What Year 394
Old March 30th, 2018, 07:31 AM
KQQLCAT's Avatar
What Year 394
How do I tell what year a 394 is?
Thank you,
Pat
KQQLCAT is offline
Old March 30th, 2018, 08:23 AM
Tedd Thompson's Avatar
If the heads are original to the block this will get you close.# 18 heads are 1959- 60, #20 heads are 61 unless it's a Starfire then its a #23, all the rest 62-64 are # 23 also including the Starfires....Tedd
Tedd Thompson is offline
Old March 30th, 2018, 08:32 AM
Phantom Phixer
Charlie Jones's Avatar
63 & 64 had an aluminum water pump and timing cover .
There is a number stamped on the left head that will tell you the year , HP rating , etc .
Should be above the center exhaust ports . Can be de-coded using various shop manuals .
All 394's had bolts on the edge of the valve covers . 59 & 60 371's had them also , but were 2 bbl carb .
59 & 60 's had smooth valve covers . 61 thru 64 had " ribbed " top covers .
Charlie Jones is offline
Old March 30th, 2018, 08:42 AM
KQQLCAT's Avatar
What would be the block casting number for 61 and 62?
KQQLCAT is offline
Old March 30th, 2018, 09:27 AM
KQQLCAT's Avatar
Ok I have been able to identify a 61 as 577476 and 62 as 582813. Can't find 63 or 64.
I thought we all should have this info.
KQQLCAT is offline
Old March 30th, 2018, 09:36 AM
Kyle's77cutlass's Avatar
Wasn't it just the 394 Starfire tat came with aluminum water pump and timing cover?
Kyle's77cutlass is offline
Old March 30th, 2018, 11:50 AM
Phantom Phixer
No , all 63 & 64's had aluminum timing cover / pump .
Old April 1st, 2018, 08:43 AM
Good to know. Thanks
Old April 1st, 2018, 09:51 AM
Phantom Phixer
My '63 is 585786 . '64 should be the same .
Old April 16th, 2018, 06:58 AM
KQQLCAT's Avatar
What is the difference between #20 and #23 heads?
KQQLCAT is offline
Old April 16th, 2018, 09:42 AM
Phantom Phixer
Valve sizes and bigger ports .
wr1970
March 29th, 2015 05:36 AM
greg pettit
June 4th, 2013 06:55 PM
boondocker
Non-Olds Engines
December 10th, 2011 06:06 AM
trackz man
December 13th, 2010 12:45 PM
mustj1
April 26th, 2007 04:50 AM
Quick Reply: What Year 394
