street cars that go to the track.
Old Nov 13, 2013 | 07:33 PM
charlierogers's Avatar
was wondering how many guys bring there cars to the dragstrip? what kind of numbers are you running and what cubic inch? not talking about stripped down race cars with plates, real street cars. any 11 sec olds out there?
Charlie,,,
Old Nov 13, 2013 | 08:28 PM
oldsmobiledave's Avatar
I do as often as possible. Although my race only car is faster my street car is no slouch. 1987 442. 470 cid SBO based on a diesel block with Edelbrock heads & a flat tappet cam (no roller). Trans is a T400 & Ford 9" sporting 3.89 gears. The car has 4 wheel disc brakes with hydroboost. Car's best run this summer with only a foot brake was 11.33 @ 116.5 mph with a 1.52 60' on a 255 60 15 MT Drag Radial. Better still this was at a corrected altitude of 5350'. The car weighs 3850 with driver. Applying the accepted NHRA correction factor for my track to the time slip has it corrected to 11.09 @ 118.8 mph at sea level. This is a true VIN 9 1987 442. Two tone paint was not re-sprayed after a theft recovery in the 90s.
Old Nov 13, 2013 | 08:36 PM
Octania's Avatar
My '85 is easily in the 10's or better
Oh yah it's an eighth mile track
Old Nov 13, 2013 | 09:02 PM
dave, those are some great numbers. I am guessing it is n.a motor as you did not say anything about spray. that's also the biggest olds smallblock I have heard of. is this a pump gas motor? if so this is a great example of a street car imo! I bet you have a lot of track time and tuning to get those times. do you mind me asking how much you have in the motor {ballpark}?
Charlie,,,
Old Nov 13, 2013 | 09:13 PM
details
The engine has 11.2:1 compression. Bored 1980 diesel block. Stroked 425 crank. Edelbrock heads with a Victor intake, an 850 AED carb on a 1" spacer & a 0.550ish" lift flat tappet cam. Headers are American Racer with a 3" exhaust. I run on 94 Octane pump gas with 34 deg of timing & no spray thru the mufflers leaving on the foot brake. Converter is a 10" 3500 stall. To duplicate the engine from carb to pan would run about $12K. Plenty of more $ in the headers, converter, trans, driveshaft, rear end, disc brakes & hydroboost.
It has only been to the track a few times as it was eating 2004R transmissions & I finally gave up & went back to the T400. There is a lot of dyno time on the engine & additional chassis dyno tuning time. There is no bar in the car but it will run 11.50 in drive all day long. I need to decide if I want to put a bar in the car or not. With a bigger tire, some more tuning & putting the car on a diet I think I can get it to run 11 flat at my home track.
There are lots of guys out there with better engines than this but I am happy with this combination.
Old Nov 14, 2013 | 04:11 AM
chadman's Avatar
I race my street car on a regular basis. I race it exactly how I drive it on the street. Through the full exhaust, same tires, air cleaner etc. I drive it to the track, drop the tire pressure and go. Here is what it consists of:
SHORT BLOCK:
461 CID
Icon pistons 14.4cc dish .005 below deck
Total Seal file fit 1/16-1/16-3/16 rings
Eagle 6.735 rods
N crank turned 10/10
stock caps w/straps and ARP studs
BHJ damper
Mondello SFI flexplate
Engle JM 3-4 hyd. cam .522/.542 lift 230/238 @.050 110 LSA in at 106 ICL
Cometic .040 head gaskets
10.2:1 measured compression
HEADS:
A castings 78cc chambers
2.07 intakes 1.71 exhaust
"bracket" ported by Mondello back in the mid 90's
new valves, guides and valve job by Smitty at M&J Proformance
H&S 1.6:1 Ford style rockers
120lbs. seat pressure
INDUCTION:
Edelbrock Torker port matched to heads, stock plenum
Holley 850 double pumper model #4781 78/86 jets no secondary PV
K&N 14"x3" drop base air cleaner
EXHAUST:
ARH/M&J Proformance 1-7/8"x3" stainless headers
Torque Tech 3" dual exhaust all the way out the back
Dynomax Super Turbo mufflers (I like it quiet)
IGNITION:
Mallory Unilite distributor
22 initial @1100RPM 35 total @2200RPM
adjustable vacuum advance
MSD 6AL
CAR:
'65 4-4-2
3800lbs. w/driver and 1/2 tank of gas how I race it.
