1964 oldsmobile starfire parts
pm sent
sold 88 hood appear
sold wiper arms
sold 1 14" wheel...have 3 more
sold jack assembly
scrapped roof section
front suspension lot, still on frame 100
3.42 limited slip rear end complete 800
sold 88 hood appear
sold wiper arms
sold jack assembly
dedsleds do you have wheels 14 x 6 to fit 62 olds 88 need 2 , my e-mail is drimmer8@comcast.net
ok thanks , do have some one from are Olds cub giving me 2 tomorrow , getting new larger lugs , should work to get the car on the road , thanks for your time ,
Sold:
Brake booster
side marker set
air clean (painted 1)
wire loom lot
red console's lens... 50.00 minus tach for the rest of console
my last wiper motor
nos curved bumper filler
hood latches
1 timing chain cover
3.42 posi rear end
cowl loom cover
Brake booster
side marker set
wire loom lot
my last wiper motor
hood latches
3.42 posi rear end
cowl loom cover
THIS IS WHAT'S LEFT AS OF 6/1/15
6/1/15
solid bare doors 150.00/pr
complete working power window setup 450.00
complete convert/side glass set, softray, 300.00/set
COUPE 63-64 COUPE: INSIDE WINDOW TRIM LOT 100.00/LOT, DRIPRAIL TRIM LOT W/SEAL CHANNELS 50.00/LOT, DOOR SILL COVERS ABD PLATES LOT 30.00/ALL
bucket seat set, power, lt blue, overall good shape, with ok matching rear seat, coupe, 650.00
nice blue console w/tach, some pitting, shifter included, tach really looks nice, loom 250.00 obo
red console in worse shape, tach has pc broken off face, pitted, complete though 50.00(will part out)
nice complete dash out of coupe, MINUS HEADLIGHT SWITCH 185.00
starfire grill assembly 200.00
2DR HARD TOP FRONT WINDSHIELD softray, 250.00...with trim and seal
ok rear panel insert 20.00
l/r fenders that need work 100.00/pr (LT BLUE)
gas door 5.00
2 driveshafts w/slimjim yokes 35.00/ea
FRONT SUSPENSION PARTS 100/FOR lot (speedo cable/spindles/control arms)
GRILL INSERTS 20/BOX
STEERING COLUMN COVER 10.00
TAIL PANEL INSERT LETTER LOT, NOT COMPLETE 10.00
2 394 ENGINES:
1 lower compression 2brl engine, mostly complete 150.00/LOT
1 high compression 4brl, mostly complete, taken apart now 650.00 obo.....PACKAGE DEAL FOR BOTH?
6/1/15
gas door 5.00
2 394 ENGINES:
complete working power window setup 400.00
nice blue console w/tach, some pitting, shifter included, tach really looks nice, loom 200.00 obo
gas door 5.00
2 394 ENGINES:
gas door 5.00
2 394 ENGINES:
SCRAPPED DRIVESHAFTS
PARTED OUT 394S...SOLD MY LAST EXHAUST MAN SET, 4BRL CARB AND INTAKE, 1 ROTATING BLOCK ASSEMBLY
htr boxes, clean 125.00/pr
nice blue console w/tach, some pitting, SHIFTER INCLUDED tach really looks nice, loom 250.00 obo
red steering wheel 100.00
starfire grill assembly 180.00
l/r fender scoops 45.00/pr
1 upper fender trim pc 20.00
l/r fender extensions 25.00/pr
gas door 5.00
TIMING CHAIN COVER 85.00
HEADS (10.25) 150.00/PR
COMPLETE 2BRL SETUP 50.00
I THINK 2BRL HEADS 85.00
VALVE COVER SET 40.00
STARTER 20.00
FLEXPLATE 40.00
DISTRIBUTOR 15.00
PLUG WIRE HOLDER SET 25.00
CRANK/RODS/PISTONS 125.00
ALTERNATOR BRACKET , PULLEY, PS PUMP SET UP 150.00
PS PUMP BRACKET SET 15.00
VALLEY PAN 20.00
OIL FILTER HOUSING 10.00
ORIGINAL GOOD STARTER 20.00
UPPER RADIATOR SUPPORT BRACKETS 10.00/EA
2 HARRISON RADIATOR CORES 40.00/EA
FUEL PUMP PARTS BAG 10.00
394 BARE BLOCK, CRANK RODS PISTONS INCLUDED, 200.00
gas door 5.00
STARTER 20.00
FLEXPLATE 40.00
DISTRIBUTOR 15.00
VALLEY PAN 20.00
price drops
solid bare doors 90.00/pr
complete convert/side glass set, softray, 280.00/set
htr boxes, clean 85.00/pr
COUPE 63-64 COUPE: INSIDE LOT 100.00/LOT, DRIPRAIL TRIM LOT W/SEAL CHANNELS 50.00/LOT, DOOR SILL COVERS ABD PLATES LOT 30.00/ALL
nice blue console w/tach, some pitting, INCLUDED tach really looks nice, loom 200.00 obo
red steering wheel 80.00
2DR HARD TOP FRONT WINDSHIELD softray, 200.00...with trim and seal
gas door 5.00
STARTER 20.00
FLEXPLATE 40.00
DISTRIBUTOR 15.00
VALLEY PAN 20.00
gas door 5.00
STARTER 20.00
FLEXPLATE 40.00
DISTRIBUTOR 15.00
VALLEY PAN 20.00
this is what's left:
COMPLETE UNCUT DASH ASSEMBLY, BARE 25.00 PLUS SHIPPING
AM RADIO, POWERED UP, 45.00
UPPER DASH INSERT W/CLOCK, CLEAN 65.00
DASH INSERT SET W/GLOVEBOX, ASHTRAY, STEERING COLUMN COVER, LOOM 65.00
WIPER SWITCH 25.00 (UNTESTED)
IGNITION SWITCH W/KEY 35.00
HEATER CONTROLS W/CABLE 45.00
DASH PAD THAT NEEDS RESTO, GOOD FOAM, 25.00
SPEEDO CLUSTER FOR BUCKET SEAT CAR 55.00
starfire grill assembly 160.00
2DR HARD TOP FRONT WINDSHIELD softray, 160.00...with trim and seal
l/r fender scoops 35.00/pr
gas door 5.00
GOOD WIPER ARM SET, TRICO 30.00/PR
COMPLETE 2BRL CARB CORE 20.00
CARB LINKAGE 15.00
2BRL CARB AIR CLENAER 20.00
STARTER 20.00
FLEXPLATE 40.00
VALLEY PAN 20.00
THERMOSTAT HOUSING 10.00
394 BARE BLOCK, CRANK RODS PISTONS INCLUDED, 250.00
gas door 5.00
CARB LINKAGE 15.00
STARTER 20.00
FLEXPLATE 40.00
VALLEY PAN 20.00
#67
THIS IS WHAT'S LEFT FROM ANOTHER CAR I PARTED THIS WINTER: 7082209204 CELL
REMOTE FENDER MOUNT SIDE MIRROR, NEEDS RECHROMING 65.00
DASH PARTS LOT 100.00/ALL
FENDER PATCH PANELS, L/R 60.00/BOTH
GRILL AND BUMPER FILLER ASSEMBLY 125.00
A/C CONTROLLER UNIT 15.00
LOT IN LAST PIC 25.00
THAT'S ALL I HAVE LEFT!
#80
I need two exhaust hangers .
One front one near the muffler . Either side .
The rear one back by the bumper on driver side .
Condition of the rubber is not important . As long as the metal is solid .
