New Personal Best
Old Aug 13, 2012 | 06:06 AM
jims2000lt's Avatar
11.52 @116
New Personal Best
Went to US41(no limit dragway) in moroco, IN yesterday with the 442 and ran a new personal best.
11.52 @ 115 with a 1.56 sixty foot time.
also ran the same exact time once more with a 1.59 sixty.
First and slowest run was an 11.67 @113.
Made a total of 7 runs without a single issue.
Brief combo update.
69 442 all steel except front bumper with full interior
3.42 olds 12 bolt axle
tci 32-3500 10" converter
th400 reverse manual VB
+.40 455 = 464
890 cfm holley
torker intake
Ebrock heads
2" hooker super comps
3" exhaust
Lumati Voodoo cam flat tappet hydraulic
Over the winter I honed the cylinders, installed new rings bearings and gaskets. Also self ported the heads and intake.
Old Aug 13, 2012 | 06:54 AM
gearheads78's Avatar
car guy
Congrats man! Its always great to see the results from your effort.
Old Aug 13, 2012 | 04:30 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Did you see a black 69 there running 9.40's?
Old Aug 13, 2012 | 06:28 PM
jims2000lt's Avatar
11.52 @116
Yup. Talked to Milan a bit along with his driver. I checked out their car and they did the same. We both liked each others rides. I should have done a photo of both, on and off the track.
Old Aug 13, 2012 | 06:42 PM
ah64pilot's Avatar
Got any pics of the evening?
Old Aug 14, 2012 | 04:29 AM
380 Racer's Avatar
Milan builds some mighty fine motors. Very intellegent guy.
Old Aug 14, 2012 | 05:58 PM
jims2000lt's Avatar
11.52 @116
Yup. i'll try to post them up tonight. My dad ran his 67 GS and cut some better 60s along with gettin air under the left front. My friend Rob ran a new best of 11.84 in his 55 Dodge Ram with a dual quad 457. Its was a great day with super weather for a change. 75 and overcast, a little humid but not bad.
Old Aug 19, 2012 | 08:16 PM
ah64pilot's Avatar
What do you have for a suspension setup? I have yet to do anything to mine and I'm trying to plan it out so I don't waste money.
Old Aug 19, 2012 | 09:00 PM
Rickman48's Avatar
Did you have to run a bar, going 11's? I know some strips will let you wait until 10's.
Nephew's wanting to take his 494 '69 out, but concerned about the bar.
Old Aug 19, 2012 | 10:07 PM
ah64pilot's Avatar
If it's an NHRA sanctioned track the roll bar rules start at 11.50 or quicker...if it's not sanctioned it's up to the track owner.
Here in Houston Hennessy bought a track in Sealy and it is not sanctioned. As long as your car isn't shoddy he will let you run it. There have been stock body Supra's running 9's out there without cages and such.
Old Aug 21, 2012 | 07:13 PM
SBORule's Avatar
There should be more tracks like that around the country.
I can't count how many times I've been told to not come back until I have a 6 point in the car and NHRA legal seat belts.
Now that I don't have any Nitrous on the car, it's not a problem.
Old Aug 21, 2012 | 07:15 PM
SBORule's Avatar
Congratulations on your new personal best.
Brief combo update.
+.40 455 = 464
890 cfm holley
torker intake
Ebrock heads
3" exhaust
Old Aug 22, 2012 | 05:34 AM
380 Racer's Avatar
My home track is NHRA sanctioned. If the track lets a person run and looks the other way on safety issues and they wreck their car, the insurance pays half. So you are actually taking a big gamble running sub 11.50s without a bar.
Old Aug 26, 2012 | 12:33 AM
jims2000lt's Avatar
11.52 @116
Southside machine lift bars, boxed stock uppers, CE 3 way adj shocks, moroso trick rear springs, and hotchkis tubular frame braces that go between the upper and lower mounting points.
May go to air bars of antiroll bar over winter to level out launch. Pulls just the left front tire off the ground. I would also like to go to a better set of adjustable shocks. Front of lower control arm mounts are gusseted along with the upeer control arm mounst with 3/16 steel plate. Battery is up front and have a steel with heim joint torque strap with stock rubber motor mounts. Other plan is moving the battery and adding a BTR or HVH tapered four hole carb spacer to replace open center moroso peice. Hope all this helps you and me both.
Old Aug 26, 2012 | 12:36 AM
jims2000lt's Avatar
11.52 @116
Thanks man. I love driving to the track, running these numbers and driving back home. Alot of people scratch their heads and alot of jaws drop when I tell them my sixtys with a 3.42 gear. Something is working right for me.
Old Aug 26, 2012 | 09:20 AM
TripDeuces's Avatar
You mentioned you ported the heads over the winter. I'd be interested in your previous times as compared to the new set up just to see what the porting did.
Old Aug 26, 2012 | 01:12 PM
jims2000lt's Avatar
11.52 @116
My best last year was an 11.63 at 113. On average I'm about .15 faster. I basically sand rolled the intake ports, cleaned and lapped the valves, checked the valve springs, and polished the combustion chambers. I spent most of my time porting and polishing the Torker. Trying to get all the runners equal. I had thought of swapping to a victor jr but I drive the car more than race it and figured I would only see a small gain if any with that intake since its rated to run at a high rpm. I shift at 5500 and cross the finishline at 5300. I could use more gear but always wanted to see how fast I can go with the 3.42 gear.
Old Aug 27, 2012 | 03:08 PM
ah64pilot's Avatar
Wow, I'm hoping my car can run about what you are running. I ran 12.11 @ 112 last time out but I don't have much for suspension. I am running SSM's as well but everything else is stock. I plan on doing the anti-roll bar and some QA1 adjustables soon...and maybe some boxed upper control arms. I have a 3.42 gear as well
As far as the control arm mounts, I know gusseting can't hurt but did you see evidence of cracking or anything that made you want to do it? Just wondering if I should do it before I create a problem for myself.
Also, where can I find specs on your engine? I just want to know if I am being too optimistic expecting 11.50's out of it. I made 492 / 544 before changing the head gaskets and upping the compression a little bit.
I'm in the same boat, I drive my car more than I race it so I don't want it to be too squishy on the road I wish I could drive it to the track but it's an hour and a half each way... I can't afford the gas lol!
Steve
Old Aug 28, 2012 | 03:14 PM
jims2000lt's Avatar
11.52 @116
Steve
I saw cracking years ago on the right side upper mount and the car was running 11.90 with the left front about 8 inches off the ground. Once I gussetted everything and installed the tubular frame braces it started leaving more level and pulling the left front only an inch or so. It braced everything which helped the SSM bars plant the tires HARD. I have a few pics of it at the sixty and the whole car is lifted up.
I originally started my engine build in 02 copying a build CAR CRAFT did and up til now things have progressed. Never been dynoed, car or engine but my guess is 520 hp and alot of torque.
Your engine probably has enough power to go 11.5 but weight and rear suspension helps alot. I probanly have gained 1/2 a second just from tweaking the rear and I'm not done yet.
Ireplier on your thread and want to make some changes too. Probably QA1s and an antirool bar but we'll c where the $ is this winter.
let me know if I can be of more help.
oldsmobiledave
Oct 18, 2014 07:08 AM
joe_padavano
Site Suggestions
44
Dec 20, 2013 12:58 PM
Joeolds71
Site Help
Feb 1, 2013 02:06 PM
aaronlife
Aug 30, 2010 09:51 AM
70-442-455
May 24, 2008 03:35 PM
