Dr Olds Mileage Machine
Old Oct 8, 2017 | 06:58 AM
Picture Dr Olds in a Nursing Home. He is old and bitter and has become very cheap as well. Igor comes to visit every week,telling him he just finished the 80 442 W30, the last it's kind. Dr Olds snaps at him, "Why didn't you use the 403?". Igor apologises and knows the Dr is right, but GM cancelled it. He tells igor he has finally found a way to make the Baby Olds 260 somewhat driveable. He knew of GM's plan of an overdrive transmission the next year. Why not combine the 260 with forced air and small dual exhaust, the new 2004R and 3.42 gears. Surely GM would make a combo like this. Not choked exhaust, crappy 3spd andsuper tall gears. That would be painful to drive, I want a cheap to operate car that can beat a toddler on a tricycle at the stop light. Don't worry Dr, I am sure GM has the"Brain's" to build a car like that. Yes, Brain's!
Old Oct 8, 2017 | 07:01 AM
His Mileage Machine has come to life!
Old Oct 8, 2017 | 07:06 AM
Taking it on a 5 hour drive today, hoping for 25 mpg imperial.
Old Oct 8, 2017 | 07:23 AM
The good doctor would not have used a Ford hood scoop...
Old Oct 8, 2017 | 08:02 AM
OldsAl's Avatar
Now Joe that was funny!😎
Old Oct 8, 2017 | 10:30 AM
I know, it was cheap.
Old Oct 8, 2017 | 10:34 AM
You DO realize that the center of the hood is actually a LOW pressure area, right? There's a reason why Olds put the O.A.I. openings under the bumper, at the headlights, or at the very front edge of the scoop. Your "force air" setup is actually sucking air OUT of the carb.
Most factory musclecar hood scoops were completely ineffective or worse and were 99% optical only. The high pressure areas on a car are the front bumper/grille/leading edge of the hood and the base of the windshield.
Old Oct 8, 2017 | 11:33 AM
Oh know I am starving the Dualjet!��. I went in the front fenders with dual snorkel on the 70S. Sheesh, you guys are critical��. Either way it wasn't bad to drive 2 plus hours. My speedo is 10 km/hr slow, how much does it affect the odometer?
Old Oct 8, 2017 | 11:46 AM
At what speed? You need to figure out the percentage that it's off. The odo will be off by the same percentage.
Old Oct 8, 2017 | 01:31 PM
jaunty75's Avatar
If you have a GPS, you can check this yourself. See how much the odometer turns when you've gone 1 km according to the GPS.
By the way, how do you know the speedometer is slow? Did you check it against a GPS?
Old Oct 8, 2017 | 01:59 PM
Yes, I have a speedometer app. I am planning on running 225/70R14 tires in place of 235/60R14 tires. This trans had the brown gear vs the usual black one. Pulling the speedo bullet can be a bitch, picked the closet gear. It will be perfect with the taller tires. Plus even less rpm on the highway. I will report on the highway mileage. Thinking pretty good.
Old Oct 8, 2017 | 03:12 PM
Originally Posted by jaunty75
If you have a GPS,
GPS is for people who can't do math...
Find a stretch of highway with mile markers. Note the odometer when you pass the first mile (or KM) marker. Drive for a while (say 10 mi or 15 KM). Note the odo when you pass the last marker. Do the math. That's the percentage that your odo is off.
Old Oct 8, 2017 | 06:33 PM
It is 10 km/hr slow at 100 km/hr. According to my GPS odometer it is .25 slow in 1 km.
Old Oct 8, 2017 | 06:52 PM
It is way off. It showed I went 224 km. It is 215 km to get there. I went there and 3/4 of the way back. It should be 383 km. It used 41 liters, that means 26 mpg imperial averaging 100 km/hr or 60 mph. That means high 20 mpg in the summer with less wind. Awesome.
Old Oct 9, 2017 | 03:30 AM
Nice job!
Old Oct 9, 2017 | 07:33 AM
10 km/hr off at 100 is 10%.
.25 km out of 1 km is 25%.
It can't be both.
Old Oct 9, 2017 | 11:33 AM
zeeke's Avatar
Nonsense! I figured out mine out to old fashioned way, I blew past a highway cop at 65 and when he pulled me over he asked if there was any reason I was doing 75 in a 50. Did some math and came up with a difference of 10 MPH faster than the speedo is showing.
As for fuel economy I can't tell you that, my car has an awful problem with maintaining steady RPM's. Loose nut behind the wheel.
I like your ride though.
Old Oct 9, 2017 | 03:03 PM
Did I mention Senality?😊
Old Oct 9, 2017 | 03:08 PM
It can't be both.
