Lookin for
Taillights
Mirrors
Visors
Front windshield pillar post trim
Passenger side rear topaccuator cover bracket
driver and passenger door outer window sweep trim
Door latches
Seat beat retractors(black)
actuator covers are on a top frame in my basement, door latches, i need to dig for.
I will wait untill I hear back from you to search for them. This is what I was able to find on the quick. Let me know if it helps.
I've parted 5 88's over the last couple of years, i have a convertible and a coupe on my property and parts on shelves. 2 th375 trannys, a running 350.
columns, instrument clusters, seat belts , etc.
bump
THESE 2 CARS ARE GONE' BUT I HAVE LOTS OF SMALL PARTS FROM THEM.
bump
I have a friend looking for a 1974 Delta 88 hood and rear quarter panels. If you know of any available, please let me know. I am assuming the quarters for the coupe and convert are different, can you confirm that?
Hello again, I have 3 hoods.
The quarters are different around the roof area. The rest is the same. They could be cut to fit. The quarters on the 76 have some rust, but are salvageable. I have a good quarter cut from a 74 4dr. Shipping these will be rediculous.
I will p/m you my ph #.
Thanks Jim
Thanks Jim
These cars in this post have been scrapped, I have saved a lot of good parts from them.
I have a 76 that I posted recently, The pictures of the black quarters are from that car. They aren't perfect. But better than most I have come across.
Reason: Add pix
Hi, just throwing my 2 cents in here but the '74 hood is not exactly the same as the '75 and '76. The '74 should have two hood springs while the '75 and '76 only have 1. Personally, I would have preferred if they kept the 2 springs but oh well.
Some of this stuff i have, some I do not.
drivers mirror yes
visors, red reproductions like new condition.
windshield pillar trim, do you need inside or outside, i have the chrome exterior trim, and the interior a pillar, white, and possibly a black pair.
seat belt retractors I should have in black.
door latches, please be more specific, but I should have them..
Too actuator brackets yes.
I have 74 tail lights, no 75's.
No on windows sweeps..
I will P/m you, my phone #.
I will post photos when we clarify which trim you need.
Thanks, Jim
Hi. I wanted to know if you have the inside window trim as well as the outside window trim with cowl? Also, i'm looking for a working top motor and bracket. I have a 1975 Delta 88 Royale.
Thanks.
