529 Olds build
Old Oct 28, 2022 | 04:36 PM
  #41
cutlassefi's Avatar
Originally Posted by chadman
It won't make 1000hp. Hoping for at least 900hp.
If anyone can squeeze that out of it you can. First class as always.
Old Oct 28, 2022 | 06:06 PM
  #42
Bernhard's Avatar
Awesome build looking forward to seeing it in your car making passes.
Old Oct 28, 2022 | 07:32 PM
  #43
pettrix's Avatar
The cost of the build NORTH or SOUTH of $40k?
Old Oct 29, 2022 | 07:25 AM
  #44
Tugla's Avatar
Yes, I remember. You were headed to Drag Week. Was nice meeting you. I didn't know your screen name on here.
drag week was awesome...I did meet up with Bruce and Tracy there.
Old Oct 29, 2022 | 01:47 PM
  #45
chadman's Avatar
Thank you.
Old Oct 29, 2022 | 02:24 PM
  #46
chadman's Avatar
Per request:
Old Oct 29, 2022 | 02:28 PM
  #47
HighwayStar 442's Avatar
Thanks Chad! Realy like how they worked the runners into the carb flange.
Old Oct 29, 2022 | 08:28 PM
  #48
olds80six's Avatar
The Marcella intake works incredibly well. Milan had that built around 2011-ish. Propelled his footbrake 12-1 compression big block to the low 9.40s.
Looking forward to the results of this build.
Old Oct 31, 2022 | 09:29 AM
  #49
chadman's Avatar
Old Oct 31, 2022 | 05:37 PM
  #50
Nice! Three plugs on bottom, to bolt pan on? The punch out on the front passenger side for oil pump?
Old Nov 1, 2022 | 09:04 AM
  #51
chadman's Avatar
Yes, the three plugs are to access the pan rail fasteners. The kick out is to give the oil slinging off of the crank a place to go which reduces windage, increasing horsepower.
Old Dec 5, 2022 | 02:01 PM
  #52
w30442's Avatar
Any updates on your new power plant Chad. Awesome work by the way
Old Dec 6, 2022 | 01:50 AM
  #53
wr1970's Avatar
Holy moly that's going to be a monster!
Old Dec 6, 2022 | 03:57 AM
  #54
chadman's Avatar
I got busy with a few other things. I plan to get it finished up here shortly. Will update soon.
Old Dec 10, 2022 | 07:33 AM
  #55
DR_DAN's Avatar
Yes these can go 560, probably more. This is the same bore as the 560 combination but with less stroke. I'm not a big believer in the huge strokes and feel the heads will have a hard enough time keeping up with 529 CID.
Exactly what I believe myself. Never have been a big fan of a lot of stroke. Looking good Chad!!!
Old Dec 15, 2022 | 08:10 AM
  #56
chadman's Avatar
Progress:
Old Dec 17, 2022 | 02:03 PM
  #57
chadman's Avatar
Goes on the dyno Friday
Old Dec 17, 2022 | 02:10 PM
  #58
Tugla's Avatar
congrats man, good luck....
where are you dynoing it?
Old Dec 17, 2022 | 04:08 PM
  #59
v8al's Avatar
Registered Olds Owner
Nice Christmas present!
Old Dec 17, 2022 | 05:40 PM
  #60
Bad ***!! Good luck on Friday! Painting engine, if so what color? Ignition wires laid out the way it should.
Valve covers by? Almost looks like what Andy sells. Having trouble finding any, other than his. Bernard Mondello ones, he no longer sells.
Old Dec 18, 2022 | 04:01 AM
  #61
chadman's Avatar
Badman Racing Engines
Old Dec 18, 2022 | 04:04 AM
  #62
chadman's Avatar
The engine is painted, cast iron gray. Valve covers are Moroso fabricated. That is what Andy sells as well although I didn't get these through him.
Old Dec 18, 2022 | 05:48 AM
  #63
chadman's Avatar
A closer look at the VCs for you Highway Star:
Old Dec 18, 2022 | 09:11 AM
  #64
New2oldsw30's Avatar
Chad, good luck, I think your run your 8.80's with that and some of the people involved.
Track only, purpose built car????
Old Dec 19, 2022 | 07:33 AM
  #65
chadman's Avatar
Yes track only. The car is technically street legal but not very streetable with 16:1 and a 5500 stall converter.
Old Dec 19, 2022 | 07:48 AM
  #66
fleming442's Avatar
Your pumps don't carry C16?
Old Dec 19, 2022 | 07:54 AM
  #67
Weight? What should this motor rpm to? Probably not enough converter.
Old Dec 19, 2022 | 09:12 AM
  #68
chadman's Avatar
I was just throwing an approximate number out there. The converter will be whatever the engine wants. I expect it to peak around 7200 and hopefully carry to 7800.
Old Dec 19, 2022 | 09:14 AM
  #69
Ok thanks. I know where we would be if those numbers are them.
Old Dec 21, 2022 | 04:55 PM
  #70
w30442's Avatar
Would this be the highest HP RR headed engine or fastest down the track ?
Old Dec 22, 2022 | 04:41 AM
  #71
fleming442's Avatar
Still going to make it tomorrow with all the winter death falling from the sky?
Old Dec 23, 2022 | 10:45 AM
  #72
VORTECPRO's Avatar
Nice build, look for to the dyno/track test!
Old Dec 23, 2022 | 01:31 PM
  #73
chadman's Avatar
Dyno session went well today. First sheet is on Sunoco Maximal 116 (non-oxy). Second sheet is on Q16.
Old Dec 23, 2022 | 02:08 PM
  #74
oldsmoboogie's Avatar
WOW, that is impressive!
Old Dec 23, 2022 | 02:40 PM
  #75
Duh's Avatar
Duh
Nice.​
Old Dec 23, 2022 | 03:24 PM
  #76
VORTECPRO's Avatar
Chad
Is the air being pulled from the outside or in the shop the carb will see?
Old Dec 23, 2022 | 04:01 PM
  #77
chadman's Avatar
Inside room temp.
Old Dec 23, 2022 | 04:04 PM
  #78
fleming442's Avatar
Hell. Yes. Nice work, man!
Old Dec 23, 2022 | 05:27 PM
  #79
VORTECPRO's Avatar
It looks like you could be over 900 HP during the whole run.
154 MPH @ 3200 = 900 HP
1320/154 = 8.57
Thats what it should run.
Who builds your transmissions?
Old Dec 24, 2022 | 08:50 AM
  #80
Bernhard's Avatar
WOW !
Impressive build Chad with great attention to detail. Looking forward to seeing the beast in the car going down the track.
