Silhouette air shocks
Old Jun 7, 2013 | 08:18 PM
musicars's Avatar
Has anyone replaced the rear air shocks in a Silhouette? I used the Monroe MA826 shocks in our '03. They looked identical to the rusted out ones I took out. They factory lines hooked up to them but the old lines were very difficult to remove because of the rust inside the fitting. I have no doubt I damaged them taking them out since there is a slight leak somewhere as the pump kicks in every few minutes. Unfortunately, the lines that come with the new shocks have the correct fitting on one end only. The other end uses a screw on compression type fitting. I'm think I may have to check with a dealer for hoses.
I do think I may be able to make a set by using two hose kits so I can get enough clip on ends and may try that this weekend.
Anybody dealt with this and have any tips?
Old Jun 8, 2013 | 03:47 AM
jensenracing77's Avatar
I replaced them on our Silhouette a couple years ago. The fittings came right out and threaded into the new shocks so I won't be much help. Does the parts store carry the line and fittings? I would think the line and fittings would be an easy find?
Old Jun 12, 2013 | 09:35 PM
musicars's Avatar
The lines the parts stores carry have the clip on end, which connects to the shocks, on one end and use compression type threaded fittings on the other end. The factory lines have clip on ends on both ends. It's AWD with the auto leveling system so maybe they are different.
flameorange
Silhouette
19
Dec 19, 2009 06:39 AM
Tucker442
Silhouette
15
Jun 27, 2009 02:44 PM
jensenracing77
Silhouette
Feb 25, 2009 04:03 PM
joe_padavano
Feb 17, 2009 03:01 PM
jimoreo
Apr 22, 2006 03:04 PM