It is 10 or maybe 11 km/hr slow according to the GPS. I agree the odemeter is confusing, it is more than one in 10 for sure. Next trip, probably in spring with the proper tires, I will go off the GPS odometer. Either goal reached, shooting for 30 mpg, should get awfully close.
Old Oct 9, 2017 | 03:12 PM
Lol every time we start talking cars at work I ask what kind of mpg does it it get doesn't matter if it's the dodge demon or mini clubman. The guy who drives a Honda always gives me the strangest looks!
Old Oct 9, 2017 | 04:29 PM
I don't worry about mileage. My "new" car can get over 20 in town (with someone else driving it, that is) but my last fill up was 16. It's just way too fun to spool the turbo and see the tach rapidly approaching the redline!
Old Oct 10, 2017 | 06:38 AM
This car does very well in town, acceleration and mileage for what it is. In the valley hills definitely needed to kick it down and the little 260 sounds like 6000 at it's 4000 rpm shift points. I wish I would kept my SP2P intake. A member on the G body forum with a swirl port 307 HO just got it rebuilt using the Performer manifold and Edelbrock 500 cfm carb. I told it was probably going to run like crap. He is smiling ear to ear driving it, so much more power. Maybe the smaller carb not overwhelming the tiny ports? I am tempted in swapping a Performer and primary tune from the Dualjet into a Quadrajet but a lot of work for questionable gain.
Old Oct 10, 2017 | 08:53 AM
Mike77's Avatar
I don't understand talk on this site about gas consumption. We drive "mostly" big
V-8 in big heavy cars built 40 years ago. If you want "good" fuel consumption go buy a Prius. The "classic" are made to put the pedal to the metal and have some fun!
Old Oct 10, 2017 | 08:59 AM
jaunty75's Avatar
Originally Posted by Mike77
I don't understand talk on this site about gas consumption. We drive "mostly" big V-8 in big heavy cars built 40 years ago. If you want "good" fuel consumption go buy a Prius. The "classic" are made to put the pedal to the metal and have some fun!
Thank you!
I occasionally get asked when I'm filling the tank on my '67 Delta 88 what kind of mileage the car gets. I always say, who the hell cares??? I tell them 2 or 3 miles per gallon on a good day when I'm going down hill with the wind at my back.
I put maybe 500 miles a year on the car. That's like 2 or 3 tanks of gas a year. I couldn't care less about mileage. You don't own a car like this because you're concerned about mileage. That's what the Honda Civic back home in the garage is for.
Old Oct 10, 2017 | 12:23 PM
Thank you!
LOL im joking w the lads at work between a BBO, late model muscle and a truck i typically end up w the worst mileage of all in the conversation
although i am impressed w the late model muscle cars mpgs in the low 20s while still providing tons of fun.
Took my BBO into work today and i know this being the second rt commute w it i need to fill the tank on the way home
Old Oct 10, 2017 | 05:45 PM
Yes, but....
Old Oct 10, 2017 | 05:48 PM
Thank you!
Yes but I got this 260 and needed to do something with it.
Old Oct 11, 2017 | 09:31 AM
Well, as long as you're doing a science project, make it rocket science, right?
Old Oct 11, 2017 | 09:35 AM
And you didn't have a boat?
Old Oct 11, 2017 | 04:46 PM
Yes I do but will wait till I want to permently sink it.
Old Oct 11, 2017 | 04:54 PM
Exactly, I would much rather have this little Olds 260 than a sbc. Anyone who says you lose one or maybe two mpg by switching to a 350 is FOS. I got 21 with the little 260/ TH350 and 2.78 gears in my 70S. I only got 19 mpg with the Olds 350/TH2004R and 2.78 with carb leaned right out in the 70S. Usual 10% Ethanol regular with the 260, non ethanol 91 premium with the 350, even making the gap biggef. The mpg in this last drive with the 88 CSC were non ethanol 91.
Old Oct 11, 2017 | 09:00 PM
mrw8i's Avatar
Last week my wife got 64 mpg in her Prius.
I got 7 mpg in my 73 Cutlass !!!!
Old Oct 11, 2017 | 09:51 PM
Impressive, suprised a Prius actually did that well. Hopefully there was much rubber burnt off for 7 mpg. I am hoping for 15+ mpg out of my 70S on the highway.
Old Oct 12, 2017 | 02:26 PM
I routinely get 300 horsepower out of my DD.
What does a Prius put down?
Old Oct 13, 2017 | 10:50 AM
damaged442's Avatar
You guys are wording it incorrectly. It's SMILES per gallon. In my case, when I am driving my cars, the smileage is very high!
72Cutlass
May 24, 2021 07:24 AM
Rocketowner
Nov 2, 2016 10:53 AM
Hurst/Olds
Feb 19, 2015 08:51 AM
Rocko442
Mar 26, 2012 06:58 PM
justin66756
Dec 8, 2009 09:02 AM
