I’m installing TRZ solid body mounts in a ‘71 Cutlass. Having some trouble figuring out how to remove positions 4&5 mounts. They appear to not have any bolts, however I can’t get the body to lift off them. All the others been straightforward.
Yes, you will need to open up the hole for the 1 position. You will also need to clearance the bushing half that's inside the frame where it is lap welded for the bushing to sit flush..you will also need to clearance the 6 position in this manner.
The underside of mentioned mounts that are throwing me for a loop: #4 #5
I did quite a few upgrades to try and get down the track straight:
TRZ Rear Anti-Roll Bar
TRZ adjustable upper and lower rear control arms
poly transmission mount
solid motor mounts
TRZ solid body bushings
