1957 Olds 371 4jet and transmission complete
A pull out of a 1957 88. 371cu in 4 jet, 4 barrel with transmission. All original including high capacity oil pan, dealer ARA air conditioner compressor and floor mount, air cleaner, exhaust manifolds, starter, .....everything under the hood. I can furnish pictures and video of it running prior to extraction.
1957 Olds 371 cu in 4 Jet
This is a complete engine/transmission and accessories from a 1 owner 1957 Olds 88. It ran on Oct 9, 2017 prior to removal. It is a 371 cu in with a 4jet Rochester carb. Comes with high capacity oil pan, air cleaner with original Oldsmobile Rocket decal, generator, starter, exhaust manifolds, oil breather, dipstick, transmission dipstick, dealer added ARA air conditioning compressor and under dash mount diffuser box, transmission linkage, throttle linkage. Engine has oil pump, fuel pump, distributor and cap, coil, starter and solenoid, heat riser valve, lower motor mount thermostat and neck. It needs a rebuild on the harmonic balancer. Other accessories are radiator and transmission cooler. Driver and pass air boxes.
Houston, TX 77379. Trying to imbed pictures and a video of it running.
It was on for $2750 OBO and buyer pays for shipping, but I had offers for transmission only and ancillary parts. There are over $2,000 if you just ordered some of the parts from the catalog. Needs new Harmonic balancer, but the old one is included for the core exchange. I am planning on re-listing after the holidays.
chevyking
May 31st, 2018 09:45 AM
