355 over 6500 rpm's?!
Old Oct 8, 2021 | 01:25 PM
  #161
antzahh's Avatar
I don't mess with autos too much, but aren't the holes threaded on the converter side?
if it's a nut and bolt, you might be able to increase it. You're in Europe, right? Throw some metric at it!
No threads in that converter and yeah i would but 10mm is too small and 12mm is too big, i managed to find inch threaded bolt?? and that reads 11mm so that's close enough, I just need to wait till monday if i don't want to drive too far away from my town to get couple bolts and nuts
Old Oct 8, 2021 | 02:45 PM
  #162
fleming442's Avatar
11mm is 7/16" 🤪
Old Oct 8, 2021 | 06:02 PM
  #163
OLDSter Ralph's Avatar
How is it bolted to the torque convertor ?
Old Oct 8, 2021 | 06:56 PM
  #164
antzahh's Avatar
11mm is 7/16" 🤪
I was thinking the same..
Old Oct 8, 2021 | 06:57 PM
  #165
antzahh's Avatar
Bolt, washer, nut
Old Oct 14, 2021 | 07:01 AM
  #166
antzahh's Avatar
I did change the bolts and voilá, no clacking or knocking sounds anymore or atleast i didn't heard anything suspicious while i was doing about lets say 10-15miles test drive.
Old Oct 14, 2021 | 04:06 PM
  #167
fleming442's Avatar
Winner, winner, chicken dinner!!!!
Old Oct 14, 2021 | 04:57 PM
  #168
olds 307 and 403's Avatar
Out of Line, Everytime😉
Always nice when it is an easy fix. I have never used the bolt and nut style, always used the lug style converters. Obviously they can work with an Olds V8, good to know, some have claimed otherwise.
Old Nov 26, 2021 | 04:51 AM
  #169
antzahh's Avatar
It's been a while but there's something for you guys..
Old Nov 26, 2021 | 09:56 AM
  #170
You need to change your privacy settings.
Old Nov 26, 2021 | 12:45 PM
  #171
antzahh's Avatar
Fixed!?
Old Nov 27, 2021 | 05:28 AM
  #172
Originally Posted by antzahh
And that sounds expensive..
Oh, it was. Actually the 330 crank, even with the lighter pistons was $1500+ Canadian for internal balancing, I just said F it, over $3K for the machine work, an ugly bill but it is paid. The original shop didn't hone fit the pins for floating on the Molnar rods to Mahle pistons, the shop doing the balancing is doing them. The new Edelbrock heads are going on too. Yes, I can see it now, sounds really mean.
Old Nov 27, 2021 | 03:37 PM
  #173
antzahh's Avatar
So that fit hone is included in that $1500? Still sounds really, really expensive.. I think that those iron heads which i have was in the similar price range with new valves n stuff..
Old Nov 27, 2021 | 07:10 PM
  #174
Nope, it took 5 slugs, Mallory is dam expensive. Yeah, a set of rebuilt irons heads would be similar. I am going with the new Edelbrock heads. Your car should haul ***.
Old Nov 28, 2021 | 11:15 AM
  #175
antzahh's Avatar
Oh yeah those slugs explains is all.. And yeah thanks! I think Im going to have some more interesting footage in the next summer
Old Mar 23, 2022 | 08:39 AM
  #176
antzahh's Avatar
First test drive yesterday and everything went fine until engine got its operating temperature and i kicked the throttle a bit harder for the burnout, huge one bang from exhaust and after that a couple more loud ones... There was a rhythm for the pops and bangs. Went back to shop at idle and let her cool down, after that idle/throttling was decent, not huge pops or bangs.
Today checked the valve lash and they were good, not too tight anywhere, checked compression pressure, a hair over 14 bars all over. Also pulled all spark plugs and tested couple ones for the spark, weak yellow spark, cant really even hear the ZAP.
Altough most of the plugs looked fine, couple were more black than others and one was wet.
