Hooker vs flowtech???
Old Feb 11, 2014 | 04:47 PM
19cutlass71supreme's Avatar
I'm looking at these two headers for my 71 cutlass supreme. Both under $200
The choices are flowtech ceramic and hooker painted.
The hookers on summit say they don't fit the cutlass but I've been told that many people used them anyways and didn't have a problem with them.
Any advice between these 2?
Also, can I use 455 headers on the 350? Because it seems that the $200 headers are for the 455 but it's the internet...
Old Feb 11, 2014 | 06:02 PM
Oldsmaniac's Avatar
I put a set of flowtech headers on a 72 Cutlass conv with 455. They slid in easy and stock starter bolted up fine but driver's side 2 lower tubes were resting on the frame and some severe sledging was required for fit. Dont know about hookers for the 72 and I doubt 455 headers would work on the 350. Yes they will bolt up but the 455 is wider than the 350.
Old Feb 11, 2014 | 06:18 PM
70cutty's Avatar
Beer Connoisseur
I always liked hookers..........headers. I have them on my 70. They fit fine, PIA to install but no problems with frame or starter. However if you are planning on lowering the car they hang pretty low. My 70 is lowered and it's not speed bump friendly. If I was doing it again i would get shorties. 455 headers will be way too low.
Old Feb 12, 2014 | 08:20 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Don't get the flow tech's. they're not very good. The collectors always point in goofy directions. One will be angled down slightly, or sometimes left, sometimes right. Real pain in the **** trying to bolt straight exhaust to crooked headers.
Old Feb 12, 2014 | 09:06 PM
The_Jeremiah's Avatar
I put hooker headers on my 69 before I got rid of it, I had to move the brake junction block but other than that, no complaints. When It comes to headers you get what you pay for... If you can get a set of coated and a set of painted for the same cost, id go painted just because the headers must be of better quality.
Old Feb 13, 2014 | 05:06 AM
Smitty275's Avatar
Engine Builder
Go with the Hooker set. If nothing else the stickers are cool. Have the paint stripped off and repaint with Rustoleum Hi Temp primer and color of choice. Follow the directions to a T. The heating and cooling off periods are crucial to making it last and not burn off. Once its properly cured it will last a very long time.
Old Feb 14, 2014 | 02:39 AM
FinOldsMan's Avatar
I got Flowtech on my 66 F-85 455 block and i have to raise the block one inch to make them fit.
Old Feb 14, 2014 | 04:15 PM
Smitty275's Avatar
Engine Builder
That's because the 64-67 chassis is different than the 68-77 which is what they all make them to fit.
Old Feb 17, 2014 | 08:24 AM
507OLDS's Avatar
You can also get the Hookers in the 1 7/8" primary tubes.I think the flowtechs are 1 3/4".
You have to move the brake valve on top of the frame with any of these headers,to provide more clearance.You will still get one side sitting slightly lower,with either set,but it seems like the Hookers make the collectors end up even with each other,going under the crossmember,so your whole exhaust isn't crooked.
Old Feb 18, 2014 | 06:42 PM
Thanks for all the info guys
Old Mar 12, 2014 | 12:09 PM
HWYSTR455's Avatar
If you look at my build thread, you will see how I had to doctor the Flow Techs to make them fit, and one side did hang lower than the other (passenger). The outlets did point properly though.
I changed them out for Hookers and they fit much better.
Old Mar 13, 2014 | 05:43 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Flowtech headers also rust like hell and needed double gaskets to seal. Mine were the 1 5/8" primary A body headers and were ceramic coated. Rust pin holes everywhere and peeling ceramic within 2 years.
kevin.horton
May 30, 2012 07:12 AM
L69
Jan 9, 2012 05:59 PM
Mark71
Jun 27, 2011 09:43 PM
defiant1
Oct 21, 2010 02:41 AM
