394 "Rocket" engine build
Old March 25th, 2018, 08:13 PM
Phantom Phixer
Charlie Jones's Avatar
Rods and pistons
I next installed the rest of the pistons and rods . Of note , on these engines is the orientation of the rods and pistons .
My forged pistons were non directional , but stock cast pistons will have either a letter "F" or a notch . This must always be toward the front .
In addition, the rods must be oriented so that the "spit hole " is aimed toward the center of the engine . When this hole aligns with the crank journal oil hole , it spurts a shot of oil toward the camshaft . Aiding lubrication of the cam .
Also of note are the rod bearings . They should have a notch in the bearing where the "spit hole " is .
The set of Sealed Power bearings I got didn't . I got a set of old stock bearings with the notch , but they were so "shelf worn" that I could only use half of them . That's just what I did , I used them in the rods , and used the Sealed Power bearings in the caps .
Then the clearance between the rods was checked with a feeler guage .
This is what it looked like all together ;
I then turned the crankshaft with an old " bending beam " torque wrench .
It took about 20 ft/lbs to turn it over .
Charlie Jones is offline
Old March 26th, 2018, 06:41 PM
Phantom Phixer
Next the flywheel was installed . I'm using a stock '63 Olds stick shift flywheel .
I needed bolts , and I discovered that Ford 351 flywheel bolts are the same .
I got a set of ARP 's from Jeg's .
Next I installed the timing cover ;
And water pump ;
Old March 27th, 2018, 06:21 AM
I love this build. Hardly anyone messes with the Gen 1 Olds V8 anymore, at least you plan on exploiting one of their strength's, a multiple carb intake. Should really move all that steel down the road.
olds 307 and 403 is offline
Old March 27th, 2018, 09:05 AM
TripDeuces's Avatar
20lbs to start it moving or keep it moving?
TripDeuces is offline
Old March 27th, 2018, 12:27 PM
Phantom Phixer
Maybe a little more to start it moving . The point is , that it hardly takes very much to turn it .
Old March 27th, 2018, 01:36 PM
TripDeuces's Avatar
Hehe, that was my point to but I'm thinking the other way. I think 20# is a lot. I know my rings probably have less tension than yours but mine was considerably less.
Old April 1st, 2018, 04:43 PM
Phantom Phixer
Next I cleaned up the oil pan with a wire brush . I DON'T like media blasting engine parts .
Then the windage tray had to be "massaged " to fit . It conflicted with space for the new oil pump relief .
The dipstick tube was installed Next the pan was installed , along with the filter mount and the lower bellhousing .
Finally , the bottom of the engine got a coat of "Ford Red " paint
Old April 1st, 2018, 08:18 PM
TripDeuces's Avatar
That looks great, nice work.
Old April 1st, 2018, 10:36 PM
chequenman's Avatar
I notice a three groove Harmonic Balancer. Does your Car have Air??
chequenman is offline
Old April 2nd, 2018, 09:00 AM
Phantom Phixer
Sure does , car was sold new in Alamogordo , New Mexico .
Old April 2nd, 2018, 09:42 AM
Don R.'s Avatar
Lookin' good - I never knew they used a windage tray on those engines.
Don R. is offline
Old April 3rd, 2018, 07:55 AM
chequenman's Avatar
Air Engine!!
You said at the beginning your car didn't come with an Engine but I noticed an Air Harmonic Balancer. Do you have all the other necessary parts to install on your new engine to have your Compressor and Thermatic fan all function together. There is a Carb that is specific if using it on an Air Engine. I've just gone through this maze of not having all the parts needed and had to track them down afterwards. Just askin'.
Old April 3rd, 2018, 12:18 PM
Phantom Phixer
The engine I got , fortunately , was also from an A/C car . I think I have everything to hook it up and make it work .
Old April 15th, 2018, 07:27 PM
Phantom Phixer
Now the top end
Time to update again .
There is an oil passage in the heads which supplies oil to the rocker shafts .
Make sure it's clean .
The rocker arm assemblies were next.
I found 16 NOS rockers and shafts . The arms and stands all slide off the shaft , except one stand (per side ) . This stand is retained by a pin , that can be removed by a drift punch thru a hole in the bottom side .
Next the heads and rockers were put on the block and torqued according the chart .
Old April 22nd, 2018, 09:37 PM
Phantom Phixer
Then the other head was installed ;
Here's a little trick I found to tell if the valve stems are too long or short .
After the valve gear is installed and the heads have been properly torqued .
Bar the engine over until #1 is in the firing position .
Twirl the pushrods between your thumb and forefinger . The rod should twirl very easily , but not have any "play" up and down.
Turn the crankshaft one quarter turn and check the next cylinder in the firing order . Repeat .
This well worn distributor is going to Everyday Performance in Granby , CT for a rebuild and re-curve .
Old April 22nd, 2018, 10:02 PM
Phantom Phixer
It's starting to look like an engine now . I poured assembly lube on the cam one more time , before installing the valley cover .
Then the top end was masked and painted .
My intent is to have the rocker covers chromed . But , in the meantime , just to see what it will look like , I painted te covers with some "chrome " paint from Ace Hardware .
Old April 23rd, 2018, 06:33 AM
KQQLCAT's Avatar
I just started to do this and I noticed that the engine block had plugs in some of the water passages and I noticed you did not replace them on yours. Did your machine shop say they weren't necessary? I looked at my shop manual and it shows how the water flows and they don't show water going threw the plugged areas. Just curious.
