Defogger main harness and relay wanted!
Old Nov 28, 2008 | 01:17 PM
Lady72nRob71's Avatar
Defogger main harness and relay wanted! ('70-72)
If anyone has a 1970-1972 parts car (Cutlass, 88, or 98) with a rear defogger, I would like to buy the main wiring harness under the hood and the relay(s) that mount to the firewall. See the attached pictures for the parts on A/C and non A/C cars.
Ideally I would like the harness for a car with A/C, but I can use the non A/C version also.
I do not NEED the dash switch, but if you have one I may consider it.
I do not need the wire running to the back of the car.
The terminals pop out of the dash switch connector for easy extraction through the firewall hole. However, if you must, the dash switch connector may be cut off and I can resplice it here upon reassembly.
The only terminal that will need extraction from a connector under the hood is at the A/C resistor (if the car has A/C).
If you have this, please PM me.
Many thanks!
pcard
May 14, 2014 01:21 PM
caddy
Mar 26, 2014 05:58 PM
FlyingV5150
Jan 14, 2014 11:27 AM
jjokrm
Nov 10, 2013 06:24 PM
