1970 Vista Cruiser Restoration
Old December 14th, 2017, 09:32 PM
gratsoy's Avatar
Just about everything has been sand-blasted now, and the frame has already been powder coated.
Currently the goal is getting any black parts blasted and ready so I can drop a huge load off at the powder coaters to be done all at once. Once I have the components back I will begin on getting the chasis rolling.
I snapped a few photos of the frame - absolutely amazing job. It almost looks like it was body worked with filler and blocked then painted!
This area was pretty rough before with some divets and spotting. Now its completely smooth and flawless. It's really impressive the work that the powder coaters did.
With the body blasted the true extent of the rust can be seen. A few weird spots were revealed. It seems like there was a bad window replacement at one point as the top of the dash was rotten!?
I also noticed that the previous owner had punched drain holes in spots all along the floor - which really wasn't necessary. Luckily this must have been recently as these holes didn't rust at all.
Rust repair along the rear windows has already begun. I should note that I am not responsible for any of the rust repair. Hell, if you put a gun to my head and told me to weld two pieces of metal together, I'd tell you to pull the trigger. The body man doing all the work is very talented and detail oriented, he's also been around long enough to know how the car was welded together from the factory and can replicate original style work. For the rear window area he has been busy fixing the rust as well as massaging the body in that area to fit the trim pieces perfectly.
Before
After.
gratsoy is offline
Old December 14th, 2017, 09:39 PM
gratsoy's Avatar
The fenders had the typical Olds rust, which was dealt with quickly.
There was also a serious gash on the floor behind the passenger side of the front seat. I have no idea what cause it but it is an actual wound. Someone must have run over something sharp. Some person patched it from the inside of the car (good welding on the patch, but a patch job non-the less). It will have to get cleaned up and fixed properly.
I'll have to grab some more photos of the body, another intersting area is right above the exhaust, on the rear driver's side wheel well is very swiss cheesed. Not terribly difficult of a fix, but it's not consistent with the other rust on the car. Who knows how that happened!
gratsoy is offline
Old December 15th, 2017, 04:21 AM
rand5204's Avatar
I just found this thread. Congratulations on a very cool car and a great project. Two tone paint was pretty uncommon by 1970 so the color combo is very unique. Once upon a time I had one with the same bottom color but with a white painted top. Same interior. That green must have been just about the single most popular VC color in those years. I can't even count how many I have seen over the years.
Good luck with the restoration!
rand5204 is offline
Old December 15th, 2017, 04:38 PM
oldspackrat's Avatar
You may have already thought of this but I would lay all my parts out that I am taking to the powder coater and take some good clear pictures and when you get everything back compare it to your picture to make sure everything is accounted for. I have heard many stories of stuff going missing.
oldspackrat is offline
Old December 15th, 2017, 04:42 PM
gratsoy's Avatar
Absolutely! The powder coaters we used to use managed to lose a part for my grandfathers '36 Cord. Then lost the replacement!
gratsoy is offline
Old December 15th, 2017, 08:28 PM
442crzy's Avatar
PM sent
442crzy is offline
Old December 16th, 2017, 01:09 PM
Great work! I think I have put my Vista back on the back burner again as mine is pretty bad. About your windshield/dash rust thru, I know mine is really bad. We got caught in a heavy rain and large bubbles were actually blowing out into the car! I think that metal is pretty thin, isn't it? I think they make repair panels. Can you talk your bodyman to come over to Michigan to help me??
Greg Rogers is offline
Old January 21st, 2018, 08:48 PM
gratsoy's Avatar
The metal is pretty thin in those areas, and I suspect a poor windshield replacement job was to blame too! As far as bodymen go, I'm not sharing! He's too busy with my car!
gratsoy is offline
Old January 21st, 2018, 08:56 PM
gratsoy's Avatar
Rust repairs are going steady, current estimate is 2 weeks until ready for primer.
I've been keeping busy with little jobs: removing the sound deadener from the roof pannels, blasting parts, hunting for parts (religiously checking the for sale section of this site, and shipping parts away for refurbishment.
Hopefully should get all the odds and ends powder coated soon, I'm itching to get the chasis to a "rolling chasis" state. One of the thing's I'm really struggling with is how to paint my SS rims! I think I might go gloss black...
A few small spots were fixed underneath the rear bumper.
The gash under the passenger floor is still in progress but should be invisible once done, thankfully! It looked absurd before.
Window area repairs are nearly complete too ( the car is upside down in these photos).
gratsoy is offline
Old January 21st, 2018, 08:58 PM
gratsoy's Avatar
All of the window repairs were done with the window trim close in hand. The car has essentially been fitted to the trim to the clearences are really tight.
I stopped by the glass shop the other day and the replacement windows are coming along. Sadly they made a mistake and ordered the wrong colour tint, so these windows will have to be used for test fitting and a new set in the proper color made.
gratsoy is offline
Old January 22nd, 2018, 07:24 AM
Very impressive!
Old January 24th, 2018, 07:36 PM
gratsoy's Avatar
Was going through some parts from Fusicks today and noticed some differences in the battery tray. Notice the extra holes and lack of tabs on the short edges. This is for 68-72 if I recall correctly so maybe different years use the other holes. Or maybe they're drains?
