Anybody using PRW 0230201 Stainless Rockers?
Old Jun 8, 2016 | 06:59 AM
RROLDSX's Avatar
I won't be buying HS rockers regardless of the recommendations but thanks anyway. Anyone tried these out?
Do the heads need to be machined or modified in anyway?
Thanks in advance.
Randy
Old Jun 8, 2016 | 07:59 AM
coppercutlass's Avatar
Chevy budget Olds powered
I used the Ford stainless rockers don't know the number but they worked great.
Old Jun 8, 2016 | 08:03 AM
RROLDSX's Avatar
Yes, these are for SBF and Olds engines. Did you have to do any mods or machining? Are you using guide plates?
Thanks,
Randy
Old Jun 8, 2016 | 10:11 AM
I'm using he comp cams guide plates and around studs. Used the smaller diameter stud. No issues here. Did not machine the pads for the studs so I had to use slightly longer pushrods. Pattern was damn near perfect.
Old Jun 8, 2016 | 10:54 AM
RROLDSX's Avatar
Thanks Copper, I'm assuming you used the stock diameter studs as they're designed for. Appreciate the input. I'm going to order them.
malibu406
Jun 18, 2018 06:24 AM
Red350DropTop
Oct 19, 2015 08:27 AM
Bernhard
Nov 22, 2012 08:01 AM
TennesseeDelta
Apr 7, 2008 02:02 AM
ToronadoGuyDenver
Nov 20, 2007 07:09 AM