KQQLCAT is offline
Old April 23rd, 2018, 11:35 AM
  #58
Phantom Phixer
No they were all replaced . probably after the picture was taken .
The machine shop didn't install them , as they were already removed (by me) . And they weren't certain where they went . I did install six plugs under each head .
Old April 24th, 2018, 06:04 AM
  #59
KQQLCAT's Avatar
Good to know.
KQQLCAT is offline
Old April 24th, 2018, 08:34 AM
  #60
OLDSter Ralph's Avatar
Charlie, that engine is nearly a show piece now.
OLDSter Ralph is offline
Old April 24th, 2018, 04:20 PM
  #61
Phantom Phixer
Thanks , Ralph .
It's going to BE a showpiece for quite a while . I don't even have the body back on the frame !
Old April 25th, 2018, 07:04 AM
Charlie, I sent you a private message.
Ralph
Old April 25th, 2018, 12:18 PM
  #63
TripDeuces's Avatar
Never realized how close the architecture is on these and the 2nd gen? Olds engines. Nice detail
Old April 28th, 2018, 09:27 AM
  #64
KQQLCAT's Avatar
I wonder when they started to use a windage tray? They didn't have them on 61 or 62. Must of been 63 when they changed the oil pan. Still trying to figure out exactly what the difference is in the low compression and high compression heads. I know the valves are the same because the part numbers are the same and ports look the same side by side. Learning a lot here
KQQLCAT is offline
Old April 28th, 2018, 09:57 AM
  #65
Phantom Phixer
I wonder when they started to use a windage tray? They didn't have them on 61 or 62. Must of been 63 when the changed the oil pan. Still trying to figure out exactly what the difference is in the low compression and high compression heads. I know the valves are the same because the part numbers are the same and ports look the same side by side. Learning a lot here
in 1961 the Starfires got a special head with larger valves (#23)
All the rest got #20 heads . From 62 thru 64 all 394s got #23 heads .
The compression differences were made by the "dish" in the piston .
Old April 30th, 2018, 06:09 AM
  #66
KQQLCAT's Avatar
What book are you getting this info out of?
KQQLCAT is offline
Old April 30th, 2018, 07:09 AM
  #67
Phantom Phixer
The 1963 Oldsmobile Service Manual .
https://www.ebay.com/itm/1963-OLDSMO...ZTG5Ld&vxp=mtr
And the 1963 Oldsmobile Chassis Parts Catalog .
https://www.ebay.com/itm/1963-Oldsmo...Jaq-gw&vxp=mtr
Old May 13th, 2018, 05:12 PM
  #68
tunafish's Avatar
I am in the process of building my 1949 olds coupe with a 1962 394. If you want to run a roller cam without sleeving your lifter bores you can do what I did. There are no .921 hydraulic roller lifters with cross bar on the market. I got 6.2 or 6.5 GM diesel roller lifters and dog bones,with some machine work they look like they are going to work fine.
tunafish is offline
Old May 13th, 2018, 05:18 PM
  #69
TripDeuces's Avatar
Nice work around Tunafish
Old May 13th, 2018, 07:09 PM
  #70
What machine work ? Explain ?
Old May 13th, 2018, 08:25 PM
  #71
tunafish's Avatar
If you can find the dog bones out of a 350 gm diesel with a roller cam you only have to drill a hole in the center I could only find two of them. I got the dog bones on ebay out of a 6.2 gm diesel the problem is the lifters come out of the bore about .100 so you have to counter bore the back side of the dog bone so the lifter will clear. Then I made a plate to go on the bottom of the lifter bores to hold the dog bones down. That doesn't have to be tight you want the dog bones to be a little sloppy. You can see that in the pic. let me know if you need any more info. I have a lot of pic.
tunafish is offline
Old May 13th, 2018, 08:40 PM
  #72
tunafish's Avatar
So far all olds parts 1950 frame 1959 rear end 1959 front clip.
tunafish is offline
Old May 13th, 2018, 08:47 PM
  #73
Thanks, nice job. I might try something similar on a '57 371.
Old May 13th, 2018, 08:55 PM
  #74
tunafish's Avatar
I think the 1957 371 has .842 lifter bore you can find a lot of those roller lifters with cross bar..
tunafish is offline
Old May 13th, 2018, 09:03 PM
  #75
tunafish's Avatar
correction 1957 was the first year for the .921 lifter 1957 to 1964 371 and 394
tunafish is offline
Old June 18th, 2018, 12:08 PM
  #76
Phantom Phixer
Manifold
I finished bead blasting my intake , painted it and installed .
Old June 18th, 2018, 12:27 PM
  #77
TripDeuces's Avatar
I know it's just an engine but I could look at them forever. Sorta like the car show yesterday. Everything from a 1917 LaFrance fire engine to some more modern stuff.
Old July 1st, 2018, 05:09 PM
  #78
oldsmoboogie's Avatar
Awesome engine! I would love to have one of these some day. Is there a book you could recommend on these engines?
oldsmoboogie is offline
Old June 23rd, 2020, 03:11 PM
  #79
64Rocket's Avatar
well it is almost 2 years. I wonder what has gone on. Must be running or close to running. I hope all is well with the project.
Gene
64Rocket is offline
Old June 23rd, 2020, 03:39 PM
  #80
tunafish's Avatar
All done runs great
tunafish is offline
Quick Reply: 394 "Rocket" engine build
