Engine running at higher rpm after hard driving
Old September 18th, 2017, 10:37 AM
H8D-67's Avatar
I have noticed for a while that after doing some hard driving or extended freeway driving that when returning to idle my olds will run about 250-300rpm higher than normal. I have dealt with it for months and just not worried about it because the car runs well but now I feel like figuring out whats going on.
Its a 425 with aluminum heads, performer intake with pro systems carb, MSD 6AL ignition. After hard driving it will keep that higher idle around 900-1000rpm for maybe 10 minutes of normal street driving afterwards then calm back down to normal. Anybody have an idea what it might be?
H8D-67 is offline
Old September 18th, 2017, 05:16 PM
classicmuscle442's Avatar
Throttle not returning to idle when released? Return spring weak or more likely throttle plates hanging up in carb bores.
classicmuscle442 is offline
Old September 18th, 2017, 06:50 PM
Chevy budget Olds powered
coppercutlass's Avatar
Advance weights could be hanging up. have you revved it after to try to lower the idle ?
coppercutlass is offline
Old September 19th, 2017, 07:31 AM
H8D-67's Avatar
Timing is locked out currently. I have tried blipping the throttle and it doesnt seem to change it at all.
H8D-67 is offline
Old September 19th, 2017, 07:32 AM
H8D-67's Avatar
Ive changed return springs and the issue has stayed. Could be throttle plates hanging up but I would hope not. This is a customer built pro-systems carb and isn't very old.
H8D-67 is offline
Old September 19th, 2017, 11:50 AM
stlbluesbrother's Avatar
If you shut the engine off and then restart, does it idle at the proper RPMs? If so, coppercutlass has likely explanation as it relates to advance weights in the distributor not returning to position.
Update: just noticed the comment on "Return springs ...".
Last edited by stlbluesbrother; September 19th, 2017 at 11:55 AM. Reason: noticed more info
stlbluesbrother is offline
Old September 21st, 2017, 08:07 PM
H8D-67's Avatar
Alright so took out the olds today. Did a quick hit and it started idling high. Pulled over and ripped off the air cleaner, throttle was sitting at idle like it should. Blipped it a couple times underhood and nothing changed. Turning the car off for a minute or so did bring it back to normal. Ignition setup is a msd 6al box and billet distributor with timing locked out at 32 degrees. So there is no advance weights to get stuck. Running a slightly colder plug for the 100 shot of nitrous that it gets hit with every so often. This problem did exist with previous hei setup as well.
H8D-67 is offline
Old September 21st, 2017, 11:14 PM
74sprint's Avatar
Hot Idle Compensator
Some quadrajets and other carbs had a HIC or hot idle compensator circuit which would raise the idle when the engine got a little warm. Here is one site http://442restoration.homestead.com/carbs.html But I suggest doing a Google search for Hot Idle Compensator and see if this might be relevant to your situation.
Ray
74sprint is offline
Old September 22nd, 2017, 05:10 AM
Still think your problem is carb related. Without a computer the carb is the only component that can change idle speed.
Old October 16th, 2017, 06:16 PM
shiftbyear's Avatar
Is there a way you can get a timing light on it after the idle rpm's increase, just to rule out ignition. Also when the idle is high, see if the secondary throttle plates can be shut further with your fingers, by pushing the linkage arm. Some times the secondaries can hang up in their bore even thought the primaries are against the idle stop. Also check for vacuum leaks. Good luck.
shiftbyear is offline
GHOSTOWLGRID
April 2nd, 2017 10:28 PM
skubydobdo
February 3rd, 2014 03:25 PM
Scotty B
May 16th, 2013 03:18 AM
68oldscutlass
Brakes/Hydraulic Systems
August 9th, 2012 07:27 AM
Quick Reply: Engine running at higher rpm after hard driving
