Olds 307 no spark
Olds 307 no spark
1985 olds delta 88 307
Spark plugs arent sparking. It cranks but wont cut on. Happened yesterday and randomly started running and stayed running. Happened again today but did not stay running. It ran for about 10 seconds.
what could be the problem? Thanks
Check cap and rotor to start. Make sure ghe center button on coil is also good. Resistance check the pick up coil and actual coil. Usually modules and coils just die. The pickbup coil can be flakey but can die out of the blue.
Cap, rotor, coil, ignition module, power source, pretty much anything in the ignition system. Systematic troubleshooting (and NOT replacing parts randomly) is you friend. Start by testing to see if you have power at the wire going into the BATT terminal on the HEI when the key is in START and RUN positions.
mthompson1951
November 5th, 2016 12:27 PM
stlregal
October 26th, 2010 08:45 AM