TH400 trans
Ultimate Converter Concepts 10" 3200 stall converter
Chevy 12 bolt w/3.73 gears
Moog 6204 springs with Competition Engineering shocks up front
UMI adj. rear suspension w/poly bushings, stock springs, stock sway bar
Air bags
M.T. 275/60-15 drag radials
BEST TO DATE:
1/4=11.60 @116
60ft.=1.60
Old Nov 14, 2013 | 06:17 AM
507OLDS's Avatar
The 72 is definitely a street car,with all the original steel panels,full exhaust,complete bucket/console interior,cage,and is PA inspected,which is pretty strict here.I drive it to work,cruise-ins,parades,etc.It has gone 10:90's @ 122,and weighs 3850lbs with me in it.Drag radials.I don't even own slicks.I race it exactly how it is driven.No switching of parts or different tunes.It has manual steering,manual brakes,and the AC/heat boxes are removed.
Engine: 507" Olds
1970 455 block,bored to 4.211" bore,stiock main caps with straps & studs,and filled to the water pump holes with Hard-Blok.
N-crank,stroked to 4.55",2.200" BBC journals,nothing lightened or anything fancy
Eagle 6.800" BBC H-beam rods
Ross +.060 455 Pontiac pistons,4.211" bore,.990" pin,1.495" pin height,sit .045" in the hole. Total Seal rings.
Fluidamper balancer,the original style before they went cheap
Melling HV oil pump,bolt-on pickup,Milodon 8qt pan.
Ultradyne solid roller cam,257/265 @ .050,.668/.668 lift,108* lobe separation
Comp solid roller lifters
Rollmaster billet chain,thrust button for cam.
Fully ported 1970 W30 F-heads,SI .100" longer valves,Comp springs/retainers,guide plates,ARP 7/16 rocker studs,Harland Sharp rockers,Jomar rocker stud girdles.
MSD pro-billet distributor,bronze gear,oiling hole in block enlarged for more volume.
Carb set-up: Holley 830DP Wilson ported spacer,severely reworked/airgapped Torker
EFI set-up: FAST XFI,FAST T-body,modified Victor,65lb injectors.
Fuel system:
Carb set-up: sumped tank with Aeromotive pump,pre & post filters,-8 line to Magna Fuel regulator,then two -6 lines to carb bowls,no return line.
EFI set-up: Rick's HotRod's fabbed "stealth" tank,with Aeromotive A1000 pump & filter inside tank,-10 supply to Aeromotive regulator,two -8 lines to each injector rail,-6 return line.
Transmission:
TH400 built by Olds enthusiast Dennon Behel,Killen Alabama,machined for extra clutch,Alto green clutches(more aggressive than the typical reds),Trans-Go shift kit,the good older style filter,pump extension,Aluminum deep pan.
Converter:Continental "Tight 10",built for the car,3500 stall.
Driveshaft: Victory steel,1350 joints
Rearend: Moser 12-bolt housing,#7900 ends,Moser 33-spline axles,Eaton tuned posi unit,Motive 3:73's,Timken bearings/seals,Strange 1350 yoke,W27 cover,built by me.
Front suspension: Hotchkis tubular upper a-arms,78-96 B-body spindles,stock lowers,PST bushings,Powerstop rotors,stock calipers,Moroso Trick springs,CE drag shocks.
Rear suspension: Wolfe Racecraft spherical bushings in housing ears,Jeg's tubular adjustable upper & lower arms with solid bushings,stock HD springs with air bag on right side,CE drag shocks,Hotchkis swaybar,Hotchkis frame braces
Exhaust: Hooker super comps,1 7/8 primaries,3 1/2" collectors,Jet-Hot coated in & out,Torque Tech 3" pipes with H-pipe,DynoMax Super Turbo 3" mufflers,Torque Tech 3" tailpipes.
10psi in the airbag,18-20 psi in the tires,go get some.
