TH400 Re&Re with long tube headers
Old August 12th, 2017, 11:07 AM
HeavyOlds's Avatar
Have any of you ever removed a TH400 out of a 66 Cutlass with long tube headers in place? It's a real pain to remove either header. The widest part on the transmission is where the torque converter dust cover bolts on. Making it 1/2" too wide to drop between the headers. I'm thinking maybe tilting the transmission sideways might work.
HeavyOlds is offline
Old August 12th, 2017, 01:46 PM
You will probably need to at least loosen them and disconnect the collector joint so they can swing back and forth.
Old August 12th, 2017, 04:33 PM
HeavyOlds's Avatar
I may have to do that. I think even if I loosen it I might not get enough movement. I found a good deal on a high lift transmission jack. I machined an adapter so I can use the two axis swivel mount that came with it on my floor jack. We will see if I can use this to get around the headers. Wish me luck.
Old August 15th, 2017, 09:15 PM
HeavyOlds's Avatar
My idea actually worked. I was sceptical that it would. I was able to tilt the transmission down on the passenger side by 2" and up on the driver side by 2". It easily slipped through between the headers without touching them. The headers end exhaust are actually holding the engine from tilting back. The transmission is actually widest at 19" where the dust cover bolts on at the front. At this point at the header the width is 18". This saved a ton of work and worth the $100 usd I paid for the transmission jack. You know how headers can be.
Old August 21st, 2017, 11:26 PM
HeavyOlds's Avatar
Headers 1" narrower than the TH400.
Tilting the transmission did the trick.
69CulassConvertible
June 16th, 2016 08:47 AM
Octania
December 9th, 2013 09:37 AM
Octania
November 2nd, 2013 04:27 PM
1k442
February 6th, 2013 02:16 AM
442much
January 30th, 2009 04:58 PM
Quick Reply: TH400 Re&Re with long tube headers