All new MSD 8mm streetfire wires and also all new AC Delco R45S Plugs.
Old Mar 25, 2022 | 06:26 AM
  #177
For one 200 psi is pretty high, it sounds like pinging, I experienced the same at 180 psi on 91 octane. Make sure you only run the highest premium fuel you have there. Get your carb tuned with a wideband and go through and replace anything questionable in the ignition system. Consider a colder plug like R43 if you prefer AC Delco's. Slowing the timing curve, limiting the vacuum advance and running the cold NGK 5671-8 plugs eliminated my pinging. Good luck.
Old Mar 25, 2022 | 09:14 AM
  #178
antzahh's Avatar
Yeah that maybe sounds a bit high but what i've read is that the guys who are serious engine builders has tought that even 12:1 compression is doable on street and even with pump gas. Isnt that kinda compression giving you a whole lot more cylinder pressure than for example 10.5:1? And yes im only using premium.
Today I have checked things listed below:
New plugs
New wires
New battery
Power cable to distributor is getting 12v
Coil OHM seems good
Improved ground to engine
Improved ground to battery
That Progression Ignition Distributor manual points that I CANNOT use Non-Resistor plugs and my plugs are with resistors. I CANNOT use solid core wires. Spiral core/Supression wires are acceptable and Im usin ones which have Spiral core.
Old Mar 25, 2022 | 09:49 AM
  #179
fleming442's Avatar
I wouldn't worry so much about that. Try putting some race gas in; see what happens. 12.5:1 can be done on pump gas, though.
Old Mar 25, 2022 | 10:19 AM
  #180
antzahh's Avatar
I dont think that would fix the yellow weak spark?
Old Mar 25, 2022 | 11:09 AM
  #181
fleming442's Avatar
Ha! You're right. What do you have for ignition? I just had to replace the pickup in my MSD Pro Billet. Wouldn't even start.... after getting gas. Drove in to the station fine!
Old Mar 25, 2022 | 01:26 PM
  #182
antzahh's Avatar
Progression Ignition HEI
Old Mar 25, 2022 | 02:24 PM
  #183
fleming442's Avatar
Do you have the ground strap on the coil (under the cover) and grounded? It shouldn't matter, but would rule it out. Other defective components, the power wire should be 12ga, and hooked directly to the pink on the ignition switch or bulkhead connector.
Operating voltage should be above 13.5v (14.4 nominal, above 2000 rpm or so).
Old Mar 25, 2022 | 05:03 PM
  #184
antzahh's Avatar
Everything on the distributor is untouched and it should be "plug and play" so yeah im pretty sure that ground is okay also in the distributor cap/inside if you meant that.
Earlier today i took off the coil cap and checked its ohm readings, they were fine. Also checked the ground straps etc.
Old Mar 25, 2022 | 06:01 PM
  #185
What are you running for timing? Seriously, the colder plugs do help with pinging. The colder AC Delco R43S might be all that is needed with the proper timing curve. Yes, modern engines run 12.5 to 1 but use many tricks to do it, including much better combustion chambers than our 1964 chambers.
Old Mar 26, 2022 | 03:57 AM
  #186
fleming442's Avatar
The ground strap usually just goes to the "inner" set of terminals. I usually add an extra to the car from the "outer" terminal, between the power and tach.
Old Mar 26, 2022 | 06:42 AM
  #187
coppercutlass's Avatar
Chevy budget Olds powered
Initial timing , timing curve and engine load have alot to do with cylinder pressure spikes which is when you have pinging or detonation. I run 10.25 to 1 and have ran 91 octane I'm a pinch with no issues.
Old Mar 26, 2022 | 07:27 AM
  #188
fleming442's Avatar
I'm locked 36⁰ on 93 with substantial compression. Doesn't ping or run on, but it used to with the carb. Tune has a lot to do with it, too.
But, the weak yellow spark, tho.....