Old Nov 14, 2013 | 06:37 AM
cv5800's Avatar
My 68 442 is stock, nothing stripped. I race it as is with full exhaust. Best E.T. is a 11.43 at 116.5 mph. at 4800 ft alt. The drivetrain consists of a 468 with stock crank / rods with Aries 11.1 pistons. Roller cam and BTR Edelbrock heads. 2 inch headers and 3" x-pipe exhaust. Turbo 400 and a 4200 stall with the Olds 12 bolt and 3.91 gears. Not sure what the car weighs but I assume around the 3800 lb mark. It is stock right down to the factory eight track and power antenna . windows etc.
Dave
Old Nov 14, 2013 | 06:45 AM
62
Dave
Hey Dave long time no chat...how are things coming along on the '62 Starfire project? Maybe start a thread & share some of your handy work!
Dave
Old Nov 14, 2013 | 06:47 AM
cv5800's Avatar
Dave: Thread was started in the build section.
Old Nov 14, 2013 | 05:34 PM
those are some nice numbers guys. I know its not easy building hp on the olds stuff as the aftermarket does not cater to you guys. but its cool to see these realistic street cars ie no spray, real street gear ratios, ect,ect, brian you are really working those valvsprings with that cam!
Charlie,,,
Old Nov 18, 2013 | 02:19 PM
junior supercar's Avatar
not sure how streetable a 4:33 geared car is, but it's been on the street. I've driven it to work on occasion too. It's even been up and down Route 66 on a cruise during the H/O Nats when it was in Joliet, IL. What an absolute ball to drive too. It's a future Pure Stock car. 69 W-31, born with engine rebuilt including original intake, heads, exhaust manifolds, 29255 carb, the 400289 water pump and the W-31 balancer. 10.6:1 compression with those heavy TRW pistons. JO coded TH-350 which has been rebuilt too. COAN convertor. 2.5" Torque Tech exhaust system with Dynomax long body mufflers (20" length). No h-pipe or x-pipe. KYB shocks all around. polygraphite rear suspension bushings with boxed lower control arms and rear sway bar. front suspension is as built from Lansing in May 1969. Repro Goodyear Polyglas F70x14 on SSII rims. originally a 3.91 car, now a 68 31-spline 4.33. Has gone 13.8 @ 100 The car is currently in the abyss as I gather parts cars, parts, cash and engine pieces as I'm planning to build another engine too.
I have a buddy with a 70 442 convertible Pure Stock car. He doesn't own a trailer so it gets driven to tracks. non a/c, buckets, console, auto, p/s, p/db, 2.5" x-pipe Pypes exhaust system, SSII with repro Firestone Wide Oval G70x14. 3.42 gears in a Type O. Has gone I believe 13.65 @ 101
Old Nov 20, 2013 | 03:25 PM
jims2000lt's Avatar
11.52 @116
Ran 11:50s-11:60s last summer. New engine going together now which should put me in the high 10s.
69 442 3350pounds, pump gas, 3.42 gear.
I dont own a trailer and usually drive it 35 miles one to the track and back home. Probably be another year or two before I get a trailer to make the far away races.
Planning on making the Hot Rod pump Gas Drags in 2014 if I get a rollcage installed.
Old Nov 20, 2013 | 04:34 PM
nightshiftbbs's Avatar
I have a 98 camaro ss that I take to road courses when I can afford it.
Not into the drags.
My olds is more of a sunday cruise and relax car.
Old Dec 27, 2013 | 05:16 PM
w30442's Avatar
Best so far 11.34 @ 120.5 mph in my 72 W30 that weighs 3950 with me in it. It is a 455 Edel heads and a torker. Has 3.73's and a Ultimate Converter 3200 rpm. Its a street car but I think I like racing even more now. Have to work on my 60's at 1.67 best.
Old Jan 6, 2014 | 09:22 AM
jfb's Avatar
jfb
i HAVE A STREET N STRIP CAR ALSO BUT FOR A REASON OF COMMON SENSE i WILL NOT PUT THE REAL TIMES IN PRINT PERIOD. i FOR ONE NO THAT REAL RACERS FOR DIFFERENT REASONS WOULD ALSO NOT PUT THE REAL TIMES IN PRINT, THINK ABOUT IT THATS THE WAY IT REALLY WAS FOR EVERYBODY. GOOD LUCK TO EVERYONE NOW GOING OUT TO RUN I HOPE YOU HAVE A LOT MORE IN STORE TO RUN WITH.
Old Jan 6, 2014 | 09:33 AM
chadman's Avatar
You obviously are misunderstanding the rest of us. We are not proclaiming to be "street racers". We have "street" cars that we take to the TRACK. Big difference.
