95 Silhouette
95 Silhouette
I have a 1995 Silhouette to haul my pre-school grandkids around in. Runs great. However the keyless remote fob has fallen apart. I came across another fob, but it needs to be programmed. Some instruction I got off the internet said to remove the glove box to get to a button to push. Took the glove box out...not able to find a button....anyone have any experience with a 95 Silhouette and keyless entry??
This may work for you its for a 97:
1. Remove key from ignition switch.
2. Remove the MALL PGM fuse, from fuse box
3. Close all doors.
4. Turn ignition switch to ACC.
5. Within 1 second turn the ignition switch to OFF then back to ACC
6. Open and close drivers door.
7. A chime will sound indicating you are in programming mode.
8. Press and hold the LOCK and UNLOCK buttons together on the remote until chime sounds twice,
about 14 seconds.
9. Repeat step 8 for any additional remotes.
10. Remove key from ignition and replace MALL PGM fuse.
11. Test remotes.
3. Close all doors.
about 14 seconds.
11. Test remotes.
joe_padavano
Feb 17, 2009 03:01 PM
