Rebuilding 350 - I'm in a pinch
Old February 21st, 2018, 06:32 AM
Joe King's Avatar
'72 block, Engine was rebuilt a years ago, briefly ran than pulled from car so he could install on air motor but he died before he could do it. A couple years later he sons sold it and then I picked it up. The engine was really clean and no wear marks on the bearings or cylinder but I decide to rebuild again before I put it in my car. I went off of the bearings that were installed previously when I ordered new bearings but when I installed the rods, the crank got tighter and harder to turn. I gapped all the rings and those clearances are good. Plasi gauge had my rod bearings at 0.0015. Is that to tight?
The rod bearing size is .030
Joe King is offline
Old February 21st, 2018, 06:41 AM
That is pretty tight. Did you try measuring with the old bearings?
Old February 21st, 2018, 06:46 AM
Joe King's Avatar
No I didn't and those are long gone. Any chance the .030 is to big ?
Joe King is offline
Old February 21st, 2018, 07:00 AM
Joe King's Avatar
I talked to my machine shop and they say it is good so I guess I am going to go work it.
Joe King is offline
Old February 21st, 2018, 07:47 AM
Yeah .030" is fine. What pistons were used in this build?
Old February 21st, 2018, 08:40 AM
Joe King's Avatar
.040 over, I think someone on here called them badger piston 2 or 6 cc dish. Really shallow dish, I can't post a pic of them
Joe King is offline
Old February 21st, 2018, 09:31 AM
TripDeuces's Avatar
Did you install the rods with the bearing offset toward the fillet side of the crankshaft?
I know some fillets are undercut but it's worth an ask.
TripDeuces is offline
Old February 21st, 2018, 09:44 AM
Be aware that the Badger pistons are short on compression height, so take that into consideration when you calculate the final compression ratio.
Fun71 is offline
Old February 21st, 2018, 09:58 AM
Joe King's Avatar
I have to be honest, I really have no idea this means but I greatly appreciate the help ��
I just measured and front deck to top of piston is coming up .055
Piston dish depth .077 by roughly 2.54. I hope to be okay on cr.
Joe King is offline
Old February 21st, 2018, 11:57 AM
I get 8.7 to 1 with 68cc heads and the Felpro gasket, .040" thick with a 4.230" gasket bore. Those should be the 6cc dish pistons.
https://www.uempistons.com/index.php...413bddeb82813f
Old February 21st, 2018, 12:14 PM
Yep, .077" deep dish is the 6cc version. They are what I have in my engine from the rebuild back in 1982.
The factory 6cc dish pistons were used in the 10.25:1 advertised compression ratio engines, but you see the above calculations using actual measurements that the final CR isn't anywhere near 10.25:1 - you would need to do some machining to either the heads or the block deck to bring it up with those short pistons.
Fun71 is offline
Old February 23rd, 2018, 10:48 AM
Old(s)GuysRule
67OAI's Avatar
I would recommend the thinnest head gasket available with that much deck clearance. Just my 2 cents!
67OAI is offline
Old February 23rd, 2018, 04:54 PM
If Smitty still sells the .011" shim head gaskets, they would be perfect.
Old February 26th, 2018, 02:24 PM
Joe King's Avatar
She is already put together, I'm putting the motor in a heavy Cadillac so she's not going to be a race car but HAS to be better than that tired ole 307 that is in it. I just have a few things to work out before i yank the old and drop in the new. Mostly figuring out what I need to keep to keep the ccc happy. I like my A/C, tcc and cruise control... losing ccc not really an option for me ��
I think Moroso should give their stickers with their name cut out, I love the look of the gold shooting out at you!
Joe King is offline
Old February 26th, 2018, 04:38 PM
AZ520's Avatar
Thats my kind of gold bling, nice! #8 heads ?