Old Jan 6, 2014 | 09:40 AM
coppercutlass's Avatar
Chevy budget Olds powered
I don't mind street racing in a secluded area but most street racers are real d bags. I hate the whole mentality nowadays with grudge racers the talk too much bs.
Old Jan 6, 2014 | 10:06 AM
how about....
Lose the caps lock & drop the attitude.
Old Jan 6, 2014 | 10:30 AM
507OLDS's Avatar
What?
Fine,keep it to yourself,just bring a set of snow tires and the title. I need a winter ride.
Old Jan 6, 2014 | 10:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What the heck kind of answer is that jfb? I post my awful numbers, even if my car didn't run what it should. All a learning curve.
Old Jan 6, 2014 | 02:34 PM
jfb's Avatar
jfb
hey all i am saying is that for our own purposes that our times or real times should be kept to ourselves. I love having a good time but the people i normally run against our have run keep the times to themselves period. I said this before if any of us run against other makes that we should try to come out on top with pride etc. I know for a fact that some people troll sites to learn these things as a group we have to come out on top. The internet is excellent for info but also a open book sometimes the same. I always try to come out on top for oldsmobile and future changes do too forums could be expensive so why give more info then needed money does not grow on trees guys. I would like to see all of us win with pride anywhere including shows why let others plan to win ahead of time.
Old Jan 6, 2014 | 02:38 PM
I want my 30 seconds back it took to read this. I'm proud of my et.'s and I don't think there is a conspirasy group out tk get up. I'm sure you have your tin foil hat on.
Old Jan 6, 2014 | 02:46 PM
I have been coasting by on a couple of fast Olds at our track. Owned by one guy now, if he doesn't show up I need to represent. I realize a near stock 350 won't cut it at 3750 pounds, time to step up.
Old Jan 6, 2014 | 03:27 PM
Redog's Avatar
I'm not in the 11's, but my Alero was my daily driver and I would run it at the track. Best time ever was a 14.53, not bad for a full interior car which was running 16.2 off the showroom floor
Old Jan 6, 2014 | 03:58 PM
stroke this
When are you going to step up & build that stroker motor that you want?
Old Jan 7, 2014 | 12:20 PM
This winter I am starting and will be completed before the year is out, hopefully. Hope to get at least one run this year. I have many projects to complete and a lot of fishing to do.
Old Jan 11, 2014 | 12:39 PM
jfb's Avatar
jfb
good luck to all of you and have a good time at it,I always have and will set up drag days for people. I have also won a few things from those days that helps the next time I run. I was reading on real olds power that a 434 small block reader was switching to chevy power but hey I get it costs can be huge period. once again i will say this though we all have a good time but our real times should be kept quiet our ideas are what will make us rise above any competitors,our combos choices are minimal at best. I would love to get 200 to 300 together to run in late 2014 including other makes and have all of us make a great showing. I have raced at tracks and it is a great feeling when you win so why give away secrets even with street cars if you really race.
Old Jan 11, 2014 | 02:50 PM
507OLDS's Avatar
Paul does some serious track racing,and to go to the next level,the BBC route is the most practical for what he is doing.
Old Jan 11, 2014 | 05:02 PM
jfb's Avatar
jfb
amen on what he is doing at least it is a olds body,olds also had other engines over time for pondering purposes. I would have loved to go real pro myself but money does not grow on trees or time. I will always be happy representing our make when needed and doing it with class. I would truly love to get a lot of guys together late in 2014 fall with whatever bikes, chevys,buick olds whatever around Chicago and it would be cheap if we have a large crowd.
Old Jan 11, 2014 | 05:23 PM
  #31
yeah gld does that already with the kots . real street drags , test n tune , Byron packs the house with their big buck bracket bash once a month I think then there is bop race in sept , I think gld does a bop in june then cordova in oct. plenty of events.
Old Jan 11, 2014 | 05:55 PM
  #32
jfb's Avatar
jfb
I am looking for heads up everyone including myself lines up and takes there chances and just has pure fun. I also copper would like to know if you saw any wings at the bopc swap meet last year.
