Broken Rocker ! What caused this ?
Old Feb 10, 2021 | 03:56 PM
rickw30's Avatar
Bought a 455 off Craigslist and this is what I found. Can any one tell me what may have caused this ?
Old Feb 10, 2021 | 04:10 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Something very bad. I had a push rod bend and break, along with the guide plate. The Scorpion rocker is still useable. Yikes.
Old Feb 10, 2021 | 05:47 PM
Schurkey's Avatar
Too much press-fit on the pushrod socket?
What was the lift, and which valve springs were used? Interference with valve guide/valve stem seal and retainer?
Old Feb 10, 2021 | 05:53 PM
rickw30's Avatar
I haven't removed heads yet but nothing looks unusual topside.
Old Feb 10, 2021 | 09:27 PM
grannys442's Avatar
Rotate engine and see if rocker body is hitting the polyloc at full lift.
Old Feb 11, 2021 | 05:25 AM
thewman's Avatar
Looks like your thread got hijacked by a different rocker set. Rick when you bought the engine from the ad, did the seller say who built the engine?
Old Feb 11, 2021 | 07:48 AM
67OAI's Avatar
Old(s)GuysRule
Post pics of the bottom side of that rocker. Check for valve spring coil bind and/or inadequate retainer to valve guide/valve stem seal clearance.
Old Feb 11, 2021 | 08:04 AM
boese1978's Avatar
IMO, not enough clearance between the bottom of the rocker and the mounting stud, let s see pic of the bottom of the rocker.
Old Feb 11, 2021 | 12:42 PM
rickw30's Avatar
He only said he had it built by a guy down in Florida a couple years back.
Old Feb 11, 2021 | 12:46 PM
rickw30's Avatar
Bottom side of rocker.
Old Feb 11, 2021 | 03:15 PM
fleming442's Avatar
What's the valve tip look like? Narrow, pattern, centered in the stem is good. If the rocker roller fell off the stem, you got problems.
Old Feb 11, 2021 | 04:49 PM
It does not look like any binding on the stud. Maybe a defective rocker? Strange on such a clean break.
Old Feb 15, 2021 | 03:17 AM
fleming442's Avatar
Could just be Scorpion junk, too
Old Feb 15, 2021 | 05:21 AM
Not a fan? They are US made and I thought they also make rockers for companies like Harland Sharp. Maybe the owner is FOS, thought he claimed they made most of the name brand rockers. I seriously had a pushrod bend and break, the rocker is still useable.
Old Feb 15, 2021 | 05:45 AM
fleming442's Avatar
I don't know. Are they all cast? I thought the better ones were billet. Of course, I have no room to talk with my Mondildo purple HS wannabes,!!! 🤪
Old Feb 15, 2021 | 07:51 AM
67OAI's Avatar
Old(s)GuysRule
Harland Sharp are billet and are made in house dating back to the 1960s; they also were making some of the purple rockers for Mondello years ago when Joe was still around.
Old Feb 15, 2021 | 08:53 AM
Well, only a decade old thread...
First, none of these are cast or "billet". They are machined from an extrusion.
Second, the marks on the valve end of the rocker sure look like it was hitting something and binding up, which would explain the fracture.
Old Feb 15, 2021 | 10:59 AM
wr1970's Avatar
Hmm so if lifter was stuck roller tip was not in position! Nah Joe I think maybe damaged happened as pushrod was bending to get damage on tip by roller. Jmo
Old Feb 15, 2021 | 05:40 PM
fleming442's Avatar
That's comforting. I bought them when Joe was around, but Lynn Pullmyfinger was doing sales. They were advertised as Harland Sharp's, but came in a plain white box with a sticker over the original part number sticker.... What else would you think other than marked up, Ding How garbage?
Old Feb 15, 2021 | 07:30 PM
That is good, the guy from Scorpion was probably FOS. Yeah, my next set will be Harland sharp. Scorpion do have two levels of strength, pretty sure mine and probably this one is the lower level.
Old Feb 16, 2021 | 05:00 AM
rickw30's Avatar
The roller on the tip doesn't seem to have much clearance.
Old Feb 16, 2021 | 05:57 AM
TripDeuces's Avatar
All the above and coil bind too
Old Feb 16, 2021 | 08:02 AM
wr1970's Avatar
I agree.
ChevyZ06
Feb 10, 2021 07:24 PM
kevdz79
Body work
Mar 31, 2019 07:15 PM
2oldsguy
Jun 2, 2018 06:28 PM
ah64pilot
Dec 16, 2012 10:37 PM
