Title in my name,rear quarters have been replaced up to top of body,Doors NOT included. Motor matches title 350 but has not run in years, 350 turbo trans #do not match, has driveshaft,256 rear gear open,non boxed control arms,no gas tank unless you want the one I removed,dashboard with non cut out radio area,a few tabs broke off and bench seat,rear seat need work,column shift gauges and wiring included but not installed, column shift ,body bolts removed ready to lift off frame, disc brakes in front, has duel exhaust and trumpets but show wear. No bumpers,core support,radiator or front clip, trunk area not bad but small squares cut out above body bolts . Extra used front disc spindles ,calipers and rotors,extra steering box, windshield is good as well as frame around it, convertible top FRAME included as well as top motor,hoses and old cylinders, Bumper brackets,stock hood. Some patches on floor boards,driver and passenger, trunk gutter is good as well as areas under doors. cowl around V.I.N. is solid. $1500.00 O.B.O.
