Stock Flextplate & Harmonic Balancer - Power Levels
Old Jan 2, 2021 | 11:55 AM
pettrix's Avatar
On a 455 making under 500HP, how reliable/safe are the stock OEM style Flexplate & Harmonic Balancer?
Old Jan 2, 2021 | 01:18 PM
I see no issues with using stock.
Old Jan 3, 2021 | 01:42 PM
Battenrunner's Avatar
Stock flexplate that doesn’t have sloppy holes for the converter or flexplate to crank flange can hold a decent amount of power, probably close to 500hp, if the balance weight is welded on well and it doesn’t get a stress crack.
The stock or rebuilt factory dampers are the most likely things to fail at higher HP /higher RPM with the outer ring spinning or moving on the elastomer isolator.
I have bought rebuilt stock balancers and seen the rings slip several degrees when checking timing and comparing true TDC on less than 400hp 455’s.
ATI and BHJ make great dampers for our Olds engines.... reliable, rebuildable, and effective with true SFI sticker
I went with a Speedmaster 79 Billet Flexplate with bolt on external weight and it was a nice piece and SFI approved also.
buy once, cry once
Old Jan 5, 2021 | 07:05 PM
Bernhard's Avatar
The balancer is not a item you want to try and save money on. Go cheap on the valve covers and air cleaner. When I'm checking total advance ignition timing, I do not want to be struck by shrapnel from an exploding balancer.
Old Jan 5, 2021 | 07:54 PM
70sgeek's Avatar
'72 Cutlass ragtop
ATI also makes an Olds-dedicated flexplate, SFI approved 166 tooth. Have one on behind my 350 and it's a stout piece - I believe p/n = ATI915565
Old Jan 5, 2021 | 08:14 PM
coppercutlass's Avatar
Chevy budget Olds powered
I'm appx 420 ish HP with my sbo. Stock balancer and flex plate spun to 7k rpm
Old Jan 6, 2021 | 09:44 AM
70cutty's Avatar
Beer Connoisseur
Your block will give up before flexplate and balancer.
Gene kerr
Apr 1, 2020 08:07 AM
Tiha
Sep 8, 2017 07:41 AM
wagsk2000
Oct 10, 2016 03:01 PM
Buster411
Jan 16, 2013 01:45 PM
Stevec
Aug 12, 2012 03:12 PM
