Type O axle parts and gears?
Old Oct 20, 2012 | 02:18 PM
jims2000lt's Avatar
11.52 @116
Who makes parts for these still?
Looking to rebuild my Posi and swap to a 3.90 to 1 gear this winter.
Car has a 3.42 to 1 posi now.
Would I need to change carriers?
Cheaper to build a 12 bolt or 9inch?
Currently running high 1.50 sixtys on a footbrake launch, pushing about 3350 LBs.
Thanks for any and all input/ input.
Old Oct 20, 2012 | 02:30 PM
2blu442's Avatar
Check with Jim (monzaz) or Brian (507OLDS). They should be able to answer your questions and point you in the right direction.
John
Old Oct 20, 2012 | 02:57 PM
Run to Rund's Avatar
It will cost similar money to build whatever rear you choose, if going for strength and not just a rebuild of something that is more or less stock and for which you already have most of the stuff. If you are runnikng 1.50 60 ft. times, either a fully built 12 bolt or better a Type F ten bolt (aka "Dearborn" option or 9" Ford) would be best.
Old Oct 20, 2012 | 04:48 PM
You do not have to change carriers.
Old Oct 20, 2012 | 05:12 PM
380 Racer's Avatar
Do a 12 bolt Chevy, good for the 9s and cheaper than a 9".
Old Oct 20, 2012 | 07:19 PM
jims2000lt's Avatar
11.52 @116
Cool. Thanks for the info guys. Probably gonna look into getting a 12 bolt built.
Old Oct 20, 2012 | 08:12 PM
507OLDS's Avatar
I have access to a 12-bolt Chevy housing that I can build to suit.
As far as your O-axle,you can retain you existing carrier,and install new Richmond 3:90 gears,but you will need to mill .100" off the backside of the ring gear, OR you can leave the ring gear alone,and get a new carrier,which is made for the Richmond gears.
Old Oct 21, 2012 | 12:04 AM
The_Jeremiah's Avatar
If you want my .02 cents, go with the 9" I like being able to change gears completely without changing carriers, just cut it down to size with 12 bolt bearing ends from moser so you can put your gm brakes on the end.
Old Oct 22, 2012 | 10:51 AM
jims2000lt's Avatar
11.52 @116
After this past weekend of racing and running 1.55- 1.60 sixty foots and running 11.64 to 11.55, I'm just going to keep the same setup for awhile.
I dont think a gear swap will really make a huge difference for the cost.
Probably gonna drain the rear, clean it, put Amsoil back in, and add a W-27 cover.
I think a year from now I'll start build a new rear. Probably go with the 12 bolt. I'll be starting on a new engine build by then with MORE HP. BB stroker or atleast new rods pistons with more compression and a roller cam topper with a victor intake. We'll see what happens.
Old Oct 22, 2012 | 11:51 AM
507OLDS's Avatar
When you refill that rear,use conventional gear oil.Do not use synthetic.It is not good for any clutch style posi unit.Don't forget your posi additive too.
rktolds
Jun 1, 2015 06:38 AM
yamahondarider
Drivetrain/Differentials
Nov 8, 2014 08:24 PM
L77F85
16
Nov 29, 2013 06:19 AM
507OLDS
Apr 26, 2012 05:03 AM
bbolds442
Mar 27, 2008 12:35 PM
