Eagle Rods vs Stock Rods Weight
Old Dec 24, 2020 | 11:59 PM
pettrix's Avatar
What is the weight difference between an Eagle H Beam rod vs stock Olds 455 rod?
Old Dec 25, 2020 | 03:32 AM
cutlassefi's Avatar
30-40 grams normally, Eagle is actually lighter.
Old Dec 25, 2020 | 09:29 AM
pettrix's Avatar
So an Eagle rod is about 30-40 grams lighter than a stock rod?
Old Dec 25, 2020 | 02:03 PM
cutlassefi's Avatar
Uhhh yeah. I guess I wasn’t clear on that? Thought I was.
Old Dec 25, 2020 | 04:25 PM
VORTECPRO's Avatar
Would you agree you can get 40 grams out of a stock rod?
Old Dec 25, 2020 | 04:43 PM
pettrix's Avatar
So when rebuilding a 455, it's really not worth the time and money to try and reuse factory rods. Trovato's book states that factory forged rods are good for throwing into the garbage as they are very unreliable above 450HP. The big end never remains true.
The Eagle rods are around $500 so it seems like a no brainer. They are lighter and much stronger than factory rods.
Old Dec 25, 2020 | 04:53 PM
cutlassefi's Avatar
That’s the biggest problem, very hard to get them to repeat once they’re apart and back together.
Old Dec 25, 2020 | 05:27 PM
VORTECPRO's Avatar
On my last 455 build I used Eagle rods, I had to equalized them, I resized them, I had to pin fit the small end, I had to modify the bearing tangs, I then had a decent set of rods to use.
Old Dec 25, 2020 | 06:25 PM
pettrix's Avatar
Pulled the engine out and dropped the pan. This was at the bottom of the pan. Haven't pulled the heads off yet. It was running but was burning oil and blowing smoke.
Any guesses what that chunk of aluminum is? Piston?
Old Dec 26, 2020 | 08:03 AM
Bernhard's Avatar
Very informative thanks for posting.
Old Dec 26, 2020 | 08:27 AM
cutlassefi's Avatar
As I said before, you should’ve sent them back if they were really that bad.
And as is typical with your political style, you don’t always tell the whole story. You should’ve noticed by now that virtually all aftermarket bushed rods will come thru on the tight side. That’s fully intentional in case you haven’t figured that out yet.
I also have to wonder if you used the right rod bearing. If you use the Clevite HN they always fit perfectly.
Old Dec 26, 2020 | 08:49 AM
pettrix's Avatar
This is the upper rod bearing. Is this "normal" wear or is the factory rod big end having issues?
Old Dec 26, 2020 | 09:33 AM
cutlassefi's Avatar
No. Also looks like either detonation or an out of balance situation.
Old Dec 26, 2020 | 11:55 AM
That bearing and the chunk of aluminum seem to point towards detonation.
Old Dec 27, 2020 | 07:16 AM
VORTECPRO's Avatar
The big end of the rods were not tight or low on the spec, they were over the high side of the spec, which is sometimes the case with Scat or Eagle rods. Now its possible I have different measuring equipment (Sunnen) than you which could possibly give a different measurement than you could be getting. As far as the tangs go, I would never force a bearing into a tang, that was the reasoning behind remachining the tangs. And the question I have is: is it a good idea to run a Clevite HN bearing on a cast crank? At the same time I equalized and resized the rods I was able to oval hone the rods a big plus in my opinion. I don't send low end aftermarket parts back, I don't have the time, I have put together a operation that allows me to fix or modify parts to meet my expectations. The results speak for themselves.
Old Dec 27, 2020 | 07:41 AM
cutlassefi's Avatar
I mentioned the small ends typically needs attention on all aftermarket rods. So the small end was over the high spec and you had to rebush them? “I had to pin fit the small end”. That’s what you said initially. So that wasn’t the case or was it? Your statement is confusing based on my initial point.
As far as HN bearings go for an Olds, when you use a CAST Eagle crank you HAVE to use then cuz of the radius. And using them on a regular N crank wouldn’t be any different. The rod is what flexes as much as anything. So, if you’re using a good solid rod and your clearances are correct for the application, then you should have 0 issues. I’m speaking from first hand experience because I’ve done dozens of Olds 455 builds. You’ve done two, but apparently you’re now an expert. I gotcha.
And I guess you can’t take 5 minutes to call Eagle, tell them you have a bad set, order another right away then return the bad ones when you have a few minutes? You know when you’re not on here spewing trash? Oh that’s right, you don’t make any money if you don’t have to “fix” something.
Old Dec 27, 2020 | 08:05 AM
VORTECPRO's Avatar
So the small end was over the high spec and you had to rebush them? That’s not what you said initially.
Mark
Its good to see you back feeling good! You are right the small end is undersize, its the big end that I usually find out of spec (BIG).
As I sit here eating breakfast I've tried to count the 455 Oldsmobiles I've built from the ground up, and I come up with 26 builds. I will proudly state with (0) (ZERO) bearing failures.
"You know when you’re not on here spewing trash? Oh that’s right, you don’t make any money if you don’t have to “fix” something"
CutlassEFI.
LOL. Ok I'am going to take a stab at this, Think I know what your trying to say....................its like breaking cullasefi code LOL.
So what I think your saying/posting............When I find a part I'am not comfortable using in a build, I fix that part and charge the customer? I think thats what your saying/posting...... right, your dam right thats what I do, of course I would call the customer and ask them what they want me to do first.
I truly do appreciate your point of view on here and would never want you to change!
