Wiper switch hookup
Old November 18th, 2017, 09:39 AM
drkearnel's Avatar
Wiper switch hookup
When I picked up my 64 Cutlass it didn’t have he wiper switch installed, I have now found the switch in a box of “extras” tha came with.
Issue is I’m not sure which wire goes where. I’ve attached a pic of the wires and switch if anyone can help.
I think this is a 2 speed switch? From what I can comprehend from wiring diagram and how the motor is hooked up, the white wire is the washer motor and the green and purple are for wipers
any help would be great!
drkearnel is offline
Old November 18th, 2017, 10:04 AM
Going off the wiring diagram. The green is the wiper, the white is the washer feed from the switch. The purple is fed from the fuse box to the wiper motor, and jumpers to the washer. The single terminal on the switch should connect to the metal of the switch body when the washer is engaged and there should be a ground wire terminal in the 2 wire plug. The schematic shows a single speed wiper motor. Don't know about the black wire, possibly the heater.
http://circuitswiring.com/circuit-di...-85-part-2.jpg
http://www.oldcarmanualproject.com/t...re5765-288.jpg
Old November 18th, 2017, 11:11 AM
drkearnel's Avatar
These switches are supposed have a ground wire? I thought they were grounded by the body when screwed in?
Which wire goes to which terminal on the switch?
the purple/black wire runs from the wiper motor through the firewall and is just loose with the green and white ones.
Old November 18th, 2017, 11:33 AM
Cincinnati Rick's Avatar
Yes... Like Eric said. The wiper motor and the washer pump are fed with a constant hot. When the switch for either the wipers or the washers is engaged, a ground signal is sent to the respective motors.
Cincinnati Rick is offline
Old November 18th, 2017, 01:00 PM
It looks like the single terminal is grounded to the body of the switch. According to the diagram the side by side connector should have a ground wire in it.
The white wire goes to the single terminal and the green in the side by side connector connects to the other 2.
Your going to have to verify that the purple/blk wire is in fact the one that goes to the motor. It should be hard wired in the fuse box.
Old November 21st, 2017, 09:37 AM
drkearnel's Avatar
Thanks for getting back. I'll double check on the purple/black wire when I get home and update.
Old November 21st, 2017, 10:06 AM
Which wiper motor do you have - square or round?
Old November 21st, 2017, 12:45 PM
drkearnel's Avatar
I honestly am not sure. It looks like a normal wiper motor to me haha It looks like this one below, if that helps.
Old November 21st, 2017, 01:08 PM
That is round. This is square:
Old November 21st, 2017, 01:15 PM
drkearnel's Avatar
Interesting, I'm new to the Olds scene, so that's news to me.
Yes I have the round wiper motor.
Old November 21st, 2017, 07:23 PM
drkearnel's Avatar
so I can confirm the purple/black wire goes from the wiper motor, through the firewall, and is hanging under the dash with the other wires right inside the wiper switch location.
the motor has the purple/black, a solid purple, and dark green
the washer pump has yellow and solid purple jumped from wiper motor.
crappy pic attached
Old November 28th, 2017, 04:39 AM
drkearnel's Avatar
So it looks like I have a third wire to the switch and motor that is not shownin the diagram.
Is is this because I have 2 speed wipers?
Old December 8th, 2017, 03:31 AM
drkearnel's Avatar
How would I bench test the wiper switch to make sure it is not at fault?
bigoldscruiser
August 7th, 2010 07:29 PM
oldolds51
May 2nd, 2010 11:34 AM
ELECMAN
September 28th, 2009 05:52 AM
macvic
March 27th, 2008 04:10 PM
silverriff
February 25th, 2008 06:10 PM
Quick Reply: Wiper switch hookup
