Pegging the meter...
Old September 13th, 2017, 09:13 AM
For your amusement:
https://jacksonville.craigslist.org/...277543865.html
Old September 13th, 2017, 09:24 AM
TripDeuces's Avatar
What in the Olds line up had a 110" wheelbase out of curiosity?
TripDeuces is offline
Old September 13th, 2017, 09:30 AM
None of them, obviously. The 2drs would have had a 112" wheelbase. Given how much other incorrect info is in that ad, I don't have a lot of confidence that the seller can drive a tape measure. In any case, if someone cut and welded a VC frame, you can make the wheelbase whatever you want.
Obviously this started life as a Supreme that has had a Vista roof and back end grafted onto it. It even still has the Supreme grills. If someone swapped the VC VIN tag, then yes it will decode to a Vista. Wow, that's a resounding proof. He cleverly doesn't include a side shot in the ad - I'm guessing the bodywork is less than stellar. The ad copy made coffee come out my nose.
Old September 13th, 2017, 09:53 AM
Rocketguy's Avatar
Great one Joe. He contradicts himself as he goes.
I wonder though how one can still call lit a Vista Cruiser; it's now more a hatchback or camback.
Rocketguy is offline
Old September 13th, 2017, 09:58 AM
VI Cutty's Avatar
Talked about here a few years ago, maybe not this one but a couple others built the same. I wonder if this is the source of his "research".
https://classicoldsmobile.com/forums...er-2-door.html
VI Cutty is offline
Old September 13th, 2017, 10:09 AM
It appears to be this same car from 2010 with the now-mandatory repro W25 hood. The article even has the same BS story. I've heard lots of similar undocumented stories over the last four decades. Let's just say that real Olds showcars and styling exercises have been documented and can be found on the web. There is not one scrap of proof to back up the story on this car. Frankly, Olds would not have force-fit non-compatible body lines like the Supreme back windows if the factory were actually building a styling exercise or showcar. Clearly this was cobbled by someone using existing sheet metal.
http://hooniverse.com/2010/03/07/wel...vista-cruiser/
Old September 13th, 2017, 11:36 AM
Allan R's Avatar
......... It even still has the Supreme grills.
I agree with everything you've stated except this point of clarification. 72 Vista Cruiser used exactly the same grills as the CS
BTW, this is around the 4th or 5th alleged '2 door OEM Vista Cruiser' claimed to exist. The one that looks the nicest IMO is this one that keeps the proper rear quarter lines:
Allan R is offline
Old September 13th, 2017, 12:42 PM
The car in question is a 1970. 1970 Vistas uses Cutlass (not Supreme) grilles - despite the fact that today they all have 442 grills and W25 hoods. I must say, however, that in one photo the car appears to have Cutlass grills and in another it appears to have Supreme grills. It also looks like it has been apart and back together and painted a few times.
Old September 13th, 2017, 01:51 PM
Allan R's Avatar
oops, eye check.... sorry boutdat!
Allan R is offline
Old September 13th, 2017, 03:50 PM
Yup looks pretty much like the black one. I do love the Earl Scheib paint job on the engine.
Old September 13th, 2017, 03:57 PM
Note that they even have the same trim clip or whatever that is at the bottom of the front fender below the Vista emblem.
Old September 13th, 2017, 04:24 PM
The front marker light lens was changed. Whats on the rear of the roof of the black one?
Old September 13th, 2017, 04:32 PM
Appears to be a piece of cardboard, or maybe an interior panel.
Old September 14th, 2017, 04:29 AM
Professur's Avatar
Be honest Joe ... would you turn it away if someone gave it to you, or would you drive it anyhow? I'd drive it.
Professur is offline
Old September 14th, 2017, 05:04 AM
Old School Olds
tru-blue 442's Avatar
https://postimg.org/image/44l5h9npn/
I would drive this one. Tastefully done except for the fender emblem.
Thanks for the pic Allan. It would be cool to find more info on it. 455, buckets and a console w/air. Now that would be sweet.
tru-blue 442 is online now
Old September 14th, 2017, 05:25 AM
toymobile's Avatar
I live about 40 miles from the car, could check it out if anyone is interested??
Johnny
toymobile is offline
Old September 14th, 2017, 06:43 AM
oldspackrat's Avatar
I have seen this car online for several years, off & on. I would like to see it in person to see how good/bad the conversion was. Also I've never seen any pictures of the rear seats or interior area other than the dash. I'd like to see the tail gate area, B & C pillars, etc...
Johnny,
I don't expect you to take the trip just for me but if you're in the area can you get pix?
oldspackrat is offline
Old September 14th, 2017, 10:48 AM
toymobile's Avatar
Johnny,
Not a problem, I drove by Tuesday on the return home from the CAIN.
Johnny
AzMotorhead
June 2nd, 2016 02:30 PM
Fear Reborn
November 30th, 2011 03:50 PM
69442murph
November 12th, 2011 08:45 PM
Allan R
August 17th, 2011 02:14 PM
Bobac455
May 11th, 2010 07:36 AM
Quick Reply: Pegging the meter...
