Performance 455 Rebuild Suggestions:
cutlassefi my dyno sheet is attached in regards to BSFC#HP-Hr, I have a 870 Holley Street Avenger for carb. I am no engine guru by far but trust my engine builder in regards to the info and results.
Scooter with the engine in the car I run about 40psi at idle and between 50-60 while driving and hard acceleration. Overall I'm happy for a street vehicle with A/C and power brakes, 2004R is next
I have to agree. More like .4-.5 on a carbed V8. An honest .275 would be earth shattering. The ooil companies would be lining up at His door to buy him out and stop him from ever building another engine.
Great build! I went with Eagle kit 488 with thumpr hyd roller cam and made peaks of 586 tq @ 3600rpm and 487 hp @ 5000rpm.
I would attribute the duration and lift of your cam giving you higher peaks along with running it at cooler temps in which we ran mine at 181.
My avg oil pressure from 3k-5k rpm was 38.4 and my avg BSFC#/HP-Hr avg .275.
So was it 600@3700 or as stated above?
Was the Thumpr cam installed on the 102 ICL as recommended?
Even with no dyno sheet to see where the rest of the curve is, I'll take a stab at it anyway. I most likely would have done something on a 110 with less exhaust duration than you have.
Thumpr's are mostly to make noise, they're not necessarily the best at making power.
Sorry overlooked that.
You left hp on the table with your oil temp only being 90*, if that's correct.
Your build peaks way too early, even for a 488. Going on corrected hp it's a bit low overall.
Did you mill the center divider on the intake?
Your cam is wrong for this build. A cam like the one I used for "70cutty" would have been better, especially done on a 112 for a stroker build like yours.
Jmo.
Jmo.
Jmo.
Jmo.
I don't believe he milled the center divider on the intake of the RPM Air Gap intake, just port matched to heads.
Thanks for the info.
Jmo.
Jmo.
Cutlassefi "70cutty" corrected dyno sheets don't compare to mine in regards to torque or hp and the curve is very similar(where peaks aree)? Are you stating that this cam would perform better with my combination because the thumpr out performed that custom grind just looking at the dyno sheets.
Not sure what you're asking.Bottom line is the cam you have probably sounds great. But it's wrong for your combination imo.
I'm confused by your comparison. One more time, IMO you have the wrong cam in your motor for POWER, not noise.
Thanks.
Uhh I think you're comparing the wrong sheets. CHP to CHP (corrected, not measured) hp and torque are pretty similar, and he did it with 35 less cubic inches.
Thanks.
Thanks.
Thanks man
No problem, just didn't understand exactly where you were coming from or headed.
Yes your builder picked the wrong cam. That's common though, they read too many magazines. Comp Cams has a lot of people brainwashed.
455 Build Update
Hi all,
Just a quick update on my 455 stroker build.
I had some good runs at the track this last weekend and best so far is 11.54 @ 117 mph with a DA of 2000 ft and a car that weighs 3850 with me in it.
The calculator says the mill is putting out 579 HP.
FYI: I am running 35 deg of total timing and run 91 octane gas with a 15-20% splash of C12 race fule for a total octane of ~ 95.
All the specs are at the top of the thread. Only changes are I am running a TCS 4000 stall converter (was supposed to be 2800-3400 stall but the Olds torque monster is a little overpowering). It is a race grade converter with anti balloon plate etc.
FYI: I noticed perplexing issue with oil pressure a while back where oil pressure would drop from 55 to 40 psi on hard acceleration and then pop back up when I let off the throttle. I tried draining ~ 3/4 qt and the problem went away. I have a Moroso 7 qt pan with a WIX 1 qt filter so volume isn't an issue. I have also since switched from 5W-40 synthetic to AmsOil Race Dominator 15w-50 and now have about 5-7 more PSI across the board. Pressure holds steady at 58 -60 psi down the track. Cold idle is 63-68 psi and 35-40 psi hot @ 180-200 deg water temp.
Question: what sort of performance gain could I expect by switching from the current Edelbrock performer intake to the RPM Air Gap or better yet the Victor?
I also think that my Holley HP 950 might be a little small. Would I benefit from going to a 950 or 1050 QF?
The engine seems to be running well and strong, I am happy so far.
Cheers,
Cheers,
Who is your builder up there? Only slightly up from me, that is why I am asking. Nice numbers and build, there are some seriously fast Olds powered Oldsmobiles in this province.
I had it built by K & S Machine in Kelowna (Keith Korchinski). Check out his 6's ProMod video. It was a PITA shipping the motor back and forth but he is a good builder with 30+ years experience, reasonably priced and also a very nice gentleman to talk/deal with. He just does what ever it needs and "makes it right". FYI: he scratch build the heads on his 2400 HP ProMod.
I bought all my performance parts from Ray at Hardcore Performance Specialties here in Saskatoon. Give him a call if you need anything.
What are you running and what is your HP?
I could probably eek a bit more out of it with proper carb tuning and a real intake like a victor. The car is a full street car.
You will have to get your car up to SIR.
Cheers,
Cheers,
I would love to get up there, maybe next year. Pretty sad any decent shops around here have huge wait times. There is another good shop in Alberta, OldsmobileDave deals with, has built 800+ hp Olds V8's. I may try a local to machine my 425, 403 based SBO stroker. My car is slow but adding a set of nicely ported and milled #6 heads on my 350 this week. Going to Yorkton on September 6 to run the 1/8 mile, hoping for high 8's.
Johnathan Bjerk
Jan 8, 2013 06:53 PM
wmachine
Dec 30, 2009 05:55 AM
