ignition switch arm kit.
Old Jun 25, 2015 | 05:01 PM
jfb's Avatar
jfb
I posted this in general discussion,if wanted read it. I am looking for the metal arm kit to the colum and to the lock and ignition switch,I understood from a 1st generation musclecar guy that it exists and was a gm part or something. if this does not exist anymore just the arm bushing it too was a fit for only gm colums and that is what I was told, I need a number and a name of the business posted and then I can roll. the bushing was a weird size also. I called several parts houses so just post facts.
Old Jun 25, 2015 | 08:40 PM
toymobile's Avatar
I don't understand what you need, I have a part column that is complete If I knew what you needed maybe I have it.
Johnny
Old Jun 25, 2015 | 08:55 PM
Originally Posted by toymobile
I don't understand what you need...
Yeah, I've become completely baffled after following along for a good while.
Maybe these will help us to loft a torch in the darkness:
Old Jun 25, 2015 | 09:20 PM
I'm assuming he needs the sector gear, rack, actuator rod, pivot pin, snap ring, and the 2 springs.
Old Jun 25, 2015 | 09:33 PM
Originally Posted by jfb
I need 1 more thing that bushing kit for the arm I need one
I am looking for the metal arm kit to the colum and to the lock and ignition switch...
If you got that from those, then I am impressed.
Old Jun 25, 2015 | 09:46 PM
Hey, we know the definition of assume...
Old Jun 25, 2015 | 10:33 PM
This vendor sells the internal parts for GM columns:
http://www.steeringcolumnservices.com/
Old Jun 27, 2015 | 06:45 AM
jfb's Avatar
jfb
thanks joe this has been a real hassle across the line and yes eric is right about those parts, I seriously have never had to go that deep into the colum and hardly anyone anywhere knows what I am talking about. that kind of work is a lost science. Those parts at one time was a kit and was considered a wear item. I until this point really had no idea of them. thanks again guys.
rcdynamic88
Apr 26, 2022 09:39 AM
HIGHCOMP425
Dec 20, 2011 07:19 PM
oldzy
Dec 19, 2011 06:43 AM
jag1886
Mar 25, 2011 07:41 AM
oldbutgood
Nov 12, 2002 10:00 PM