AZ520 is offline
Old February 26th, 2018, 05:24 PM
cutlassefi's Avatar
Where are you located?
cutlassefi is offline
Old February 26th, 2018, 07:15 PM
What cam? With unmilled #8 heads, which I have CC'd at 77 to 78 CC, that puts you right at 8 to 1. That oil pan is completely unnecessary with that mild build in a car that won't see high RPM. But it does look good.
Old February 27th, 2018, 05:13 AM
Joe King's Avatar
I have a previous post from late last year where I asked about which set of heads I should use, I have a set of virgin 7A (1972) or my #8 heads. These 8s have been milled, ported and the a valve grind. It was all completed and came with the original motor I purchased. From the responses I received the #8s would work just as well with the work done to them so I stayed with them. The oil pan was also mounted to the same motor so it didn't cost me anything extra. The original motor had a real wild cam and single plane Edelbrock intake so it was originally being built for some real power but to radical for my car. AS for the cam, it is an Edelbrock #3712. The best end of this thing has been balanced to, just another added bonus.
Cutlassefi, Central Florida- I live in Deltona, South of Daytona and North of Orlando
Joe King is offline
Old February 27th, 2018, 05:44 AM
Oh yeah, they were 73cc correct? That puts you around 8.3 to 1. That cam had 140 to 142 cranking psi with it 2 degrees advanced in my stock 76 350 which was around 7.8 or 7.9 to 1 stock. It should play well with even the 85 and up swirl port aggressive timing curve. I would run a G hanger and a CK or CV secondary rods to start in your Qjet.
Old February 27th, 2018, 06:04 AM
Joe King's Avatar
Man, I have been trying to research which secondary rods I was going to use. I checked yesterday and the current ones I have are the GREAT DD rods and an L hanger. I haven't decided if I was going to change the hanger but I guess it wouldn't hurt. I know currently I didn't think my secondary's were opening up but after seeing the specs of the DD I figured out why. I think the clue should have been that it is the LAST rod on the list (pg 153 Doug Roe Rochester book)
I probably can't blame the q-jet entirely, it is a tired 307 with 130k pushing around a big ole Cadillac Brougham.
Thanks again, this was literally one of the last things I was trying to work out.
Joe King is offline
Old February 27th, 2018, 11:23 AM
The CV rod was used on many smog 350's, nearly every carb I have pulled apart had them. Hangers were H through Q.
Old March 6th, 2018, 12:41 PM
Joe King's Avatar
On my 350 these are head bolts, but both sides of my 307 look like this. I can't imagine this is factory
Joe King is offline
Old March 6th, 2018, 07:26 PM
How in the hell does someone snap off half inch head bolts?
Old March 7th, 2018, 05:48 AM
brownbomber77's Avatar
The last 307 I pulled apart had one busted half way down the bolt.
brownbomber77 is offline
Old March 7th, 2018, 05:27 PM
cutlassefi's Avatar
So it had a Victor intake on it? Did you sell it or keep it?
Old March 7th, 2018, 05:31 PM
Joe King's Avatar
It had a brand new one on it and I sold it for super cheap, well maybe not super cheap but at the time I sold it I had no idea what it was worth. It sold on craigslist within 2 hours. That should have been my sign that it was to cheap.
Joe King is offline
Old March 8th, 2018, 10:59 AM
Joe King's Avatar
Let's talk knock sensor for a minute. I pulled it out of my 307 and at the same location on the 350 the port is a water drain but closed off completely on the 307. Is it okay to screw in the same location as the water port or is there a better suited place for it?
Joe King is offline
Old March 8th, 2018, 05:00 PM
Yes, that is what I did when I installed the knock sensor when I put an Olds 350 in my 94 Z71 running the factory TBI. Make sure you torque the sensor to the recommended value, the TBI was 11 ft/lbs.
Old March 8th, 2018, 06:17 PM
elB
elB's Avatar
I like this idea. I'm tempted to go this route on my car: the 307 has developed quite a rear main leak (puddles) and it's quite underpowered. Good luck with the install!
elB is offline
Old March 8th, 2018, 06:38 PM
Joe King's Avatar
Now that must be a sweet swap! Totally jealous over here. I did try to screw it in but it seemed liked the FAT part of the sensor scrapped the block before it was tight so I am having to rethink this... Maybe I will try again tomorrow.
