Wiring Diagram on how to install 8000 RPM tach in 71 cutlass
Old Jun 13, 2016 | 04:44 PM
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
I have an hei system. 71 olds cutlass supreme. i bought this tach without any wiring diagram. Any information would be helpful.
Old Jun 13, 2016 | 05:04 PM
Typically power, ground, tach signal and light.
Tach signal connects to the TACH terminal on the distributor.
Power and Ground should be self explanatory. You can typically find a switched power connection on the fuse box, such as the IGN terminal.
Light ties into your dash light wiring.
So you need to determine which of those spade terminals ais power and which is the tach input.
Old Jun 13, 2016 | 05:21 PM
So far i have the light wire to grey light wire from clock. i have the ground wire. the last two male terminals are what i need to know where pwr and tach wires plug up.
Old Jun 13, 2016 | 10:33 PM
smash72's Avatar
Smash
I have a Mallory set up which i can't find a terminal for a tach. Diagram reads tie tach wire (green if I remember correctly )to the neg side of the coil. Mine has a terminal block from neg coil mounted on the firewall which makes it easier. Will dig up and post that diagram. Going from memory Dash light/white tach wire, ground/blk tach wire, ignition/red tach wire, neg coil/ green tach wire
Old Jun 14, 2016 | 05:25 AM
Whats the worst that can happen if I incorrectly hook up tach and power wires?
Old Jun 14, 2016 | 06:12 AM
edzolz's Avatar
The smoke gets out. Smoke is what makes it work. Typically green is the tach signal wire, black is ground, red is power, and blue (or grey) is light.
Old Jun 14, 2016 | 06:34 AM
Perhaps contact the manufacturer? There aren't too many sources for that aftermarket Olds tach. The problem is that the ground and light terminals are obvious, but the two spade terminals are unlabeled. On will connect to power and one to the "-" terminal of the coil (or the TACH terminal of an HEI), but you don't know which is which.
Old Jun 14, 2016 | 09:42 AM
4speed455's Avatar
Looks like the tach that GM Sports Salvage sells. I would give them a call.
http://www.gmsports.com/content/1968...***-tachometer
Old Jun 14, 2016 | 12:48 PM
^^^this once the magic smoke has been released electronics never work again w out replacement parts.....
Old Jun 14, 2016 | 12:52 PM
I'm sure you know that it is being repro'd now... at least for cars on your side of the pond.
Old Jun 14, 2016 | 03:22 PM
Talked with GM Sports. They directed me to the guy who makes the tachs. He walked me through the install.
HonestDave
Sep 10, 2015 01:53 PM
Alex72cutty
Dec 25, 2014 06:58 PM
71-442
Jun 17, 2013 03:34 PM
Thor-HoG
Jun 12, 2012 01:28 PM