I've blasted the part with the intention of filling the holes and if possible welding on some tabs to replicate the original piece.
gratsoy is offline
Old January 25th, 2018, 08:40 AM
Gary
VC455's Avatar
The slotted holes are even oversized!
Sad and puzzling that vendors don't seem to understand that reproduction parts should match the originals. In most cases it would take no extra cost or effort to do so.
My experience with Corvette reproduction parts is much better. That indicates that if we return the parts or stop buying due to poor reviews, more accurate ones eventually emerge.
I recently returned a steering wheel adapter and horn button because of incorrect sizing and alignment. I got original parts from a member on this site and substituted them.
VC455 is offline
Old January 27th, 2018, 06:54 PM
gratsoy's Avatar
Does anyone have a photo of a good or restored DeLuxe steering wheel? I am sending some emails to a fellow, hoping to have mine recast but we aren't sure on what the correct colour for the insert is. To my knowledge it should be a silery colour, but to what extent? Was it grey-ish or more like it was trying to look shiney like chrome?
gratsoy is offline
Old January 29th, 2018, 09:32 AM
oldsmobiledave's Avatar
pic
This is the deluxe wheel in OldsAl's 1970 Cutlass W-31.
oldsmobiledave is offline
Old February 4th, 2018, 07:13 PM
gratsoy's Avatar
Thanks for the reference photo! Hopefully I can ship my wheel out soon. It's ok now, but I can see that it is starting to get bad.
All the metal work on the body is done and it's now getting sanded. Looks fantastic.
gratsoy is offline
Old February 4th, 2018, 07:19 PM
gratsoy's Avatar
I've also managed to finally secure about every accessory/factory option for a 1970 car that I wanted. With all of these options installed the car will be very "modern" which will make it very comfortable for a cruiser/road-trip car.
I also now have the finished roof glass. The tint is probably 98% perfect match, which is plenty. One of the things I was looking out for when trying to match the tint is that there's almost this subtle green tinge in the windows when you look out from inside the car, the new windows manage to capture this decently.
For now I've shoved them on the shelf, wrapped in foam and bubble wrap - I'm a little nervous to play around with them in fear of any damage. But when I have time I will fit test them and post up some photos.
I still need to investigate if I can etch them, the hopes is to get a stencil made with the original lettering from the factory windows and use that to make these new ones a perfect reproduction. But I am also comfortable with just installing as is, I'm just pleased not to have to install de-laminating windows on such a thorough restoration.
gratsoy is offline
Old February 5th, 2018, 05:53 AM
  #58
That really neat about the windows, are more available? I'd love to see pics of them when you put them in.
Old February 5th, 2018, 07:07 AM
  #59
Gary
VC455's Avatar
Garrett, the repairs were beautifully done. It now has beautiful bones, and contours much better than those from Fisher Body.
VC455 is offline
Old February 5th, 2018, 10:13 AM
  #60
VC455 can you please explain your signature. It reads Type O axle with Chevy 8.875" 4.10 gear. How is that possible? Are you sure that is not an old Richmond 4.10 gear set for the 3.08/3.23 type O?
Old February 5th, 2018, 11:44 AM
  #61
Gary
VC455's Avatar
My rear axle has a Chev 12-bolt ring gear that was drilled for attachment in my Type O.
VC455 is offline
Old February 5th, 2018, 02:09 PM
I'm still lost. The type O uses an 8.5" crown gear. The 12 bolt Chevy is 8.875". How does that work?
Old February 5th, 2018, 03:04 PM
  #63
costpenn's Avatar
I wonder how much more time is required to do a wagon to these specs over a coupe - it has to be at least 25% - let alone the increased difficulty in finding wagon specific parts. Excellent work - thank you for sharing.
If you could, would you list all those accessories/options you have acquired? Are any wagon only?
costpenn is offline
Old February 5th, 2018, 05:15 PM
  #64
dc2x4drvr's Avatar
Over the top, very nice body work, I’m subscribed!
dc2x4drvr is offline
Old February 6th, 2018, 08:17 AM
  #65
Gary
VC455's Avatar
Originally Posted by costpenn
Are any (options) wagon only?
The unique Vista and wagon options have to do with the configuration of these cars. There is nothing unique that would have application to sedans.
On the other hand, there are many sedan options unavailable on Wagons and Vistas such as SSII Wheels.
The unique options are
AA3 Chrome Roof Glass
AS4 Deluxe Rear Shoulder Belts (3rd seat)
B39 Floor Carpeting - Cargo Area
C28 Drop or Swing Tailgate
C51 Rear Window Air Deflector
V55 Luggage Carrier
VC455 is offline
Old February 6th, 2018, 08:42 PM
  #66
gratsoy's Avatar
Hi Greg,
I'm looking into having some sets made so offer on the site, they are hand-made. I had a glass shop in my area make them using the originals as guides. I'll have to verify that the fit is correct first, then I need to investigate the logistics of shipping glass across the continent. But, it's on my radar.
gratsoy is offline
Old February 6th, 2018, 08:47 PM
  #67
gratsoy's Avatar
Finding parts isn't that bad - to my surprise. A LOT of Vista's got parted out over the years .
