72 Cutless Supreme Instrument Cluster
Old December 6th, 2016, 12:45 PM
dg110270's Avatar
I'm trying to help someone order an oil pressure/ water temp guage to put in place of the clock position that has a blank on it. We want one dual or one quad guage in that hole. What size hole is that? The car is not in town right now. It's being shipped. Who should I order the guage from. any help would be nice. Car is 72 Cutless Supreme.
dg110270 is offline
Old December 6th, 2016, 01:54 PM
A Sun Super Tach fits in the hole nicely and the online spec for the tach shows 3 3/8" diameter.
Fun71 is offline
Old December 6th, 2016, 02:51 PM
dg110270's Avatar
Thank you Fun71.
dg110270 is offline
Dave26's Avatar
Speedhut has a large variety of gauges in a number of sizes. As for size...get a car/dash, remove the bezel...take accurate measurements. Another option is the rally pack.......repops available from most of the parts houses (fuel/temp/pressure) made to fit(left of speedo)....will look like the speedo......a tach would fit in the clock opening....could get a (tic-toc-tach)
Dave26 is offline
Old December 7th, 2016, 02:17 PM
dg110270's Avatar
Thanks Dace26. I found a gauge at speed hut that may work. I hope 3.375" will fit the clock hole okay. What do you think?
dg110270 is offline
Old December 7th, 2016, 03:26 PM
Dave26's Avatar
I would take the bezel off and get an exact measurement before ordering.
Dave26 is offline
Old December 8th, 2016, 06:01 AM
Dave26's Avatar
These are the "rally pac" gauges. Available from most parts houses and will be an exact fit.
Dave26 is offline
Old December 9th, 2016, 06:43 AM
oddball's Avatar
Any common 3 3/8" gauge can be mounted to the gauge panel. It will be in FRONT of the panel, while the other gauges are BEHIND the panel. Doesn't look fantastic, but quick, cheap, easy.
With time and creativity you can fabricate a mounting ring that mounts in the stock place and holds an aftermarket gauge. Clearance with the gauge panel will be a challenge, but the gauge certainly can fit in there.
Rally pac is swanky, but there are wiring mods and $$$ that go along with that.
oddball is offline
Old December 9th, 2016, 03:06 PM
dg110270's Avatar
Thanks Oddball. I didn't know it would be sticking out in front of panel.
dg110270 is offline
Old December 9th, 2016, 03:46 PM
4speed455's Avatar
Autometer 3 3/8 tach mounted behind the panel. I modified a broken clock housing to make the mounting bracket.
4speed455 is offline
Old December 12th, 2016, 05:30 AM
dg110270's Avatar
dg110270 is offline
Old December 12th, 2016, 05:37 AM
dg110270's Avatar
The clock hole has a blank in it now 4speed455 so I may be able the use that blank bracket to mount the new gauge.
dg110270 is offline
Old December 12th, 2016, 07:32 AM
oddball's Avatar
This is what it looks like if you use the trim, itself, as the mounting ring.
Or you can fabricate something to mount the gauge to behind the trim, like an old clock.
oddball is offline
Old December 12th, 2016, 07:49 AM
dg110270's Avatar
What brand are those gauages Oddball?
dg110270 is offline
Old December 12th, 2016, 11:04 AM
oddball's Avatar
New Vintage, custom design to mimic rally pack. Crazy stupid expensive but very pretty.
oddball is offline
Old December 12th, 2016, 02:57 PM
dg110270's Avatar
They look great
dg110270 is offline
71 Cutlass
January 13th, 2017 09:35 AM
carnell71075
May 1st, 2010 07:37 PM
carnell71075
April 25th, 2010 05:52 PM
gglow
January 19th, 2010 03:31 PM
carnell71075
January 9th, 2010 02:34 PM
Quick Reply: 72 Cutless Supreme Instrument Cluster