Old Mar 26, 2022 | 08:29 AM
  #189
Yeah the tune is everything that's where using an AFR gauge really helped . My car cruises at about 12.5 13.0 . Not rich enough to wash things out but fat enough to be safe.
Old Mar 26, 2022 | 08:53 AM
  #190
I wonder what the Progression Ignition distributors use for a coil? Maybe a MSD or Accel coil might be a good upgrade with a low ohm MSD 8412 coil bushing. It also doesn't mention the module amperage output except that it is good to 10,000 rpm.
Old Mar 26, 2022 | 11:01 AM
  #191
I am still running an HEI . Now another mention I will make.. if you have any and I mean any digital ignition problems make sure you don't have RFI. When I installed my digital rev limiter above 5k rpm it really labored like it was taking timing out too soon. I placed it in the car and made an aluminum cover for it to sheild it . Just some food for thought. Alot of people quickly install digital products and our cars are a playground for RFI.
Old Mar 26, 2022 | 10:25 PM
  #192
Bernhard's Avatar
MSD and Accel are not what they used to be !
Old Mar 27, 2022 | 06:31 AM
  #193
I don't disagree with that statement somewhat, so many transfer of ownerships the last few years. I have a 25 year old Accel Super coil, still works. I bought one of the last red and white lead Accel Brute Thunder coils in stock a couple of years back. It is a nice looking coil, supposedly another 3000 volts over the regular HEI Supercoil, is it any better? It comes with the low ohm contact bushing. It is only available in the red and yellow wires currently. Honestly the quality of the Acell spark plug wires improved a lot in 25 years, they were junk back then, they leaked voltage often, a few of us had issues. The now discontinued Accel 25 ohm race wires were the nicest wires I have owned. I bought one of the last sets new for my new motor. They held up to heat much better than the MSD Superconductor wires. The Accel 9000, the coated style, not the newer ceramic boot style, never tried them, were also decent wires.
Old Mar 27, 2022 | 09:35 AM
  #194
antzahh's Avatar
Well guys you know what!
After all testing and thinking we swapped the cheap aftermarket blue cap HEI in place an voilà! THE SPARK WAS THERE AGAIN, engine now sounds and feels what it should. Going to send couple mails to Progression Ignition hq
Old Mar 27, 2022 | 11:15 AM
  #195
Curious, what brand cap and rotor did you go with? Standard/Blue Streak, was the brand years ago, along with Accel. Most of the cheap Chinese cap and rotors seem Ok, quality wise. Some have seen issues with excessive resistance on the center contact, it could have been the issue. Glad it was simple fix.
Old Mar 27, 2022 | 02:44 PM
  #196
antzahh's Avatar
Its probably Blue Streak unit..
Old Mar 27, 2022 | 04:32 PM
  #197
fleming442's Avatar
Isn't Progression the one you can tune through your cell phone?
Old Mar 27, 2022 | 05:26 PM
  #198
CANADIANOLDS's Avatar
ya, the self learning app😁
Old Mar 28, 2022 | 08:54 AM
  #199
antzahh's Avatar
Yep!
Old Jul 25, 2025 | 12:45 PM
  #200
antzahh's Avatar
Well guys it's been a loooong time since I have posted anything so long story short;
All that ticking noice etc was from couple of exhaust valves touching the pistons. Nothing catastrophic, the cause was too tight of a valve lash. I had a millimeter feelergauge ( I'm from Europe, Finland) and ofc the specs on the cam card is in inches (That's how u pay the dues I guess?) so the lash was 3 x too tight what is should be.. Well after figuring that out I removed heads and disassembled them. Found couple of bent valves, bought new ones and assembled heads and installed them.
Car is running again, also bought all new MSD distributor, 6AL box and coil. Now its also getting a proper spark. Timing is adjusted by ear and jets are adjusted by eye by looking at plugs. Car houls *** with those adjustments already.. MORE coming soon or... sometime soonish?