Accessories/options are:
  • Power windows
  • Power locks
  • Power Bench
  • Tilt Column
  • 70 only AM/FM
  • 8 Track tape deck
  • Cruise control
None of these are wagon specific. I guess technically the windows/locks are, but they also might be identical to the 4-door set-up.
For Wagon specific, other than what has already been listed in VC555's reply, all I can think of is auxilary rear speaker. But, it's only wagon specific due to it's location, there's a similar option for cars. The drop/swing tailgate became standard in the later Vista's.
gratsoy is offline
Old February 7th, 2018, 12:45 AM
  #68
tcolt's Avatar
Hi Garrett
I wonder if it's worth making the Vista glass pieces a 1/4" bigger all around. They are notorious for leaking at the sealant which leads to rust. I noticed on my Vista that the overlap between the glass and the sealing lip easily could be a bit more....
I know it's probably not something that you need for your particular wagon, but I know that's what I would do if I had the glass reproduced.
tcolt is offline
Old February 11th, 2018, 12:39 PM
  #69
gratsoy's Avatar
Originally Posted by tcolt
Hi Garrett
That's an interesting thought, it wouldn't cause any clearance issues with the trim and trim clips?
gratsoy is offline
Old February 11th, 2018, 12:42 PM
  #70
gratsoy's Avatar
Has anyone ever pulled apart a cruise control turn signal? Below is a photo from google showing the black button missing from a '70 turn stalk. I need to disassemble mine for repairs and rechroming but I am unsure of how to remove the button properly.
gratsoy is offline
Old February 11th, 2018, 01:16 PM
  #71
tcolt's Avatar
I can't help with the cruise control, but concerning the Vista glass, it has as much as 1/2" clearance all around. If the idea makes sense one can easily look into it further, but since I'm not too far from installing my decent used glass (that's what I have for now), I have currently only been looking at how I'm going to control the height of the glass when I install it and the fit of the trim moldings to my rebuilt roof. The height of the glass is controlled by how much sealant is between the roof and the glass and how much I compress it. The added difficulty is that the gap / fit doesn't seem to be quite uniform around the opening.
tcolt is offline
Old February 11th, 2018, 06:43 PM
  #72
gratsoy's Avatar
Interesting, I'll investigate this when I test fit the windows.
In other news I diassembled the cruise stalk. The button just pulls off, but, I think it originally was glued and that the glue was weak/failed. I got mine apart with no issues.
The Fluted end of mine was loose, so I was able to push the harness in at the bottom of the stalk which shoved the button out of the end. Then I was able to gently pull the button off and de-solder the wires to the switch.
You can see that the end is in rough shape. I plan on ordering a non-cruise stalk from Fusick's to see if I can splice some of it onto my cruise stalk and have it rechromed.
Does anyone have experience with the Fusick turn signals? If theirs isn't a two piece with the plastic end like the originals then obviously my plan won't work.
gratsoy is offline
Old February 13th, 2018, 06:53 PM
  #73
gratsoy's Avatar
Took the bellows apart. I read on here that the 70 bellows is the same as one from an '81 XJ6, so I ordered the part. They're very similar, but I am not certain if the new one will work.
Perhaps the new one can stretch out and is just compressed because it's so fresh?
Does anyone have any ideas where to source the rivets for the Front Fender braces? Fusick's sells reproductions, but I'd like to powder coat the originals.
gratsoy is offline
Old March 9th, 2018, 09:30 PM
  #74
gratsoy's Avatar
Slowly making progress. Everything is back from powder coating so reassembly of the chasis should be taking place soon. Here's a quick pic of the Fusick's reproduction battery tray corrected to match the original after coating:
The body has been sanded down to 320, next step is to double check the lines and door fitment before paint.
gratsoy is offline
Old May 13th, 2018, 09:57 PM
  #75
gratsoy's Avatar
gratsoy is offline
Old May 13th, 2018, 09:58 PM
  #76
gratsoy's Avatar
gratsoy is offline
  #77
gratsoy's Avatar
These shocks are definitely getting painted black.
gratsoy is offline
Old May 13th, 2018, 10:02 PM
  #78
gratsoy's Avatar
Progress has been slow. I wasn't in the shop much at all this winter as I was up on the ski hills. Things are moving better now, most of the bushing have been installed and the frame is coming along. The current plan is to get it assembled so the body can be mated to check door gaps and fitment. This is also a good time for me to check the fit of my reproduction glass.
THEN finally paint.
The engine is apart too, just waiting on some more parts to trickle in courtesy of Mark Remmel
gratsoy is offline
Old May 13th, 2018, 10:26 PM
  #79
Aron Nance's Avatar
Extremely nice work!!!!!!
Aron Nance is offline
Old May 14th, 2018, 01:04 AM
  #80
tcolt's Avatar
It looks great! This is the fun part Garrett :-)...
tcolt is offline
Quick Reply: 1970 Vista Cruiser Restoration
