Looking for stock parts for 455 396021F
Old May 23rd, 2017, 07:40 PM
jpayne_80@hotmail.com's Avatar
Hi, Y'all!
I am a newbie here and have been reading a lot about the 455 for the past week. I bought a 455 to put in to my '64 c10. I got the engine dirt cheap, knowing it needed some work. I do not plan on building it for hi performance, just to get it running good and strong. The block looks to be good and the top of the pistons have 30 stamped on them (assume they it has been bored 30 over)
After getting in to the engine it looks like I will need a few things, stock parts are fine:
1. a new set of heads or at least just the passenger side head (can be bare)
2. Possibly an intake manifold (may be able to save it by cleaning real well)
3. Working/rebuildable 4bbl. It did come with the adapter plate to fit other (non Qjet) carbs
4. Probably more as I get into the bottom end. I don't have an engine stand yet.
I live in SW Missouri, zip code is 65745. If you have any of the needed parts lying around and they are in good condition please let me know.
I'll be more than happy to give you my number to text me. I live in the boonies and texts get through better than calls.
Although 36 years old I am new to the engine world, but I have always loved old cars/trucks. And the bigger the engine the better!
Thanks!
Jeff
jpayne_80@hotmail.com is offline
Old May 23rd, 2017, 08:45 PM
Olds Fever
CRUZN 66's Avatar
Welcome again... Looks like a nice ride for that 455 to find a home... Good luck with the project... I think you might have some luck finding the parts you need here on the site...
CRUZN 66 is offline
Old May 24th, 2017, 05:12 AM
What is the casting number of the heads you have now? Obviously if you get only one head, you want it to match.
The stock cast iron intake will clean up fine with a sandblaster.
Old May 24th, 2017, 05:17 AM
oldspackrat's Avatar
I have one bare letter C head here in Indianapolis along with a 4 barrel intake if you need any of those parts.
oldspackrat is offline
Old May 24th, 2017, 05:49 AM
ROCKETMAN269V's Avatar
stock parts for 455
First of all, Welcome to the site. It looks like a "J" head in the picture. I would retrofit some earlier heads, like "E", for a little better performance, since you need one anyway. Are the pistons stock type low compression? See if you can read a part# on top of the piston. That's a nice looking truck that you have. Good Luck! with your project. Bob.
ROCKETMAN269V is offline
Old May 24th, 2017, 07:50 AM
442crzy's Avatar
PM sent
442crzy is offline
Old May 24th, 2017, 11:26 AM
Yep, J heads. I will get the code on the current head as mentioned above and post on here. I know the heads are going to be heavy so shipping will be killer.
Also, are the stock exhaust manifolds ok to run? The crossover pipe has been pinched and welded closed. I've seen a lot of long tube headers online but they look like they'd hang real low.
Old May 24th, 2017, 11:37 AM
Why wouldn't the stock manifolds be ok to run? There were millions of Oldsmobiles built with them.
If you must have headers, Sanderson sells center dump shorty headers for the Olds 350 and 455. The only difference between the two is pips diameter (1 5/8" vs. 1 7/8"). They also make shorty rear dump headers, but only in the 1 5/8" tube size.
Old May 24th, 2017, 11:42 AM
I worded that wrong. Are they ok with the pinched/welded crossover tube?
Old May 24th, 2017, 11:51 AM
I'm not sure what "pinched/welded" really means. The factory just used a flat cap on the passenger side crossover port. Many people fabricate an equivalent cap by cutting the end off the crossover and welding a round piece of plate over it, as seen in the last photo.
Old May 24th, 2017, 11:55 AM
That makes sense. A previous owner of my 455 looks to have cut the crossover tube about 6" from the flange, pinched the tube shut, and welded it. Not the best look but should work the same.
Old May 24th, 2017, 01:14 PM
MOTORHEAD
11971four4two's Avatar
Custom
I lurk in the midwest minnesota mostly
I do have some parts
Nothing good is free
Have a great day
11971four4two is online now
Old May 24th, 2017, 01:30 PM
Custom
Have a great day
I don't expect anything to be free; not looking for handouts.
Old May 24th, 2017, 01:42 PM
MOTORHEAD
shipping Ping
Are you in lower 48???
What do desire???
seems like pound of ship
Equals $$$$$
come on over
I seem to have too much iron
again
Have a safe trip
Old May 24th, 2017, 03:25 PM
wr1970's Avatar
I am near Wichita . I have a set of E heads and a stock 4 barrel intake. Also have the turkey tray never been used. PM me with your cell # if you are interested.
wr1970 is offline
Old May 24th, 2017, 03:58 PM
Here is a picture of a piston. You can barely see a 30 stamped on it.
Old May 24th, 2017, 08:20 PM
MOTORHEAD
cool beans
not hp
Old May 24th, 2017, 08:24 PM
MOTORHEAD
[QUOTE=wr1970;1017640]I am near Wichita . I have a set of E heads and a stock 4 barrel intake. Also have the turkey tray never been used. PM me with your cell # if you are interested.[/QU
I am going to
Wichita??? kansas
here we go again
Old May 24th, 2017, 09:23 PM
MOTORHEAD
Old May 24th, 2017, 09:26 PM
MOTORHEAD
race gas station is only 4.42 away
Old May 24th, 2017, 09:35 PM
MOTORHEAD
standard
Marx3
May 1st, 2015 12:13 AM
delta254
December 3rd, 2012 08:37 AM
gearheads78
February 29th, 2012 08:11 PM
oldscruiser
February 15th, 2011 12:44 AM
ZASX
December 13th, 2007 12:38 PM
Quick Reply: Looking for stock parts for 455 396021F