Joe King is offline
Old March 8th, 2018, 07:57 PM
It was a sweet set up till it burnt to the ground, the circulating block heater shorted out. I think it was directly in the block, you could add a short piece of pipe and adapter but I guess that defeats the purpose. Post a pic of the sensor.
Old March 13th, 2018, 01:30 PM
Joe King's Avatar
Well dang, the alt bracket from my 307 mounted on a couple of studs from the head bolts that my 350 ARP bolts do not have... Curve ball has been thrown
Joe King is offline
Old March 13th, 2018, 06:10 PM
Unfortunately, it is stock or nothing for those bolts with the stud ends.
Old March 13th, 2018, 06:22 PM
Joe King's Avatar
Guess im'ah have to build 'er a new bracket. Hope the power steering bracket goes better since I plan on putting that one on in the car
Joe King is offline
Old March 14th, 2018, 06:13 AM
Weren't the Cadillac brackets unique or were they the same as the Delta 88/98?
Old March 14th, 2018, 06:00 PM
Joe King's Avatar
I mounted the alternator and power steering pump today and it looks like I have enough mounting points that I can do without that one bracket so that's what I'm gonna do
Joe King is offline
Old March 22nd, 2018, 07:18 AM
Joe King's Avatar
Oil Stuff
I have been doing a bunch of research and I think I hit a fork in the road. I have this 7quart oil pan and a lot of people like these so they can run 5 quarts of oil and keep the windage down. I liked that idea, I was about to go custom make a dipstick for this bad boy so it would really fill work 5 quarts (minus filter) but then I read that with a high volume oil pump, it is better to run 7 quarts because it can run dry? So I'm kind of stumped here. I finally dropped the motor in the car yesterday and my hope is to finish everything up and **** the neighbors of tomorrow for my break in start up. Can't take her for exhaust until she is running so possibly running straight headers unless I can squeeze a little room of the collector to Temp mount a muffler there but it is pretty tight.
Joe King is offline
Old March 23rd, 2018, 05:47 AM
I believe 6 quarts plus filter is the right amount to run in that pan. In your car, it will probably help extend oil changes slightly, unless you push high rpm, you will see no benefit. Part of the reason oil changes can be extended so much is because new cars use synthetic and hold 9 quarts! Add in much tighter and more consistent tolerances along with direct injection, super fast EFI, our old junk can't compete.
Old March 26th, 2018, 06:09 AM
Joe King's Avatar
Vacuum Hoses
So now I am onto the vacuum lines and I am deleting a bunch but not all. I do want to keep the prefer valve that goes to the canister. In keeping that, do I have to keep the ccv octopus thing also? I would rather delete it if it wouldn't hurt anything.
Edit: I just kept this thing. It looks like it there is a breather on the top of carb that should be hooked up and connects to it.
Joe King is offline
Old April 22nd, 2018, 06:27 PM
Joe King's Avatar
I have had trouble with this engine ever since I did my initial start up. Finally figured out the #8 heads that have had a ton of work to them had... Well, to much work to them. Valve seats were cut so far that the valve attends we're sticking out to day and someone actually cut them shorter just so the rockets would some what work but in 2 cylinders the valves didn't seal.
Needless to say I finally picked up a set of 7A heads that are bolt on ready and I am excited! The old heads had dual springs but the new one's have the own single springs which I think are better for my Camshaft anyways. So I guess I will pick up my old heads and pull the springs of and scrap the rest of them, I can't see putting another $600 in them just to get them back in shape. I'm still taking the new one's in to be double checked that they are ready to go.
On another note, I mic'd my fel-pro head gasket and it measured .045, I thought it got a little thinner than that. Maybe when installed it shrinks a little bit.
Joe King is offline
Quick Reply: Rebuilding 350 - I'm in a pinch
