1972 Cutlass Hood Help
Had to remove my hood for a few months and finally went to put it back on today and things don’t look right.
I had four helpers place the hood back to its original position and have locked down with the two front bolts in their original position. However the back bolt hole of the hing leave about a 3/8 “ gap between hood and support. Are there suppose to be spacers or washers between the the two parts? Or do you just tighten down the bolts leaving a gap?
Advanced auto sells a variety pack of shims very similar to the original. Id have to assume you could get the same from Rock Auto. If you have a body supply near you they would definitely have them.
![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Hurst/Olds 73/74
September 24th, 2016 09:31 PM
guy.graziano
March 21st, 2012 09:32 AM
guy.graziano
December 5th, 2010 12:10 PM
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
