems like voodoo but you'll get it I'm sure.
Old May 11, 2020 | 05:57 PM
98 man's Avatar
Ok that worked, Thanks Guys!
Old May 11, 2020 | 05:58 PM
Glad you got it.
Old May 11, 2020 | 08:16 PM
Basically all I would have done is what the others did. Rotate it in my pc and then repost it. Glad you got it fixed.
78Cutlass4Speed
Site Suggestions
25
Mar 17, 2020 01:56 PM
Ctls442
Jun 27, 2015 09:11 PM
stellar
Site Help
Mar 19, 2012 02:31 PM
dynamic88
Jul 13, 2008 03:39 PM
