Porting my j heads
Old May 7th, 2018, 10:43 AM
6t7
6t7's Avatar
Porting my j heads
Greetings, I have recently bought a ‘67 Cutlass with a rebuilt 455, not sure of the year, it’s got j heads. It has plenty of power as is, but more is better, right? I have done a couple of home porting jobs that have made a noticeable improvement in get up and go. Any tips \ advice on which areas to concentrate on, how much to remove would be appreciated. Thanks
6t7 is offline
Old May 7th, 2018, 12:12 PM
Welcome to the site, post an intro in the Newbie section when you get a chance. Although its about sbo heads, this is a really good read.
https://classicoldsmobile.com/forums...echniques.html
oldcutlass is offline
Old June 17th, 2018, 11:59 AM
67 Cutlass Freak's Avatar
Hey Eric that's not just SB heads. I showed some G's and C's being ported in that thread as well. Same techniques used for both SB and BB.
67 Cutlass Freak is offline
Old June 18th, 2018, 06:55 AM
74sprint's Avatar
'J' Heads
IMHO Don't waste your time with 'J' heads. Even with a street/strip port job, on the flow bench they flow no better than stock untouched 'G' heads. If you can, get at least 'G' heads, 'C' of course would be the best iron or even go with cheap aluminum ones if you can afford them. But J's are boat anchors because of their choked raised floors for additional cooling and are designed for very high swirl, way too much swirl.
Ray
74sprint is offline
steel-and-fire
December 4th, 2018 06:04 PM
Tpenner64
May 27th, 2018 10:28 AM
Austin Trevor White
June 5th, 2015 05:40 PM
455cutlass1969
April 13th, 2012 06:17 PM
442NDTSS
July 2nd, 2010 10:41 AM
Quick Reply: Porting my j heads
