65 f85 rear trim
Old December 18th, 2017, 03:26 PM
slambert's Avatar
65 f85 rear trim
off 65 f85 driver quality 100 plus shipping call 423-335-4646 Bristol va
slambert is offline
Old July 16th, 2022, 07:39 PM
65droptop's Avatar
i thought i read somewhere about you cutting your trunk pan down in order to get it into place, but now i can't find it, was that a must? if you had to do it over again, would you leave one wheel well repair out to make it easier? i will be fitting the trunk itself tomorrow and i am considering leaving one side of the wheel well repair out, in order to get the pan in in one piece. i cut mine just like you did above the bead, using that as a guide for a straight line and definite where to cut on the new panel. i repaired both sides but have not welded them in to place yet. thanks as always for you assistance. since you literally just did, what i am doing, i truly appreciate you.
65droptop is offline
66trakpak
November 17th, 2014 03:53 PM
Lil runner
August 6th, 2014 11:36 PM
ey beck
February 19th, 2014 10:56 AM
at3reg98
June 18th, 2012 08:19 AM
JeremyTA
Wheels and Tires
May 10th, 2011 10:56 PM
Quick Reply: 65 f85 rear trim
