1971 Cutlass hood hinge color?
Old September 14th, 2017, 03:55 PM
Powerm01's Avatar
Are these supposed to be body color or flat black?
Powerm01 is offline
Old September 14th, 2017, 04:12 PM
Mine have always been rust color.
I can't say what color they were originally, but I'm positive they were not body color.
Fun71 is online now
Old September 14th, 2017, 05:15 PM
stevengerard's Avatar
Zinc Chromate - a dull dark silver color.
stevengerard is offline
Old September 14th, 2017, 05:38 PM
My2nd 69 442's Avatar
I believe you will find that Zink Chromate is a light puke green color. Maybe you are thinking about Cadmium Plate which is a very flat "silverish" color
My2nd 69 442 is offline
Old September 14th, 2017, 05:50 PM
Allan R's Avatar
Is it for a concourse restoration or a nice show car. I painted mine satin black. Looks good, and as we know, black goes with everything.....
We're these even painted from the factory? Back then the norm was to replace a car every 3-4 years.
Allan R is offline
Old September 14th, 2017, 06:00 PM
classicmuscle442's Avatar
My '70 W30 has blue/gray hinges, car is nugget gold, interested to find out what's correct.
033
classicmuscle442 is offline
Old September 14th, 2017, 07:36 PM
Sorry, my bad they were Zinc Phosphate from the factory. Eastwood makes a Zinc Phosphate color - as close as you will get without re coated them with zinc phosphate - which you can do at home but a lot of work for basically the same look
http://www.eastwood.com/ew-zinc-phos...t/2/10281Z.htm
Which is a semi flat dark blue grey
Old September 14th, 2017, 07:56 PM
I think stevens right
heres a couple pics of some never used ones i got in aparts lot these have the fisher body stamp on them
https://classicoldsmobile.com/forums...2-cutlass.html
Old September 14th, 2017, 10:09 PM
Powerm01's Avatar
Zinc Phosphate
Thanks to all. Zinc Phosphate sounds good to me!!
I do agree with a good ol satin black does go with anything but Zinc Phosphate looks good too. I am trying to keep it stock looking. Maybe the hood hinges looking stock is just a little bit of OCD popping through for me.
Powerm01 is offline
Old September 15th, 2017, 06:12 AM
Rodney
cdrod's Avatar
Zinc Phosphate Paint
I've used the do-it-yourself phosphating kits, also called parkerizing kits. Although the color seemed to be correct, the finish was easily wiped off and and was greasy. I plated some nuts & bolts and had the grey stuff all over my hands just from handling the parts. I've had better success using Rustoleum Metalic spray can paint (see pic).
The "Dark Steel" color is a close match for zinc phosphate. "Flat Antique Nickel" is also a good choice for bare steel looking parts. All can be purchased at Home Depot.
cdrod is offline
Old September 15th, 2017, 06:38 AM
442Fred's Avatar
The hinges are natural not painted, coated or phosphated that is why Fun71 says his are rust colored.
442Fred is offline
Old September 15th, 2017, 07:29 AM
Randy C.
rcorrigan5's Avatar
I believe the hood hinges all through those years were a dark grey color. Here is a '68 hood hinge I "restored" a few years ago. I knew the original color on it was a dark grey but the spring was a slightly lighter color. What I did was remove the spring from the hinge, bead blast both, and then paint the hinge cast metal gray and the spring a color called "stainless steel". It turned out pretty good, I think. And that's what I did for both my '68 and '69 cars. They've been restored for several years now and still look brand new. If you don't want to spend the extra money for the true, actual finish, doing it this way is an economical option.
Randy C.
rcorrigan5 is offline
Old September 15th, 2017, 07:46 AM
jharsh's Avatar
Randy C.
Randy,
Do you remember the brand name for the paint?
Thanks,
jharsh is offline
Old September 15th, 2017, 08:02 AM
mrolds69's Avatar
X2 with Steven, hinges were grey phospate and not natural. Very few items on these cars were natural, the things that were, usually had some kind of coating so they would not rust for a while. If you looked under the hood, they didn't want you to see rust at the dealership. I don't think they cared how long it lasted, though. A few other things that come to mind are the master cylinder and the auto trans pans. They were "natural" but both had something on them.
mrolds69 is offline
Old September 15th, 2017, 08:27 AM
Rocketbrian's Avatar
Grey phosphate is correct. I can't remember if I did mine with grey phosphate or cast iron grey. The springs I just wire wheeled and sprayed with satin clear. The grey phosphate I have used is also from Eastwood.
Rocketbrian is offline
Old September 15th, 2017, 09:00 AM
davebw31's Avatar
Like 442FRED said, natural. They were "washed" with an anti-rust inhibitor which did not last to long. Depending on how well they were done the "wash" lasted 6 months to a year. I installed an NOS set on my 70 F85 W31 and they are just now starting to show signs of some flash rust.
davebw31 is offline
Old September 15th, 2017, 10:45 AM
mrolds69's Avatar
Call it semantics, but "washed" with chemicals or coated is not natural. I suppose if you trailer everywhere, natural is ok. I drive my cars like 2-3K a year in driving rain sometimes to shows, if they were natural, personally...I prefer something on them.
mrolds69 is offline
Old September 15th, 2017, 12:04 PM
tangokilo's Avatar
Parkerizing, bonderizing, phosphating, or phosphatizing is a method of protecting a steel surface from corrosion and increasing its resistance to wear through the application of a chemical phosphate conversion coating. - Definition from google. This finish can range from jet black to grey and can be clear. This is the same finish used on US Military weapons like the M1 Garand. M1's often look green due aging in cosmoline. Gun smiths can apply this type of finish and you can buy kits from Brownells. Tom
tangokilo is offline
Old September 15th, 2017, 01:58 PM
442Fred's Avatar
Ok so they were washed with a rust inhibitor but it did not change the color of the hinge.
My suggestion is paint them which ever color you want it won't be correct.
Cast blast also looks like phosphate if you are so inclined
Just trying to help with correct info.
442Fred is offline
Old September 15th, 2017, 03:39 PM
davebw31's Avatar
the outside manufacturer put just a very light coat to keep assembled parts from flashing rushing. my nos hinges were poorly covered and you could clearly see bare metal. I think gray phos. is the best coating and the best match. thinking of doing mine gray phos as they are getting funkie looking. also considering a wash of the hinges using an acid based product that removes light rust and coats them.
davebw31 is offline
RetroRanger
December 15th, 2018 05:28 AM
Gearhead442
Paint
October 23rd, 2011 06:07 PM
sx455raidercelticfan
July 11th, 2010 08:36 PM
sebastien
Body work
May 17th, 2010 01:51 PM
Quick Reply: 1971 Cutlass hood hinge color?
