Parts Needed
79-85 Olds toro parts needed
I'm looking for the oil pick up and pump to fit my 81 olds diesel oil pan. This is so I can put my Olds 350 in my 84 Cadillac Eldorado.
Thank you -Matt
Thank you -Matt
FYI the oil pan you are seeking is different from the standard 350 oil pan... Comparing part number applications, the standard 307/350 pan (PN: 555137) is not correct for E-Body Cadillacs... Part number 563497 (discontinued) is correct for E-Body.... You can most likely also use PN: 563502 oil pan for the 350 diesel (larger oil capacity), but only from an E-Body... Other vehicles that would have the oil pan are - 79/85 Buick Riviera, 79/85 Oldsmobile Toronado, 79/80 Cadillac Eldorado, & 80 Cadillac Seville... Hope this helps...
If you are near a GM dealer, and before spending a lot of money, have the parts department recheck the numbers I provided.... Like I said the pan has to come from an E-Body (Buick, Cadillac, or Olds) application which had a 307/350 Gas or 350 diesel engine... sometimes I question the parts books being 100% correct....
HotRodRacer
Feb 8, 2012 10:25 AM
oldsdelta67
Jun 10, 2009 12:47 PM
