power combo
Old Jul 3, 2012 | 05:19 PM
DYSKIE's Avatar
power combo
What is the best comp cam for E heads big valve, and what is for Edelbrock heads?
engine:
461cid, 10.5 compression, torker intake, Holly 850dp, MSD sys., headers.
Im looking for great combo for Hi-performance street race and drive with no problem.
Old Jul 4, 2012 | 03:17 PM
ah64pilot's Avatar
dude that is such a vague question...the best cam for me may be too small for you or vice versa. Do you really have 10.5 compression? Do you have power brakes or anything that needs vacuum?
A little more background for the car and your experience would help in determining what kind of cam to recommend for you.
Old Jul 4, 2012 | 03:43 PM
DYSKIE's Avatar
there is power brake and vacuum
Old Jul 4, 2012 | 03:53 PM
DYSKIE's Avatar
Olds 461, big valve “E” heads ported and polished, Mondello pistons, high volume oil pump, windage tray, ARP bolts, 10.5:1 compression, MSD system, FT headers, 4:11 rear end.
Old Jul 9, 2012 | 06:34 PM
DYSKIE's Avatar
How about lunati voodoo 276/284H or comp cam xe274H?
Old Jul 11, 2012 | 11:02 AM
cutlassefi's Avatar
Why are you limiting yourself to those cams?
Old Jul 12, 2012 | 05:04 PM
DYSKIE's Avatar
Do you prefer another cam? I want to get the best cam that work with my engine.
Old Jul 13, 2012 | 12:41 PM
cutlassefi's Avatar
What heads? Iron? Edelbrock? Ported? Unported?
That makes a difference.
Old Jul 13, 2012 | 01:20 PM
DYSKIE's Avatar
previous owner said it's big valve “E” Iron heads ported and polished
Old Jul 13, 2012 | 06:04 PM
cutlassefi's Avatar
Then I'd do an Erson with their .355 lift lobes, probably a 236/244 on a 112. Lift would be .568 on both. With ported heads and/or Edelbrock heads the added lift is worth something. Otherwise it's a waste.
I sold a similar cam to a guy with a 455 Buick, ported iron heads and a 175 shot of NO2. Made 580 at the rear wheels.
Old Jul 13, 2012 | 06:39 PM
MR73OLDS's Avatar
Gears tire size finnal gear ratio matter! Car weight,a/c,heads flow rate. Are things to consider. I have had my best luck with the comp cams there tech help line is good dont hesitate to call them. You dont want to be pulling your cam out or your engine after installed! Make sure all your engine coponents are part of your engine build! Good luck.
odddoylerules
Apr 21, 2014 07:54 AM
Olds71suprema
Apr 1, 2008 08:16 AM
Chumley
May 24, 2007 09:39 AM
Crankit
Jan 25, 2007 05:09 PM
