milling exhaust side on iron heads
Old February 7th, 2014, 05:04 PM
young olds's Avatar
Im thinking about getting my heads milled on the exhaust side to bring the divider flush. It looks like it will have to go quite a bit, anyone have a measurement of how far to go? And does it cause any problem with bolt hole depth or the freeze plugs?
young olds is offline
Old February 7th, 2014, 05:10 PM
Oldsmaniac's Avatar
Some heads have a center divider recessed too far to mill flush. I believe for a BB these would be J heads not sure if there are any others. You can measure the amount of recess and then figure how much metal would need to come off. I think the ones I had done were B heads and there were no issues at all.
Oldsmaniac is offline
Old February 8th, 2014, 07:45 AM
Engine Builder
Smitty275's Avatar
Usually take .180-.200" to get it flush with a small flat on it. It does increase flow a little but it also raises the roof of the exhaust port. So you either have to slot the bolt holes in your headers so you can raise them up a little or open the top of the header flange accordingly. You'll also need to trim the top of the gasket opening also.
Smitty275 is offline
Old February 8th, 2014, 07:47 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Also, if you have cheap headers, the pipe might hit the side of your oil pan, thus cooking your oil. Measure that clearance as well.
J-(Chicago) is offline
Old February 8th, 2014, 10:00 AM
young olds's Avatar
Thanks guys
Old February 8th, 2014, 12:35 PM
Engine Builder
Smitty275's Avatar
I forgot to say that some headers will require multiple gaskets to make up for what is cut off. This includes ARH and Kooks/Dick Miller.
Old February 8th, 2014, 05:06 PM
young olds's Avatar
Thanks for the heads up
Old February 10th, 2014, 09:35 AM
507OLDS's Avatar
My heads are cut that way. The biggest issue I had was that having the flange milled that far back creates a shelf with the deck.
507OLDS is offline
Old February 10th, 2014, 09:42 AM
Chevy budget Olds powered
coppercutlass's Avatar
Now I have never personally done this or had it done but if you did have the heads cut that way couldn't you just run those really thick remflex graphite header gaskets ?
coppercutlass is offline
Old February 10th, 2014, 10:16 AM
507OLDS's Avatar
I would have needed a spacer. I had to grind the bottom sides of the header flanges,to get them to clear the deck & bolt to the head.
Forget the W/Z manifolds,unless you use flanges for spacers.
507OLDS is offline
Old February 10th, 2014, 12:01 PM
Would it be easier to weld up the divider?
Fun71 is offline
Old February 10th, 2014, 12:04 PM
507OLDS's Avatar
You can make it thicker too.
507OLDS is offline
Old February 10th, 2014, 06:32 PM
young olds's Avatar
can you weld up the area after machining has been done to the heads?
Old February 10th, 2014, 07:49 PM
507OLDS's Avatar
I would rather weld the center,to make it flush,instead of milling the surface back. My heads were old stock eliminator heads,that someone else had already milled. I think the center should be widened or thicker,to make a better transition into the header.
507OLDS is offline
Old February 10th, 2014, 07:58 PM
young olds's Avatar
I meant will the other areas of the head need resurfaced after welding on The head?
Joel
April 26th, 2017 01:37 PM
Shaunbo13
January 27th, 2014 04:18 PM
toms vista
October 3rd, 2010 09:13 PM
feistyfeist
May 23rd, 2007 01:30 PM
Quick Reply: milling exhaust side on iron heads