Old Dec 27, 2020 | 09:36 AM
cutlassefi's Avatar
Mark
I am thank you.
Then if the small end was small and the big end was big then say that, consistently. Your sentence/thought structure needs some help to say the least. Or you’re just practicing to become a politician.😀
For the record, some of your posts suggest unfamiliarity with certain scenarios. I’m just commenting on your own statements that’s all.
Old Dec 27, 2020 | 09:47 AM
VORTECPRO's Avatar
Talking
[QUOTE=cutlassefi;1304108]Then if the small end was small and the big end was big then say that, consistently. Your sentence/thought structure needs some help to say the least. Or you’re just practicing to become a politician.😀
For the record, some of your posts suggest unfamiliarity with certain scenarios. I’m just commenting on your own statements that’s all.[/QUOTE
See post 15 pretty clear what I said/posted.
Old Dec 27, 2020 | 11:10 AM
cutlassefi's Avatar
Reread post # 8 then reread post #15 and tell me they’re saying the exact same thing. They don’t. You omitted clarification regarding the small end.
You’re consistently inconsistent. But that’s fine. Now I know not to take your posts at face value, no problem, really.
Done with you here.
Old Dec 27, 2020 | 11:59 AM
pettrix's Avatar
So when you get the Eagle rods, what bearing manufacturer should you use?
pettrix's Avatar
Could "over-revving" cause the piston ring land to break off?
Old Dec 27, 2020 | 01:16 PM
Bernhard's Avatar
VORTECPRO
Could you explain the benefits of oval honing a aftermarket rod?
What was the added cost to blueprint the rods?
When building a big block Oldsmobile with a factory weight piston and rod what bearing clearance would you run?
Using a stock rod?
Using a aftermarket rod?
Bernhard
Old Dec 27, 2020 | 02:25 PM
cutlassefi's Avatar
Based on what your rod bearings looked like as well as this piston I’d say you had pretty severe detonation.
Old Dec 27, 2020 | 04:27 PM
VORTECPRO's Avatar
Originally Posted by Bernhard
VORTECPRO
Using a stock rod?
Bernhard
1. Could you explain the benefits of oval honing a aftermarket rod?
It gives you the ability to tighten the vertical clearance on a large rod journal engine.
2. What was the added cost to blueprint the rods?
I charge 250.00 on a aftermarket set of rods to oval hone, center to center, pin fit small end.
3. When building a big block Oldsmobile with a factory weight piston and rod what bearing clearance would you run?
I don't know I use light weight components and lighten them from there. Battenrunner had heavy aftermarket components and ran .0028 on the rods.
4. Using a stock rod?
I have used .0028 with production Olds rods. ZERO problems.
You have to understand my way of measuring might be different than someone else. I know with my Buick I fine tuned the bearing clearance over time.
Old Dec 27, 2020 | 04:33 PM
Bernhard's Avatar
Thanks for the reply very informative as usual !
Old Dec 27, 2020 | 04:36 PM
VORTECPRO's Avatar
Your welcome!
Old Dec 27, 2020 | 04:49 PM
Bernhard's Avatar
This is engine builder specific and it has to do with how hard the bearing surface is. A harder bearing can take more load but is harder on the crank surface.
A soft bearing is kinder to the crank surface. The majority of Olds crankshafts are cast and thus softer than a steel crank. You can have the cast crank nitrated to add surface hardness.
Old Dec 27, 2020 | 05:09 PM
VORTECPRO's Avatar
I used these, Battenrunner put the parts together on my last build.
Sealed Power 8-3345P .010
Old Dec 27, 2020 | 05:20 PM
pettrix's Avatar
This is what came off the current factory rod. I believe they are Federal Mogul?
Old Dec 27, 2020 | 05:24 PM
  #31
pettrix's Avatar
If making around 460HP, would you stick with factory rods or go Eagle?
Trovato in his book says factory rods are good up to 400HP, after that, they belong in the trash.
Old Dec 27, 2020 | 06:02 PM
  #32
VORTECPRO's Avatar
I think you should go aftermarket. I also believe if Bill oval honed rods he wouldn't need .004 rod clearance.
Old Dec 28, 2020 | 04:07 PM
  #33
pettrix's Avatar
Are the Speed Pro pistons any good?
https://www.summitracing.com/parts/s...ake/oldsmobile
Old Dec 28, 2020 | 04:40 PM
  #34
VORTECPRO's Avatar
I wouldn't do that, you can't trust the ring lands or much any thing else on those pistons. If your going to build a engine do it right, get good parts find a quality machine shop in your area. Where are you in Utah?
Old Dec 28, 2020 | 05:50 PM
  #35
cutlassefi's Avatar
No, used to be all we had to choose from but much better stuff out there now.
Old Dec 29, 2020 | 08:10 AM
  #36
pettrix's Avatar
I was looking at JE Pistons and CP-Carrillo pistons.
Any suggestions?
Old Dec 29, 2020 | 09:15 AM
  #37
cutlassefi's Avatar
Any suggestions?
Can’t go wrong with either one. But both will give you 9.75-10.0:1 depending on head cc etc.
Old Dec 29, 2020 | 12:11 PM
  #38
pettrix's Avatar
Where are the SpeedPro pistons now made?
The olds 1990's TRWs, were they made in the USA back then?
Old Dec 29, 2020 | 01:21 PM
  #39
cutlassefi's Avatar
Most of the Speed Pro pistons are now made in India. Says it right on the box.
Old Dec 29, 2020 | 08:33 PM
  #40
pettrix's Avatar
Is it a good idea to rerun the Cast Nodular factory crank or get the Eagle Cast Steel crank?
