56 Olds trim fasteners wanted
Old Aug 21, 2014 | 06:13 AM
Takid455's Avatar
As title states. Need all for side/ beltline trim.
Restoration Specialties in PA dosent have all of them. Fusick is no avail. as well.
Need:
1) Trim connectors (plate) w/ stud in center
2) Trim end pieces w/ stud on end
3) Rectangular ones for door (square receiving hole in door)
4) Typical GM trim fasteners w/ 12-24 stud and not 10-24 as most are now
Sliding and fixed stud.
5) Any others not pictured that may be needed
Reply or PM with what you have or source.
Need enough for whole car (2dr HT 88). Will buy in bulk.
1)
2)
3)
4)
Old Aug 21, 2014 | 06:38 PM
66400's Avatar
Don't know your location but if you can stop in Austin, Tx I have a 56 88 2drht. You remove them, you can have them.
Henry
Old Aug 21, 2014 | 06:55 PM
Tedd Thompson's Avatar
Try your local fastener store they generally have a good selection, thats where the body shops get a lot of theirs. Take what you have to match up against what they have some times two fasteners look differant but will do the same job....Tedd
Old Aug 22, 2014 | 08:38 AM
1977 Supreme's Avatar
From looking at the pictures have you thought about looking in some tri-5 chevy catalouges from like Original Parts group (OPG) or Year one
Old Aug 22, 2014 | 08:43 AM
Find a fastener store that handles this companies products:
http://www.auveco.com/product/auto.html
Old Aug 23, 2014 | 04:41 AM
Takid455's Avatar
In NJ and as much as I'd love to take a road trip, I don't think it will happen any time soon. If you could salvage any fasteners from the car, I would compensate you for your efforts.
Went through the Auveco catalog and came up short. Did have the trim fasteners with fixed stud but with 10-24 thread.
Good idea on the Tri 5. I'll see what they have. I was told some of these are unique to 56 olds, however as stated, another part may 'work' just as well
Old Aug 25, 2014 | 03:01 PM
tricordati's Avatar
Check out this eBay store http://stores.ebay.com/Golden-Cactus...p2047675.l2568
They just listed a bunch of trim fasteners for a 56 Olds
Old Sep 9, 2014 | 08:34 AM
Takid455's Avatar
After going through boxes and a parts car I have, here are the latest needs:
Need:
1) Trim connectors (plate) w/ stud in center. Only for lower 1/4 trim. 2 different heights 1" & 1 3/8". 2.75 & 3" respectively. Need 2 of each.
2) Trim end pieces w/ stud on end - need 4 of these
3) Rectangular ones for door (square receiving hole in door) - Only need 1. so close.
Need just 1 slider. 3/4" overall length. For upper 1/4 trim piece that curves to window. Also need the wide flange 12-24 nuts that go with these. need about 10. Any standard clips with 12-24 thread would be nice. Have newer ones w/ 10-24 thread if the OE ones are unavail.
I know someone has to have some of these pieces here.
Old Oct 23, 2014 | 05:38 AM
Takid455's Avatar
All found. close thread
Old Oct 23, 2014 | 06:12 AM
Good to hear, if you don't mind list your sources so others going down the same path may be able to find them also.
Old Oct 23, 2014 | 07:01 AM
Takid455's Avatar
Sure
1) Trim connectors (plate) w/ stud in center - made myself
2) Trim end pieces w/ stud on end - made myself
3) Rectangular ones for door (square receiving hole in door) - found between my car and parts car. Wound up using a different kind of fastener in the end as I felt it was a better solution.
Sliding and fixed stud. - Used new Auveco units with 10-24 studs where I did not have originals.
5) Any others not pictured that may be needed -
In the end, the aftermarket resto hardware suppliers kinda fell flat. Used my local resources and creativeness to find a solution to the issue.
tbristol
Body work
May 12, 2014 12:43 PM
speedstick
Aug 17, 2012 07:31 PM
CANVASWING
Apr 27, 2010 11:05 AM
TheBirds
Body work
Jan 18, 2010 07:31 AM
JSGD1966
Aug 5, 2008 06:17 AM