Old Jan 15, 2014 | 03:27 PM
  #33
WMACHINES's Avatar
Well, I have no shame in listing my numbers. In fact, I even have a web site setup with my engine combo to give fellow and future Oldsmobiler's something to start out with. My ride is 4065lbs with me in it. I take it to the Woodward cruise. I do the whole week think. Woodward is 30 miles from me. I drive the car to Lansing. About 100 miles from me. I run high 11's with the car. Here is the link to the web page. I cruis the car all summer long. http://home.comcast.net/~wmachines/ENGINE/index.htm
regards
Old Jan 17, 2014 | 09:20 PM
  #34
ds00469's Avatar
72" Cutlass with 468 BBO drive the car all over the place at 6MPG and will run the 1/4 at 12.99 on street tires.
Video of me at Cordova, IL
Old Jan 18, 2014 | 05:01 AM
  #35
Smitty275's Avatar
Engine Builder
I used to drive mine to the track all the time. Two to three times a week weather permitting. My first Olds was a '76 Cutlass with a stock '74 455 swapped in that through stock dual exhaust would run 14.07 no matter what the weather. I should have kept that one as it was a money maker. Then I got the '67. When it was stock with the 330 I'd race on street tires. Then when the mildly built 455 went in it wouldn't hook on street rubber. So the routine changed a little to run 11s. I'd find a spot, empty the car, swap tires, and make as many passes as possible. Then I got that need to go faster and thought it best to get a trailer, which gave me a good reason to get a truck.
Old Jan 19, 2014 | 03:22 PM
  #36
My Oldsmaturd runs 11:60s, has done parts of 3 Power Tours, is driven as often as possible, averages about 16-17mpg, and made it all the way in last years Drag Week. I had the quickest Olds until the Tennessee stop, I missed that date by 15 minutes. I tore the center out of the crank pulley in a little town called Red Bud, Illinois. By the time I got the car patched together (when the pulley cracked it wrapped the belts in the fan, which then cracked my alternator case) the next day I missed the cutoff time. I cant really complain, my friend Carrie did claim the fastest Olds title, she never misses an opportunity to remind me! I intend to do Drag Week again, hopefully its not as brutally hot as last year!
Old Jan 19, 2014 | 06:34 PM
  #37
blakes7's Avatar
I haven't been there in a few years, but at Riverhead Raceway on Long Island, there was a guy who drove from the Bronx to the track in a black 73 Cutlass, and always entered it into the "Spectator Drags", where you did a lap against other spectators. Every time I saw him there, he ALWAYS won. How much modified it was I don't know, but I think it was a manual tranny.
Old Jan 19, 2014 | 07:33 PM
  #38
BIGJERR's Avatar
I bleed Oldsmobile
Mine has been down the track a few times over the years ........
Stock bottom end with a little spray......
Bests
10.92@121 on juice
11.66 @112 On motor
455 with a stock bottom end...No girdle,No Straps,Virgin unturned crank.....
Trw Pistons on stock and a set of C heads.....
Motor lasted thru 9 years of abuse.......
Old Jan 19, 2014 | 07:35 PM
  #39
BIGJERR's Avatar
I bleed Oldsmobile
1972 Cutlass Drag Racing - YouTube
Another blue Olds at Cordova....? I need to get out more often!
Old Jan 24, 2014 | 11:30 AM
  #40
HWYSTR455's Avatar
The whole 'secrets' mentallity of certain 'drag racers' is exactly what turns me off about drag racing, but I usually run my stuff at the track. I haven't had the opportunity in the Olds yet, but certainly will this summer, take it up to Capitol in MD.
Used to have an 1/8 mile about 3 miles from my house, T&T wednesdays were nice, lot's of folks would drive right off the street and line up, no helmets were required, no tech, nothing. Used to be the same way in Colonial Beach, folks would come right from crusing the 'lap' around town, pick a fight, and pull right up to the lights at the track. Tell me that doesn't help keep it off the streets.
My driver has a pro-touring suspension, it will spin the entire length of the 1/8. Baby-ing out of the hole it's done a traction limited 7.33, and I've listed everything in that car multiple times on mulitple forums.
If you're a professional drag racer, other professionals have seen what you've run before, and know the general range you're capable of, so not sure even there how it would help. Just makes no sense to me.
BS grudge match stuff on the street, yeah, I GUESS I can see it, but still makes no sense to me. There's so many variables on the street, it just doesn't matter.
