power steering hoses
Old Feb 18, 2015 | 09:13 AM
billwaldo's Avatar
need both sides,power steering hoses for 69-70 olds 98.these are nla at local parts store.also need 'S' manifold for same car.
thanks waldo
Old Feb 18, 2015 | 09:39 AM
RetroRanger's Avatar
72 Olds CS
Bill did you check rock auto? I got mine from them fits perfect.
Old Feb 18, 2015 | 09:40 AM
Professur's Avatar
Failing that, look about for a local hydraulic supply. They can often reuse your old ends with new hose.
Old Feb 18, 2015 | 10:17 AM
Rockauto shows three brands of the pressure hose:
EDELMANN Part # 70242
GATES Part # 352510
ACDELCO Part # 36352510
Any decent local auto parts store should be able to cross one of those numbers to a brand that they carry. In fact, if you simply Google the Gates number, OReily's shows up as the first link. If you type the Gates number into the NAPA website, you get NAPA P/N NPS 7653.
Just out of curiosity, which parts store told you they were NLA? I'd suggest finding another store.
By the way, the low pressure return hose is just bulk hose, cut to the correct length.
Old Feb 18, 2015 | 12:47 PM
lunaboy's Avatar
The Rocket Astronomer
not the S but i have one 67-69 big car T 3987094 RH
Used on big cars about '67-'69. Two holes; one for crossover pipe from the LH side. Main outlet has 2-bolt flange angled about 45 degrees down and back. Might fit in A-bodied cars, with effort. Companion to A, typically
Rallye469
May 5, 2015 02:24 PM
ent72olds
Dec 21, 2013 07:46 PM
Tedd Thompson
Sep 14, 2012 05:57 PM
cutlassgal
May 15, 2012 11:06 AM
dynamic371
Mar 1, 2007 12:57 PM
