Engine Diaper
Engine Diaper
I am in need of an engine diaper for the upcoming racing season and I thought I remembered there was someone in the Olds racing community that had been making Olds specific engine diapers a few years back and wanted to know if that outfit / person is still making them and who that is?
Let me know if you have info on this that can help or if you have used a big name diaper that fit ok with an 8qt pan and still using motor mounts..
Grant
Grant
Thanks for the replys. Spoke to Mike Roth at DRE and he wants me to send my oil pan and not just measurements, Andy suggests I make my own, and I dont see how a SBC diaper would ever work on a 455 as the Chevy clock is so much smaller and gathering all that extra material would be a pain. The big block Chevy rear sump with motor mount cutouts is the closest I have found but the motor mounts on a BBC are in a very different position than on an Olds so I am still researching / huntimg for something viable.
If you would like some measurements. Mine is still off the motor.
my motor is at the machine shop.
Which the weather isn't being kind on my days off.
Chadman bought the same one.
He pointed me with the information for mine.
Willie devoe built it. From America speed built it.
and yes it could be in the 9s. if you look at the olds list ,you may find his name on the list.
The moroso oil pan it a bit wider than a stock old pan.
and it adjustable.
and it adjustable.
