Looking into getting an '83 custom cruiser
Old September 20th, 2018, 06:25 PM
Copper Nine Eight's Avatar
How does the backdoor/tailgate suppose to operate on an '83 custom cruiser? Does it open 2 ways or 3 way? Does the back window roll down?
Just for reference i will post the craigslist link
https://dallas.craigslist.org/ftw/ct...700119282.html
Copper Nine Eight is offline
Old September 20th, 2018, 06:29 PM
71 cutlass convertible
lshlsh2's Avatar
On my 85 it opened 2 ways and yes the window rolls down.
lshlsh2 is offline
Old September 20th, 2018, 06:55 PM
Thanks!
Old September 20th, 2018, 07:12 PM
Allan R's Avatar
Some additional info for you.
Allan R is offline
Old September 20th, 2018, 11:35 PM
NICE! I Appreciate that!
Old September 21st, 2018, 05:58 AM
All 1977-1990 Custom Cruisers (as well as all the other B-body wagons of that vintage) have a two-way tailgate. It opens as a door with the glass up, and as a tailgate with the glass down. The problem with these is that the bushings in the left side hinges wear and the heavy gate sags. As a result, the gate doesn't close quite all the way when you open it as a door. This prevents the safety interlock from engaging, which prevents the gate from being opened as a tailgate - the RH latches aren't fully engaged. This also causes the DOOR AJAR light to stay on, which is why many of these wagons have that bulb removed or the switch in the gate jumpered. You frequently have to slam the gate and even pull up on the outside handle when doing it to get the upper RH latch engaged all the way.
Old September 21st, 2018, 07:03 AM
jaunty75's Avatar
Can those bushings be replaced? Are they available?
jaunty75 is offline
Old September 21st, 2018, 07:25 AM
Can they be replaced? Sure.
Are they available? No, well certainly not for that specific application. I looked into this when I had mine. McMaster Carr has bronze bushings that are close, but you still need to do some machining on them to get them to fit. It's not a lot different than rebuilding door hinges, but the kits are not available.
Old September 21st, 2018, 07:28 AM
jaunty75's Avatar
Cool. Thanks.
jaunty75 is offline
Old September 21st, 2018, 10:13 AM
Thanks joe, just the info i needed!
classicmuscle442
September 21st, 2014 04:56 PM
tobywoodard
August 2nd, 2014 08:10 PM
tobywoodard
December 19th, 2012 01:36 PM
RSmith8
Cars Wanted
July 19th, 2012 10:16 AM
PalmSpringsOlds
Cars Wanted
24
January 3rd, 2011 12:11 PM
Quick Reply: Looking into getting an '83 custom cruiser
