Champion Radiator, aluminum shroud, & electric fan - kit $359.98
Anyone have any experience with the Champion radiators kit? I know the radiators are fantastic because I just put one in the 'vert...just wondered if anyone has their aluminum shroud and electric fans.
3 row radiator, aluminum shroud, 2-14" electric fans - $359.98
http://www.championradiators.com/page/458473582
Hey Steve, first of all thank you for mentioning that the radiator is great, because that's exactly what I wanted to know in another thread, I might buy one, too!
I don't have any first hand experience with the shroud and fans, but I didn't read a lot of good things about them, because the shroud blocks too much air to be effective!
Maybe this is a method to consider?!
http://www.cadvision.com/blanchas/54...FanShroud.html
Thanks again!
Thanks again!
I find the G body 3 core is barely big enough for my 403. The drain **** is in an ignorant spot and buggered up too. Go 4 core, if you do get one. I am thinking the Griffin Dominator, next time out.
I found the same problem with the Summit-branded aftermarket aluminum radiator I used for my 67 442. The petcock hit the LH frame horn when the radiator was installed in the stock location. Even using a plug instead of a petcock wouldn't help because there wasn't enough room to get a wrench on it. So, I moved the mounts enough to the right that I could open the petcock. It was a PITA getting the fan shroud and top plate lined up then, so I had to slot some of the mounting holes. It all works fine now.
I know I'm gonna get a radiator from them but I was thinking about the fans too...but maybe not if they're not any good.
We put a 3 core in the convertible and it cruised for 200 miles with a 180 thermostat and never broke 190...with the A/C on the whole way. I think they are pretty good radiators and it fit in the factory location with a factory 4 core top plate.
I have the 4 core Champion Radiator for my LS swap.
I'm not using their cheap low CFM fans they overcharge for.
I'm using a 90's Ford Taurus fan.
4000 cfm junkyard $40 fan baby. My write up on Nastyz28
that or the Ford Windstar fans are great inexpensive options you can get new for ~$80.
Giddy
March 10th, 2009 11:37 AM
